24" 3500w RMS $254 - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 767Likes
post #61 of 772 Old 03-21-2017, 07:18 AM
eng-399's Avatar
Quoted: 1507 Post(s)
Liked: 2365
eng-399 is offline
post #62 of 772 Old 03-21-2017, 07:24 AM
notnyt's Avatar
Quoted: 2522 Post(s)
Liked: 2294
WT2 is supposed to be better than DATS
BassThatHz and tuxedocivic like this.
notnyt is offline
post #63 of 772 Old 03-21-2017, 07:33 AM
eng-399's Avatar
Liked: 2365
eng-399 is offline
post #64 of 772 Old 03-21-2017, 07:34 AM
notnyt's Avatar
Liked: 2294
Maybe someone who's used both recently can comment?
BassThatHz likes this.
notnyt is offline
post #65 of 772 Old 03-21-2017, 07:37 AM
Bassment's Avatar
Quoted: 945 Post(s)
Liked: 377
So like actually how many amp service will the electrical company supply a residential service? Will they just give you whatever you ask / pay for or is there a limit? haha. Maybe they'll just charge you industrial rates
Bassment is offline
post #66 of 772 Old 03-21-2017, 07:45 AM
kgveteran's Avatar
Quoted: 417 Post(s)
Liked: 155
I assumed 200amp was the largest service for a residential service
kgveteran is offline
post #67 of 772 Old 03-21-2017, 07:54 AM
Bassment's Avatar
Quoted: 945 Post(s)
Liked: 377
You can definitely get 2-200 amp service as many very large custom homes will get that. I imagine you just pay for each 200 amp line to your house, and they will do whatever you ask. Unless there is some kind of law against residential customers having too much power available for some reason.
edit: Looks like it's about $3000 to go from 400 amp to 600 amp service that's not too bad! lol
http://www.garagejournal.com/forum/s...d.php?t=134414
Bassment is offline
post #68 of 772 Old 03-21-2017, 08:00 AM
BllDo's Avatar
Quoted: 595 Post(s)
Liked: 393
Kipnis had two 800 amp transformers installed for his house. He said his electric bill was north of $1200 per month.
BllDo is offline
post #69 of 772 Old 03-21-2017, 08:08 AM
Bassment's Avatar
Quoted: 945 Post(s)
Liked: 377
Haha that's awesome. Who is that?
Bassment is offline
post #70 of 772 Old 03-21-2017, 08:34 AM
Decadent_Spectre's Avatar
Quoted: 373 Post(s)
Liked: 177
Decadent_Spectre is offline
post #71 of 772 Old 03-21-2017, 09:34 AM
N8DOGG's Avatar
Quoted: 1059 Post(s)
Liked: 1145
You can get a 600 amp service if you are willing to pay for it lol. I've seen a few with 2 x 200s that my brother worked on. It was literally 200a panel on each side of the house.
N8DOGG is offline
post #72 of 772 Old 03-21-2017, 09:56 AM
Mattcc22's Avatar
Quoted: 122 Post(s)
Liked: 107
I work for a genset sales company and do a lot of residential installations. We regularly see custom homes with 300-400A services and every once in a while you might see a 600A service, but not very common.
Mattcc22 is offline
post #73 of 772 Old 03-21-2017, 11:41 AM - Thread Starter
BassThatHz's Avatar
Quoted: 2219 Post(s)
Liked: 1874
They confirmed they got the money and are building it now.
BassThatHz is offline
post #74 of 772 Old 03-21-2017, 12:12 PM
asarose247's Avatar
Quoted: 767 Post(s)
Liked: 543
Back in '92 I installed my own 200 amp panel , the mast, et al, inspected etc.
and then Edison came out and did the"touch" as they called it that.
3 isolated ground 20 amp lines for the HT.
no guessing
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is online now
post #75 of 772 Old 03-21-2017, 12:33 PM
Liked: 2
Hi there.
In the german forum beisa m men . de they actually did a group buy from that chinese company. The outcome was the so called "Luftverschieber" (Air-Displacer).
I had 2 of these subs at home but never built anything with them. Superior build quality, cheap (arround 120 per unit--> INCLUDING SHIPPING), great TSP for output below 60hz in a sealed box.
Oh, not to forget: They are the manufacturer of the Stereo-Integrity Subwoofers.
Herb
HerbertThePervert is offline
post #76 of 772 Old 03-21-2017, 04:36 PM
mrogowski's Avatar
Quoted: 147 Post(s)
Liked: 277
Hope things work out for you.
Sent from my 80-286 DOS 3.2/Windows 3.0 machine using Terminal
mrogowski is offline
post #77 of 772 Old 03-21-2017, 06:42 PM - Thread Starter
BassThatHz's Avatar
Liked: 1874
You mean this?
  • Spends $6,000,000
  • $2 drywall
  • Spends $6,000,000.
  • Forgets to install air conditioning.
  • Forgets in-floor cable management
  • Maybe some more disco lights and disco balls will fix it
  • Claims flat to 1Hz
  • Uses high-tuned ported subwoofers with PA drivers
Did I miss anything?
