Seos 24, 135Hz Midbass Horn and Quad PA460 18" - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 63Likes
post #31 of 74 Old 07-23-2017, 10:50 PM - Thread Starter
jshadzi's Avatar
Quoted: 98 Post(s)
Liked: 344
Originally Posted by Trimlock View Post
Love the reclaimed wood look.
What are your ports made out of? And where do you get them? They look like cardboard.
Yea cardboard shipping tubes, we get them by the ton at my company, .15" wall thickness and perfectly round, they glue solidly to any wood baffle (unlike PVC), I use them in all my builds. Thanks for following!
Javad
Trimlock likes this.
jshadzi is offline
post #32 of 74 Old 07-23-2017, 10:51 PM - Thread Starter
jshadzi's Avatar
Quoted: 98 Post(s)
Liked: 344
Originally Posted by gpmbc View Post
Really diggin the rat rod theme! The boxes look nice all around and the front is a nice touch.
Thanks! It's a fun theme as the attention to detail doesn't have to be as good as my usual build, and it follows the older horn concept.
Javad
jshadzi is offline
post #33 of 74 Old 07-23-2017, 10:54 PM
Quoted: 70 Post(s)
Liked: 74
Javad
Interesting, I bet it glues better because its porous but my experience with glueing PVC was never bad. It is just difficult to get in place.
It looks like you cut out a groove for the tube with a rabbit bit and a massive bearing lol.
I'll have to try this on my next build!
Good work as usual.
Trimlock is online now
post #34 of 74 Old 07-23-2017, 11:12 PM - Thread Starter
jshadzi's Avatar
Quoted: 98 Post(s)
Liked: 344
Good work as usual.
Yea it's made from wood so the bond is permanent, and it's free and very easy to work with, thanks for the kind words!
Javad
jshadzi is offline
post #35 of 74 Old 07-24-2017, 02:14 AM
Quoted: 512 Post(s)
Liked: 58
How difficult was the mid horn build? It would seem that the angles would be tough to figure out on your own. Did you have a set of plans to go by? If so, how could I go about obtaining a set of these plans? How much do the plans cost?
Tip24/96 is offline
post #36 of 74 Old 07-24-2017, 07:25 AM - Thread Starter
jshadzi's Avatar
Quoted: 98 Post(s)
Liked: 344
Yes it's tough, much more complicated than the average Speaker Build, but doable. You can get "plans" from inlow sound.com but they're just dimensioned drawings and cost $25. I came up with my own way to build them from what John suggests as it allowed me to make all my cuts in a sliding chop saw, now that I know how it's quite easy but there was a few weeks of head scratching as I wrapped my brain around it.
Let me know if I can help,
Javad
jshadzi is offline
post #37 of 74 Old 07-24-2017, 08:28 AM - Thread Starter
jshadzi's Avatar
Quoted: 98 Post(s)
Liked: 344
Out of the clamps this morning, 2nd one in the clamps and 2 more to go. I'm letting the Loctite cure for 12 hours as the pallet baffles aren't perfectly flat and do load up a little when clamped.
filtor1 likes this.
jshadzi is offline
post #38 of 74 Old 07-24-2017, 11:00 AM
OJ Bartley's Avatar
Quoted: 249 Post(s)
Liked: 345
Love those baffles. Amazing.
Sent from my SM-A520W using Tapatalk
jshadzi likes this.
OJ Bartley is offline
post #39 of 74 Old 07-24-2017, 06:12 PM
BassThatHz's Avatar
Quoted: 2317 Post(s)
Liked: 2065
You should upload some music with singing in it.
Singing is much more revealing.
Unless you are a violinist or trombonist or something, you'll never notice anything off with such music.
The timbre and/or harmonics could literally be off by 10db or whatnot, and we'd never know it.
Unless you are a hardcore Bach listener who just happens to visit this specific DIY site and open this particular thread, or happens to stumble on it randomly on youtube; THEN you might be able to form an opinion on what is heard.
