Sand Filled 1099 Base - AVS Forum | Home Theater Discussions And Reviews
 6Likes
  • 2 Post By rhodesj
  • 1 Post By wilesone
  • 3 Post By Raylon
post #1 of 25 Old 03-30-2017, 05:23 PM - Thread Starter
Raylon's Avatar
Quoted: 264 Post(s)
Liked: 280
I am currently building a set of bases to heighten my 1099's to get all the horn heights the same. This requires a 14" increase in my case. I've read about filling the hollow space with sand so I did this, but holy crap one 70lb bag of sand went nowhere. As you can see below, each stand has about 35 lbs of sand in it. Looks like they can easily hold well over 100lbs each! Is this dumb? Can I leave just that much in it? Can I put a filler in there like a 4x4 post or something? Please advise this newbie!
Name:	2017-03-30 19.17.49.jpg
Raylon is offline
post #2 of 25 Old 03-30-2017, 05:42 PM
asarose247's Avatar
Quoted: 838 Post(s)
Liked: 644
NO doubt -we're all in favor of speakers that are inclined stay put . .
you know that just sometimes, things just have to get shuffled around
you already cut the stands to size for the horn alignment
for that kind of weight and the effort possibly involved
what about "good looking" wheels, furniture dual weight rated, you know
what about a harbor freight dolly, good , so they say, for 1000#, even the small ones.
you could try some 1" wheels, maybe 6 for each base for a less obtrusive look, as long as the weight rating total comes close .
you may have to reduce the height of your stands
carpet would make things a bit tougher but not impossible
it's a bit of work , but you can dissemble a HF dolly and make it the size you "need".
I did that for the VBSS sub, a single dolly
the big subs got co-joined dollies, they clock in at over 300#.
HTH for a possible workable answer/ direction
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is offline
post #3 of 25 Old 03-30-2017, 05:50 PM
dtsdig's Avatar
Quoted: 912 Post(s)
Liked: 1037
35 pounds is good enough. I wouldn't sweat it! My 1099 towers don't have anything in the bottoms and the still weigh 150 pounds each! They aren't going anywhere and having empty bases creates no ill effects.
dtsdig is online now
post #4 of 25 Old 03-30-2017, 05:52 PM
rhodesj's Avatar
Quoted: 942 Post(s)
Liked: 533
I'm sure it's plenty of weight for stability. I'd cut out a board that'll fit inside the box on top of the sand to keep it from sloshing around.
JohnDean and ejr1212 like this.
rhodesj is offline
post #5 of 25 Old 03-30-2017, 05:54 PM - Thread Starter
Raylon's Avatar
Quoted: 264 Post(s)
Liked: 280
Ok I was worried more about resonance than weight, I know they aren't going anywhere weight wise. Also the sand is super dry but I am a little worried about a tiny amount of moisture being in there. Any worry about a tiny amount of moisture? I can stick my hand in and swirl my hand around and my hands will just be covered in dust, no moisture at all, I am just a little worried about it still though.
Raylon is offline
post #6 of 25 Old 03-30-2017, 05:56 PM
dtsdig's Avatar
Quoted: 912 Post(s)
Liked: 1037
If you're stressed about the moisture, you could throw some large sized desiccant packs in there. I think some guys put the sand in a bag to begin with; even multiple gallon size freezer bags would do.
post #7 of 25 Old 03-30-2017, 06:10 PM
wilesone's Avatar
Quoted: 14 Post(s)
I used Cat litter in my old ascend 340se stands to not have to worry about moisture.
brian6751 likes this.
wilesone is offline
post #8 of 25 Old 03-30-2017, 09:15 PM
Oval56's Avatar
Quoted: 27 Post(s)
Liked: 72
Hi
The other alternative to sand would be garnet used for sandblasting and its dry.
Cheers
DIY , Ikea Style
Oval56 is offline
post #9 of 25 Old 03-31-2017, 04:43 AM
brian6751's Avatar
Quoted: 1173 Post(s)
Liked: 1143
Kitty litter seems to be the most recommended
Sent from my ASUS_Z00AD using Tapatalk
That's not science! - Cyborg
FOR SALE: nothing at the moment
Rivers Edge Theater
brian6751 is online now
post #10 of 25 Old 03-31-2017, 05:18 AM
EndersShadow's Avatar
Quoted: 631 Post(s)
Liked: 954
Fill it all the way up man. Then put handles on it, and use em as dumbells .
I'd think your fine. As a "thought" you could also run a PVC pipe through it to route your speaker wire up and through it to make things look cleaner, provided you dont have something in place already lol.
My Setup | FS: Salamander Synergy 303, Outlaw LFM-1 sub, Sanus UF22 Speaker Stands, Nintendo Wii, 5 channel Polk LSi system (all threads here)
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is offline
post #11 of 25 Old 03-31-2017, 05:25 AM
1_sufferin_mind's Avatar
Quoted: 61 Post(s)
Liked: 211
My sand-filled Bright Star Audio bases have been exposed to air for 6 years now with no problems. I'm certain because I just emptied them the other day and the sand flowed freely. No damage to the frames was observed either.
I'm taking my meds !!