ID:	2041441   Click image for larger version
ID:	2041449   Click image for larger version
ID:	2041457   Click image for larger version
post #78 of 772 Old 03-21-2017, 06:47 PM
eng-399's Avatar
Liked: 2365
eng-399 is offline
post #79 of 772 Old 03-21-2017, 06:57 PM
BllDo's Avatar
Quoted: 595 Post(s)
Liked: 393
He also claims his speakers will produce a 9 knot wind. Um, yeah.
BllDo is offline
post #80 of 772 Old 03-21-2017, 07:17 PM - Thread Starter
BassThatHz's Avatar
Liked: 1874
Originally Posted by eng-399 View Post
Those amps have to be throwing some major heat from them to.
Heck yeah.
When I first moved we threw a house party. It was in the middle of winter.
I had the heater off, and we had to open the doors every 10 minutes because the air temp was approaching deadly temperatures.
A combination of 10-15 people dancing in a room with 50kW and in an R-40 insulated hermetically-sealed room-in-room.
In the summer my roof can be 115 degrees, but inside it is room-temp, without any air conditioning on.
In the winter, I can heat my room with just a 6-inch heater or my amplifiers at full-tilt for 8 hours. (and that's well below freezing.)
I'd run my HTPC+ power conditioner 24/7/365, which is 200w idle, and that heated the room +30 degrees.
Which is handy in the winter but a pain in the summer.
I could only imagine 90 vacuum tubes (or whatever his is running there.)
Good thing he has like 16ft walls. Otherwise it would be death hot in there...
especially when bumping loud for a few hours with the projector on, and all that array of 150w disco lights...
I could totally see a power bill of $1200 a month if he left it on.
post #81 of 772 Old 03-21-2017, 07:32 PM
BBLV's Avatar
Thanks diving in on this Chinese 24" woofer.
Anyone know if Mach 5 is still planning on bringing a 24" to market? I inquired on status through their FB page several weeks ago, but no response.
BBLV is offline
post #82 of 772 Old 03-21-2017, 08:43 PM - Thread Starter
BassThatHz's Avatar
Liked: 1874
I re-re asked them for the T/S specs.
I'm guessing they don't know, or don't care, or both!
post #83 of 772 Old 03-22-2017, 05:18 AM
mrogowski's Avatar
Quoted: 147 Post(s)
Liked: 277
Yes.
BBLV likes this.
post #84 of 772 Old 03-22-2017, 06:14 AM
Magibeg's Avatar
Quoted: 289 Post(s)
Liked: 141
Originally Posted by mrogowski View Post
Yes.
You gotta give us more details than that! My FTW-21's are starting to feel lonely.
Magibeg is offline
post #85 of 772 Old 03-22-2017, 06:21 AM
mrogowski's Avatar
Quoted: 147 Post(s)
Liked: 277
Oh. LOL
Not here. This thread has become polluted enough with off topic rhetoric.
post #86 of 772 Old 03-22-2017, 07:49 AM
Quoted: 703 Post(s)
Liked: 370
I have to ask this since I cannot figure out the answer myself. Big drivers are cool and all that, but what is actually stoping manufacturers from producing a smaller driver with excursion massive enough to match a performance of much bigger driver:. eg. 18" that would perform identically as HS24 by SI?
Revel Ultima Salon 2, Revel M106, Revel C208, Yamaha P5000S, Denon X5200, Panasonic 65" VT50, SVS PC13-Ultra
Kef LS50, Parasound New Classic, Focusrite 2i2
donktard is offline
post #87 of 772 Old 03-22-2017, 08:45 AM
MKtheater's Avatar
Quoted: 1678 Post(s)
Liked: 1197
Probably cost. The Rockford that Ricci uses is a very robust 19 inch and costs $2500 and still can not produce the same spl as the SI 24 which is much less in price. Upper bass is on par with each other.
Marantz 7702 Atmos
Outlaw 7140 and 5000
Speakers- TBD
subs 2 XXX ported SLLT powered by IPR2-7500.
MKtheater is online now
post #88 of 772 Old 03-22-2017, 09:27 AM
basshead81's Avatar
Quoted: 222 Post(s)
Liked: 6100
Cost, sound quality, and efficiency are a trade off of a ultra high excursion smaller cone driver. More excursion equals more distortion. Then you need more expensive components( voice coils and increased motor strength) for proper heat dissipation and cone control.... that drives the cost up. Also, more amplification is required to get that driver to xmax and that also contributes to more cost in the end. Imo you are always better off to go with a larger cone when possible. That is why in Pro Audio, multiple lower xmax 18 and 21" drivers with lightweight components are used because they can play hours on end at extreme levels without smoking a coil.
basshead81 is offline
post #89 of 772 Old 03-22-2017, 10:42 AM
tuxedocivic's Avatar
Quoted: 2038 Post(s)
Liked: 1904
Also physical limitations of the size of VC, spider diameter, surround size, and only 18" of basket to hold it all. A spider big enough to handle say 75mm of xmax with a 4" VC would need to be maybe 18" in diameter. So the basket needs to be bigger than 18". Hypothetical numbers of course.
It would be very non-linear too.
LTD02, BassThatHz and basshead81 like this.
Ryan
tuxedocivic is offline
post #90 of 772 Old 03-22-2017, 11:06 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5641 Post(s)
Liked: 4601
Can't f**king stand that Kipnis "theater".
GLW the 24's @BassThatHz
Aaron Smith and BassThatHz like this.
Scott Simonian is offline