The only time I've typically listened to classical is when my grade 3 teacher used to force us to do it during reading hour.
I'm not sure what most of the students were thinking at the time, but I'd bet half of them were like... (FML!) on the inside... hehe
jshadzi and Trimlock like this.
BassThatHz is offline
post #40 of 74 Old 07-24-2017, 08:02 PM - Thread Starter
jshadzi's Avatar
Quoted: 98 Post(s)
Liked: 344
Preaching to the choir, check out my YouTube channel, mostly music with vocals on all my speaker videos,and I voice every crossover I do with female vocal music.
Once I have this system back together I'll upload some nice Jennifer Warnes for you =)
Javad
jshadzi is offline
post #41 of 74 Old 07-24-2017, 08:59 PM - Thread Starter
jshadzi's Avatar
Quoted: 98 Post(s)
Liked: 344
Work continues! These showed up, and a damn nice driver for $90!
Tested out my port tuning, spot on!
One port blocked 24hz
Both ports open 32hz
Model for both, 12db XO at 110hz included, 250watts
Port velocities more than acceptable for both configs, both w/in xmax or so
1/2" Round over on ports and 1/4" roundover on baffle driver opening
And I had a special helper =)
Javad
jshadzi is offline
post #42 of 74 Old 07-24-2017, 09:13 PM
OJ Bartley's Avatar
Quoted: 249 Post(s)
Liked: 345
Lol, "my speaker".
post #43 of 74 Old 07-24-2017, 11:21 PM
Quoted: 70 Post(s)
Liked: 74
That is now hers and will be known as castle baby kingdom.
But seriously it looks awesome.
Won't the round over mess with your tuning? Why not test after the round over?
jshadzi likes this.
post #44 of 74 Old 07-25-2017, 07:35 AM - Thread Starter
jshadzi's Avatar
Quoted: 98 Post(s)
Liked: 344
Haha, yea she's hooked now! The roundover on the port? They are rounded over now, and it's only 1/2" so figure it's like a 1/4" change in port tube length, negligible but tuning is right where I want it even with the round over.
jshadzi is offline
post #45 of 74 Old 07-25-2017, 11:35 PM - Thread Starter
jshadzi's Avatar
Quoted: 98 Post(s)
Liked: 344
Flushed up the baffle
And 45 degree bevel on all edges
And where all 4 stand
Next step is some sanding and filling, some more detail work and finally a few coats of Danish Oil.
Javad
EarlK likes this.
jshadzi is offline
post #46 of 74 Old 07-25-2017, 11:36 PM
Quoted: 70 Post(s)
Liked: 74
I love chamfers !
jshadzi likes this.
post #47 of 74 Old 07-27-2017, 03:22 PM - Thread Starter
jshadzi's Avatar
Quoted: 98 Post(s)
Liked: 344
Did some filling and finish sanding on front baffle interface to main cabinet
Some of gaps were as big as 1/8".
Javad
jshadzi is offline
post #48 of 74 Old 07-27-2017, 03:31 PM
corradizo's Avatar
Quoted: 1138 Post(s)
Liked: 843
corradizo is offline
post #49 of 74 Old 07-27-2017, 05:42 PM - Thread Starter
jshadzi's Avatar
Quoted: 98 Post(s)
Liked: 344
I like the elmers stainable wood filler, also use Famowood
jshadzi is offline
post #50 of 74 Old 07-28-2017, 09:20 AM - Thread Starter
jshadzi's Avatar
Quoted: 98 Post(s)
Liked: 344
Since these subwoofers will be configurable in dual opposed or stacked, I made some brackets to connect them together in different configurations.
Here are the pieces cut and beveled
Holes drilled for fastening knobs
Fixture for transferring mounting holes and spacing brackets the same
Threaded inserts used on the inside of the enclosure, these are M8x1.5mm
Test fit, dual opposed
And stacked, dual bolt patters allow both configurations
Binding posts installed
eng-399 and Trimlock like this.
jshadzi is offline
post #51 of 74 Old 07-28-2017, 09:54 AM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
Those brackets are awesome!
jshadzi likes this.
gpmbc is online now
post #52 of 74 Old 07-28-2017, 01:15 PM
OJ Bartley's Avatar
Quoted: 249 Post(s)
Liked: 345
Since these subwoofers will be configurable in dual opposed or stacked, I made some brackets to connect them together in different configurations...
