JK's Titan615LX's - AVS Forum | Home Theater Discussions And Reviews
 152Likes
post #1 of 149 Old 03-18-2017, 06:59 AM - Thread Starter
Jk7.2's Avatar
Quoted: 247 Post(s)
Liked: 383
Just opening my flat pack boxes up so it's time to build. I am so excited to hear these bad boys for the first time. I've even got a couple of my friends excited so I have a little help to build these. I am not going to rush (I hope) on these and plan to sand the boxes down smooth and stain a ebony color and seal them with a matte type clearcoat. I'll paint the baffle flat black to kill reflection. These are going behind my a/t screen. I just got FedEx notification yesterday the rest of the kits are on there way! Thanks @Erich H for everything. The flatpacks were packed perfectly and there was no damage whatsoever.
ID:	2033481   Click image for larger version
ID:	2033489   Click image for larger version
ID:	2033497   Click image for larger version
Jk7.2 is online now
post #2 of 149 Old 03-18-2017, 06:59 AM - Thread Starter
Jk7.2's Avatar
Quoted: 247 Post(s)
Liked: 383
Reserved for final pics
Jk7.2 is online now
post #3 of 149 Old 03-18-2017, 07:03 AM - Thread Starter
Jk7.2's Avatar
Quoted: 247 Post(s)
Liked: 383
Example of the finish I'm shooting for. This is part of my bar top that is also Baltic Birch.
Jk7.2 is online now
post #4 of 149 Old 03-18-2017, 07:12 AM
Liked: 4
Subbed. Love seeing more of these getting built.
Twedter is offline
post #5 of 149 Old 03-18-2017, 07:13 AM
Rowan611's Avatar
Quoted: 276 Post(s)
Liked: 316
Like the finish. Look forward to the build. Nice to see these being bought and built.
Typed on a little keyboard, excuse any grammatical errors.
HT: Marantz 7702mkII | Crown Amps | Volt 8s | THTs | 1200Ds | Panamax 5300PM | LG OLED 65B6P | Oppo UHD-203 | PS4 |
Family: Pioneer SP-SB23W | Pioneer Kuro Elite 111 | X1
1299 build on standby
Rowan611 is offline
post #6 of 149 Old 03-18-2017, 07:32 AM - Thread Starter
Jk7.2's Avatar
Quoted: 247 Post(s)
Liked: 383
Thanks. The local MI group wants to compare these titans to Hd0823's qsc2150's. I can't wait to see how they hold up to each other. Even if it is an apples to oranges comparison, it's so fun to see and hear different speakers.
Jk7.2 is online now
post #7 of 149 Old 03-18-2017, 07:55 AM - Thread Starter
Jk7.2's Avatar
Quoted: 247 Post(s)
Liked: 383
Glued up the first box. Unbelievable how nice these fit together. I have only minimal clamps, and nothing long enough to actually clamp the width or height of the box, but I feel with enough glue and patients, just holding the panels for a few minutes by hand is enough, with small clamps to get what I could. Hell, I've heard of people building flatpacks with just glue and tape.
I need to get my insulation for inside the cab. I plan on mounting my crossovers inside the box, and using speakon connections for the input on the back, and for the high and mid wires through the top to the high and mid. I sorta want to make the top section removable for easy transport.
Jk7.2 is online now
post #8 of 149 Old 03-18-2017, 12:09 PM
hd0823's Avatar
Quoted: 181 Post(s)
Liked: 302
Can't wait to see these done. I like the choice of color for finishing them
Sent from my SM-N920V using Tapatalk
hd0823 is offline
post #9 of 149 Old 03-18-2017, 12:18 PM
VicTorious1's Avatar
Quoted: 485 Post(s)
Liked: 487
Did you already order the insulation?
