using different speakers in old cabinets - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Rowan611
Old 04-19-2017, 10:29 AM - Thread Starter
XXXtraanchovie's Avatar
i have nht classic 4 and classic 3 speakers and the woofers are showing signs of dry rot. my plan is to replace them with a better speaker that places a higher emphasis on home theater than music. also wanted to possibly replace the subwoofer in the classic 4's with daytons powered by behringer amplifier. does any of this sound like a good idea or should i just replace everything with what it came with from the factory. thanks for the help
XXXtraanchovie is offline
Old 04-19-2017, 10:41 AM
Rowan611's Avatar
Quoted: 258 Post(s)
Liked: 286
Honestly, I have to ask. Why are they dry rotting? Those aren't old speakers. And, NHT is good stuff. I have speakers that are decades older with no rot. So, what's the story?
HT: Marantz 7702mkII | Crown Amps | Volt 8s | THTs | 1200Ds | Panamax 5300PM | LG OLED 65B6P | Oppo UHD-203 | PS4 |
Family: Pioneer SP-SB23W | Pioneer Kuro Elite 111 | X1
1299 build on standby
Rowan611 is online now
Old 04-19-2017, 10:50 AM - Thread Starter
not sure if its an environmental issue, negligence (i dust the cabinets but maybe should have oiled rubber?), humidity
Old 04-19-2017, 11:02 AM
Rowan611's Avatar
Quoted: 258 Post(s)
Liked: 286
Environmental? Do you live in a desert area? I had a whole NHT Classic theater years ago. I also craved a system more geared towards HT. If I knew then what I know now, I would have built my own speakers. This is what I recommend to you.
mikeTRON250LM likes this.
Old 04-19-2017, 12:39 PM - Thread Starter
upstate new york. just theorizing? i also have the complete line up with controller and power amp 5. should i replace speakers with original factory equipment or should i upgrade to something different? if so, any suggestions?
Old 04-19-2017, 12:45 PM
asarose247's Avatar
Quoted: 748 Post(s)
Liked: 526
you need to list a few more details of current setup
and a proposed budget. .
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: F4Q4LP , RL/RR: F-3, TF/TR: Volt 6's TM: SLX
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is offline
Old Yesterday, 05:45 AM
Rowan611's Avatar
Quoted: 258 Post(s)
Liked: 286
I'd upgrade. To really help we would need a budget and more info about your setup. Listening habits (volume, room size, etc).
Old Yesterday, 07:06 AM
rhodesj's Avatar
Quoted: 900 Post(s)
Liked: 496
Replacing the drivers may be non-trivial. Finding ones that fit the existing cabinet without heavy modification can be a challenge, and then it's often necessary to redesign the crossover as a different driver will likely have different response.
How old are the speakers? Dry rot on surrounds isn't really that common on modern-built drivers...
rhodesj is online now
Old Yesterday, 09:52 AM
Rowan611's Avatar
Quoted: 258 Post(s)
Liked: 286
They're probably less than 15 years old. I bought mine in 2001 or 2002. I think he has the newer ones.
Typed on a tiny keyboard, excuse any typos
Old Yesterday, 03:46 PM - Thread Starter
speakers were purchased around 2005 i'd guess. not all of them have dry rot but the center and both rear do. room is 1300 square foot A - frame house with roughly a 30 foot ceiling.
budget wise, im trying to keep it under $2500. my plan is to just replace the subwoofer, lower mid range 6.5" anodized aluminum cone and keep the tweeter and midrange. (not sure if that makes any sense)
heres some information on found on the classic 4 that i dont know how to use because im not smart:
System Type: Tower speaker
Configuration: 4-way bass reflex
Woofer: 1 x 10" anodized aluminum cone woofer
Lower Midrange: 1 x 6.5" anodized aluminum cone, long throw design
Midrange: 2" anodized aluminum dome midrange
Tweeter: 3/4" anodized aluminum dome tweeter
Frequency Response: 27Hz - 20kHz
Crossover Frequency: 125Hz, 800Hz, 3.2kHz
Crossover Slopes: 12dB LP, 12dB HP 12dB LP, 12dB HP, 18dB LP, 18dB HP
Sensitivity: 86dB (2.83v@1m)
Impedance: 6 ohms nominal
my current subwoofer is an epik conquest powered by behringer inuke3000dsp. ideally, the subwoofer in the classic 4 i want for midrange bass. again, thanks for any and all help
Old Today, 12:34 PM
Quoted: 316 Post(s)
Liked: 222
Can you get direct replacement drivers from the company ?
I am sure that would be ideal, or even recomended replacements......?
Link to budget Home Theater build
http://www.avsforum.com/forum/19-ded...i-version.html
unretarded is online now