Revel Ultima Salons & Voice / PSB B5 / PSA XV-15 / Emotiva XMC-1 / Emotiva XPA-5 / Oppo BDP-95 / Sony PS3 / Cable-TV / Panasonic 50" Plasma / Samsung 60" Plasma
Custom McCormack Monoblocks / Custom Cary SLP98P / VPI Super Scoutmaster with JMW9 and Benz Micro Glider H2 / PS Audio PWT / PS Audio PWD with Network Bridge
1_sufferin_mind is offline
post #12 of 25 Old 03-31-2017, 05:30 AM - Thread Starter
Raylon's Avatar
Quoted: 264 Post(s)
Liked: 280
You know I hadn't got to designing that part yet. I think I will skip that hassle and make wires enter in the sealed cavity of the 10" driver and skip trying to go through the sand part. Good to think about that now though before putting it all together.
Thanks for all the recommendations, I think I will stick with the sand I have it seems super dry and will probably work.
Raylon is offline
post #13 of 25 Old 03-31-2017, 06:54 AM
Mattcc22's Avatar
Quoted: 132 Post(s)
Liked: 120
Maybe put some bracing in the box if you are worried about resonances. Then you can fill the rest of the space with pink fluffy or similiar.
Mattcc22 is offline
post #14 of 25 Old 03-31-2017, 07:41 AM
rhodesj's Avatar
Quoted: 942 Post(s)
Liked: 533
As far as I know, sand can't absorb moisture from the air. The only moisture issue is if it's damp coming out of the bag. If it's dry, your fine.
Also, regarding resonance, I'd rather add a couple braces to the box than to fill it with 200 pounds of sand.
rhodesj is offline
post #15 of 25 Old 03-31-2017, 07:48 AM - Thread Starter
Raylon's Avatar
Quoted: 264 Post(s)
Liked: 280
Ok so that solves it. I'll keep my current sand for weight and throw a brace across in the middle to deaden any resonance. The sand has already one a pretty good job of that but the brace should finish it off.
Raylon is offline
post #16 of 25 Old 03-31-2017, 08:39 AM
Quoted: 631 Post(s)
Liked: 954
As mentioned if you want to make sure just throw those packets you get when you buy shoes, etc in there as you get them. Maybe put a slot in the back or something for it.
Cant hurt and it wont cost you anything since you'd throw those out anyway.
post #17 of 25 Old 04-19-2017, 01:00 PM
Liked: 0
Did you consider lead weights?
The_Helmsman is offline
post #18 of 25 Old 04-19-2017, 01:34 PM
Manic1!'s Avatar
Quoted: 198 Post(s)
Liked: 92
Just another thought but what about spraying some low expanding foam in there.
Manic1! is offline
post #19 of 25 Old 04-19-2017, 02:03 PM - Thread Starter
Raylon's Avatar
Quoted: 264 Post(s)
Liked: 280
Did not. The goal was to kill any resonance not make it weigh 400 lbs
That I hadn't though of at the time but that probably would have been a great idea.
Raylon is offline
post #20 of 25 Old 04-19-2017, 02:06 PM
eng-399 is online now
post #21 of 25 Old 04-19-2017, 05:22 PM - Thread Starter
Raylon's Avatar
Quoted: 264 Post(s)
Liked: 280
Originally Posted by eng-399 View Post
Ryan do you have any pictures of the cabinets.
I was hoping I could actually finish a project and then post the final pictures but this project is taking forever. I have assembly almost done then it's time for paint prep. Here is a sneak peek!
The center channel has the grill support assembled.
nlpearman, Rowan611 and eng-399 like this.
Raylon is offline
post #22 of 25 Old 04-19-2017, 05:38 PM
Rowan611's Avatar
Quoted: 392 Post(s)
Liked: 463
Looks good!!!
HT: Marantz 7702mkII | Crown Amps | 1299 L/C/R | Volt 8s | THTs | 1200Ds | Panamax 5300PM | LG OLED 65B6P | Oppo UHD-203 | PS4 |
Family: Pioneer SP-SB23W | Pioneer Kuro Elite 111 | X1
Rowan611 is offline
post #23 of 25 Old 04-19-2017, 05:59 PM
Liked: 4
What are you planning on using for grills? How'd you build in the grill support?
Twedter is offline
post #24 of 25 Old 04-19-2017, 06:22 PM - Thread Starter
Raylon's Avatar
Quoted: 264 Post(s)
Liked: 280
So the speakers are going to be all white with white fabric grills. I purchased the white grill material from parts express. I bought 3/16" x 3/4" stock metal and had a buddy come over and weld the support together. He made it perfect it fits cozily in there and once I attach the fabric I think it will be nice and snug. I layered 1/2" Baltic birch plywood over the edges of the cabinet for my nice exterior and to hold the grills.
Raylon is offline
post #25 of 25 Old 04-21-2017, 05:20 AM
Quoted: 46 Post(s)
Just build a small filler box that leaves a half inch space between it an the current box. put some half, or even one quarter inch, spacers on the bottom to form a space under the inner box. Then fill the gap with sand. that will keep any wall resonances controlled. Fill the inner box with fiberglass.
artsci2 is offline