Looking great! Just say YES to chamfered edges, people!
Hmmmm, kind of reminds me of something... only prettier in your version.
jshadzi likes this.
post #53 of 74 Old 07-28-2017, 01:47 PM - Thread Starter
jshadzi's Avatar
Quoted: 98 Post(s)
Liked: 344
Haha, glad you like! Yours look a lot more x-max-ey! =)
jshadzi is offline
post #54 of 74 Old 07-28-2017, 01:51 PM
OJ Bartley's Avatar
Quoted: 249 Post(s)
Liked: 345
Well, different purposes I guess.
I wish all of my corners had lined up as nicely as yours did. I like the locking method, I've been considering a system like that for my workbench.
jshadzi likes this.
post #55 of 74 Old 07-30-2017, 09:42 AM - Thread Starter
jshadzi's Avatar
Quoted: 98 Post(s)
Liked: 344
You know in Goonies at the end when the pirate ship sails out and the cop says "holy Mary...Mother of God!"...?
Well that's sort of how firing these things up for the first time was like!
First some finishing details.
Rat Rod passive XO, low pass around 125hz
Mounting the drivers
Dual opposed configuration
XO installed and split to top section
Aaaand, wala
Did some quick XO tweaking and ended up with this, bass is about 3-5db down and I'm going to try Biamping to even that out before resorting to active.
Initial impressions...WOW, this is the type of speaker that gives you a physiological response to music, I find my heart rate and pulse raising listening to my reference music. Bass is prodigious, like shake your hair and other body parts powerful, SPL is effortless, I hit 50% volume on my Adcom preamp and it sounded like the house was rattling from the inside out, volumes easily 115db+ at 1-meter, and that's on less than 300 watts or so per channel (Adcom GFA-555).
Fun stuff! Will keep playing with them!
Javad
jshadzi is offline
post #56 of 74 Old 07-30-2017, 09:44 AM
FriscoDTM's Avatar
Quoted: 303 Post(s)
Liked: 270
Wow - Your wife must love those!
Display 2013 Samsung 75" UN75F6300 TV Media Xbox One S, Dune Solo, QNAP TS-453A NAS
Pre/Amp Marantz 7702mk2 Processor + DIY 11ch Icepower 50ASX2BTL Monoblock Amp Amp Build Link
7.2.4 Speakers DIYSG 1099s (LCR), Volt 10LX (SL, SR), Volt 8LX (BL, BR), Volt 10LX (TF, TR) Volt Build Link
Subs Dual 19Hz DIY Ported UXL-18s + FP14k Amp + MiniDSP 2x4 Balanced Tactile Crowsons + iNuke 6000DSP
FriscoDTM is offline
post #57 of 74 Old 07-30-2017, 10:15 AM - Thread Starter
jshadzi's Avatar
Quoted: 98 Post(s)
Liked: 344
She's pretty awesome, she doesn't "like" them but she's quite tolerant letting me do what I want with that room =)
jshadzi is offline
post #58 of 74 Old 07-30-2017, 11:28 AM
Quoted: 70 Post(s)
Liked: 74
My daughter would of drawn all over those by now! "Oh look, its unpainted, let me help..."
Face2 likes this.
post #59 of 74 Old 07-30-2017, 12:02 PM
Face2's Avatar
Quoted: 343 Post(s)
Liked: 207
Those look wild! They also make my SEOS24 builds look boring, lol!
Sent from my SM-G935V using Tapatalk
jshadzi likes this.
Face2 is online now
post #60 of 74 Old 07-31-2017, 12:49 PM
BassThatHz's Avatar
Liked: 2065
Probably room modes... The optimal location for subwoofers is rarely where the fronts need to be.
