Anyone using Crown K2's - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By kgveteran
post #1 of 8 Old 04-19-2017, 05:53 AM - Thread Starter
kgveteran's Avatar
Quoted: 465 Post(s)
Liked: 174
I was thinking of using my (4) QSC1450's for 7ch surround duty, and maybe the Crown K2 bridged for my four 15's. They can be had on ebay for $450 used. Any thoughts about this......the K2's put out about 2500watts bridged and no fans as a small side thing. The QSC's did about 1500watts.......
kgveteran is offline
post #2 of 8 Old 04-19-2017, 12:22 PM
BassThatHz's Avatar
Quoted: 2346 Post(s)
Liked: 2108
Never used it myself but i heard good things about it from diy'ers 12 years ago.
BassThatHz is offline
post #3 of 8 Old 04-20-2017, 03:19 AM - Thread Starter
kgveteran's Avatar
Quoted: 465 Post(s)
Liked: 174
post #4 of 8 Old 04-20-2017, 07:18 AM
Vince_B's Avatar
Quoted: 83 Post(s)
Liked: 52
K2 is a good amp, have one running an hs24 sealed on one channel and two ava15 sealed on the other channel all going through a medium aggressive linkwitz transform and it can get scary loud. Iirc they roll off a bit higher in the ulf than ideal but no fans and absolutely bulletproof. I accidentally had the ava15 pair set up as a 1 ohm load for a couple days and I wasn't pounding on it too badly but it didn't bat an eye.
Edit, I should probably qualify, scary loud by normal people's standards not avs diy speaker standards
Sent from my SM-N910V using Tapatalk
Vince_B is offline
post #5 of 8 Old 04-20-2017, 09:58 AM - Thread Starter
kgveteran's Avatar
Quoted: 465 Post(s)
Liked: 174
Ahhhhh, i do remember it having a bit of a hipass to it, gonna have to look into that, thanx
post #6 of 8 Old 04-20-2017, 10:03 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5972 Post(s)
Liked: 5025
Haha! A K2? Damn man. What year is this?
Take me back to 2006!
They produce good power up to a point. Earlier class-D switching power supply amp, IIRC. Wouldn't use it for anything than subs. Should be decent to power the Tummies.
IIRC it had a steep HPF ~7-8hz.
Scott Simonian is offline
post #7 of 8 Old 04-20-2017, 01:05 PM
shivaji's Avatar
Quoted: 739 Post(s)
Liked: 617
Here are some measurements on the K2, I remember reading this some time ago when first posted here on AVS. Wow, i have been visiting this site for some time now. By the way, I use a Crown K2 to power my mains and I find it an excellent amp used full range. Its clean, transparent and has tremendous bass slam as its known for. Sometimes, I go OPPO 93 direct into the K2. A nice, fairly minimalist system, that just happens to have 500 watts per side.
Measuring Amplifiers
shivaji is online now
post #8 of 8 Old 04-24-2017, 11:33 AM - Thread Starter
kgveteran's Avatar
Quoted: 465 Post(s)
Liked: 174
Thanx for the link, i actually remember that testing thread, good times !!!
shivaji likes this.