VicTorious1 is offline
post #10 of 149 Old 03-18-2017, 12:25 PM - Thread Starter
Jk7.2's Avatar
Quoted: 247 Post(s)
Liked: 383
Thanks! I figured because I didn't have to cut and build boxes from scratch, it saved time I'll use to finish these.
Jk7.2 is online now
post #11 of 149 Old 03-18-2017, 12:26 PM - Thread Starter
Jk7.2's Avatar
Quoted: 247 Post(s)
Liked: 383
No. I wonder exactly what I should order. What was the stuff you used Vic?
Jk7.2 is online now
post #12 of 149 Old 03-18-2017, 12:31 PM
bgtighe23's Avatar
Quoted: 1539 Post(s)
Liked: 867
My guess is denim insulation. Very easy to place on the sides of the cabinet and not block ports.
I use poly-fil from walmart for my sealed cabs.
_____ _____ _____ _____ _____ _____ _____ _____ _____ _____ _____
Receiver : Denon x5200
Front Stage : Martin Logan Motion 60XTs/Elac Debut F5 Center
Surround Speakers : HTD Level 3 Towers/RBH R5Bi Front and Rear Heights
Subwooferage : Dual UM-18s/6 SI HT18s
Born in 1995 and still continuing my HT journey
bgtighe23 is online now
post #13 of 149 Old 03-18-2017, 12:32 PM - Thread Starter
Jk7.2's Avatar
Quoted: 247 Post(s)
Liked: 383
How thick is the denim insulation?
Never mind. I just ordered 2" denim insulation.
Jk7.2 is online now
post #14 of 149 Old 03-18-2017, 01:01 PM - Thread Starter
Jk7.2's Avatar
Quoted: 247 Post(s)
Liked: 383
Just a little more backstory...
As soon as I found out about these new speakers, I decided to upgrade to them. That means I had to tear out my front IB box to fit them, and well I was at it, the right wall of the theater room. I never liked the wall on the right. It had a stupid jog in it from the original basement construction. I also did some upgrading of my projector, epson 5040ub for my old 5030ub, oppo 203hd for the old 103D, and picked up two more ds4's from hd0823. As part of this redo, I'm installing an equipment closet in the rear as well. So a lot keepin me busy. More pics. Before and almost after of the room.
ID:	2034641   Click image for larger version
ID:	2034657   Click image for larger version
Jk7.2 is online now
post #15 of 149 Old 03-18-2017, 04:19 PM
eng-399's Avatar
Quoted: 1494 Post(s)
Liked: 2342
Subscribed!
The cabinets are coming along nicely. I like the finish your looking to get from he Baltic birch. I just priced it today picking up wood for my basement bar 60$ per sheet but the wood is really nice. These titans will have no problem keeping up with you subs. Nice room to!!
eng-399 is online now
post #16 of 149 Old 03-18-2017, 05:05 PM - Thread Starter
Jk7.2's Avatar
Quoted: 247 Post(s)
Liked: 383
Originally Posted by eng-399 View Post
Subscribed!
Thanks! I was happy with the I birch ply from hd. It was over 60 a sheet, but I only needed one. The bar rail killed me on price. It was like 16 bucks a foot.
Jk7.2 is online now
post #17 of 149 Old 03-18-2017, 05:43 PM
Quoted: 485 Post(s)
Liked: 487
I used 2" denim ultratouch. I think I have two or three rolls leftover if you need it.
post #18 of 149 Old 03-18-2017, 05:58 PM - Thread Starter
Jk7.2's Avatar
Quoted: 247 Post(s)
Liked: 383
Sending you a pm
Jk7.2 is online now
post #19 of 149 Old 03-19-2017, 08:47 AM - Thread Starter
Jk7.2's Avatar
Quoted: 247 Post(s)
Liked: 383
Progress today will only be gluing up the other two flat packs. The first one came out very good. Obviously with bigger and more clamps they could have been closer to perfect, but I am happy with how the first one turned out. The back panel had just a very slight bow in it, so there ended up a 1/32" gap in the center on both sides. I just filled it up with more glue from the outside, and ran a bead of panel adhesive from a tube on every seem inside the box. All corners and braces. Done.
brian6751, eng-399 and HzDownLow like this.
Jk7.2 is online now
post #20 of 149 Old 03-19-2017, 10:58 AM
HzDownLow's Avatar
Quoted: 22 Post(s)
Liked: 37
Looking forward to your build; I've been following every Titan build recently and plan on picking up a trio as well. Great colour choice for the cabinets and the bar top looks awesome to! What is your amplifier plans?
HzDownLow is offline
post #21 of 149 Old 03-19-2017, 11:09 AM - Thread Starter
Jk7.2's Avatar
Quoted: 247 Post(s)
Liked: 383
Thanks! I am keeping my eye out for an xpa-3 or something of that nature to pop up on the classifieds. Or I may just get the new emotiva amp at the three channel configuration. These will be so loud just on the a700 I have, but I want to send them enough juice for sure.
Jk7.2 is online now
post #22 of 149 Old 03-19-2017, 11:50 AM
brian6751's Avatar
Quoted: 1017 Post(s)
Liked: 951
According to the specs, there is only a 25 watt difference at 6ohms between the a300 and the older XPA 3
Sent from my ASUS_Z00AD using Tapatalk
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is online now
post #23 of 149 Old 03-19-2017, 12:07 PM - Thread Starter
Jk7.2's Avatar
Quoted: 247 Post(s)
Liked: 383
Thanks Brian. An A-300 it is.
brian6751 likes this.
Jk7.2 is online now
post #24 of 149 Old 03-19-2017, 12:09 PM
brian6751's Avatar
Liked: 951
Just one thing. The a300 is a two channel amp
Rivers Edge Theater
post #25 of 149 Old 03-19-2017, 12:21 PM - Thread Starter
Jk7.2's Avatar
Quoted: 247 Post(s)
Liked: 383
Ah. Well maybe a nice xpa-3 will be ok.
What about three bridged behringer a500's?
Jk7.2 is online now
post #26 of 149 Old 03-19-2017, 12:48 PM
brian6751's Avatar
Liked: 951
I'm going to be using a a300 on my L and R and everything else on a a700. Probably overkill.
You could get two B stock a300's. There's some available
Rivers Edge Theater
post #27 of 149 Old 03-19-2017, 02:03 PM - Thread Starter
Jk7.2's Avatar
Quoted: 247 Post(s)
Liked: 383
Lol yeah the 130db we maxed your spl meter out at was insane. It was loud enough, but the amps would add clarity. Overkill I would agree.
Jk7.2 is online now
post #28 of 149 Old 03-19-2017, 06:07 PM
brian6751's Avatar
Liked: 951
That's what I'm after. You could definitely tell the AVR was crying for mercy. Hopefully the amps give me the headroom I need. The 130db was mostly from the subs.
The Titans will be pulling more power out of your a700 so you may find that it gives you enough power. Emotiva doesn't list it but I would think it would be about 120watts into 6 ohms all channels. I'm calculating 110db rms from 10' away. That should work
Rivers Edge Theater
post #29 of 149 Old 03-19-2017, 07:35 PM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 571
I'd look at the outlaw 7140 and 5000 amps. More power lower distortion. Can't speak to build quality on the above.
Or stick to the xpa series. I started out with a upa700 and the build quality was pretty low. I can't imagine basx being much better.
Just my .02
Fattykidd is offline
post #30 of 149 Old 03-19-2017, 08:11 PM
mtg90's Avatar
Quoted: 442 Post(s)
Liked: 859
Note to calculate SPL on these using the 99dB/2.83v/1m sensitivity figure use the power into 8 ohm rating of the amplifier. So if say the amp does 100w at 8 ohms you would get 119dB/1m.
brian6751, VicTorious1 and Jk7.2 like this.
mtg90 is online now
