How to "spread" bass? - AVS Forum | Home Theater Discussions And Reviews
 10Likes
  • 1 Post By Scott Simonian
  • 3 Post By Bill Fitzmaurice
  • 1 Post By asarose247
  • 1 Post By clientnumber9
  • 2 Post By 79horn
  • 2 Post By Bigus
post #1 of 15 Old Yesterday, 09:44 AM - Thread Starter
Liked: 0
In my room I have only one place a sub which is in the center of a wall. Being used for music only, I want to figure out how I can distribute the bass evenly from only one cabinet. I was thinking maybe daul opposed with the port facing forward has the best chance. What do you guys think? Also thinking of going with 2 18s like the HO or UM from Dayton.
Christopher Zandler 2 is offline
post #2 of 15 Old Yesterday, 09:45 AM - Thread Starter
Liked: 0
Forgot to mention that it's not dead center and I have a few feet of wiggle room.
post #3 of 15 Old Yesterday, 09:56 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5534 Post(s)
Liked: 4479
You will need more than one source of bass in order to "spread the bass around".
You will need more than one subwoofer.
mikeTRON250LM likes this.
Scott Simonian is online now
post #4 of 15 Old Yesterday, 09:57 AM
Bill Fitzmaurice's Avatar
Liked: 5145
Placed ideally the results can be OK, but with only one sub room mode sourced response humps and boundary reflection cancellation nulls will always be there. Two 18s in one cab will both excite the same modes and nulls. Put them in two cabs, and remove the phrase 'I can't' from your vocabulary. If size is an issue go with twelves or fifteens. Smoother response trumps higher output.
Augerhandle, Rowan611 and Purenv like this.
Bill Fitzmaurice is online now
post #5 of 15 Old Yesterday, 09:58 AM
johnson636's Avatar
Quoted: 245 Post(s)
Liked: 64
From what I gather, dual opposed is a sealed implementation and doesn't utilize ports. Will you elaborate? I'm just curious.
johnson636 is online now
post #6 of 15 Old Yesterday, 10:00 AM
Bass Enabler
Liked: 4479
Dual opposed is an orientation and not exclusive to sealed.
It is possible to have dual opposed orientation in any alignment.
The M.A.U.L. for example, is dual opposed with four drivers and it is a vented/bandpass alignment. Not sealed.
As is the new Skorn on Data-Bass.
post #7 of 15 Old Yesterday, 11:28 AM
johnson636's Avatar
Quoted: 245 Post(s)
Liked: 64
Learned something new today. Thanks for clearing that up Scott.
post #8 of 15 Old Yesterday, 12:24 PM
asarose247's Avatar
Quoted: 748 Post(s)
Liked: 526
Subs have been known to be seen lurking about, surreptitiously and beautifully disguised as end tables , coffee tables.
a rather well executed example would be an end table from @squire s007
also, and maybe even better for "just" music, the BFM Table Tuba
give them a look
Rowan611 likes this.
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: F4Q4LP , RL/RR: F-3, TF/TR: Volt 6's TM: SLX
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is online now
post #9 of 15 Old Yesterday, 12:45 PM
clientnumber9's Avatar
Quoted: 24 Post(s)
Liked: 45
Good advice for life and speaker building!
Brazle likes this.
clientnumber9 is offline
post #10 of 15 Old Yesterday, 01:41 PM
79horn's Avatar
Liked: 3
Yes sir I have an "end table" sub rite beside my easy chair, d.i. Y. Made by myself. 2.6 cubes net. Tuned to 38 Hz. 15" kicker driver. Works pretty well, but drops off about 34 Hz. Wanted to add a lil decoration so I went with a small engraved logo. It was a fun build.
79horn is offline
post #11 of 15 Old Yesterday, 03:36 PM
Bigus's Avatar
Quoted: 337 Post(s)
Liked: 338
Bass is best spread with a large butterknife.
Bigus is offline
post #12 of 15 Old Yesterday, 03:47 PM
torii's Avatar
Quoted: 911 Post(s)
Liked: 478
the more the merrier
and the bigger usually means the better
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5 Subs: Velodyne HGS 12, VA 1512, Rythmik FV15HP
torii is online now
post #13 of 15 Old Yesterday, 06:54 PM
jujuman200's Avatar
Quoted: 13 Post(s)
AS far as the woofers go....... the RSS460 is the choice for JUST MUSIC. It has much more finesse than the UM18. The UM18 is better suited for HT duty.
I have 2 RSS460 in full Marty cabs....... Awesome sauce.
Juju
jujuman200 is offline
post #14 of 15 Old Today, 09:54 AM
Quoted: 31 Post(s)
Liked: 64
The simple key is bigger is not better with what you want
You want consistency, put another sub in the back wall in the middle and you will likely be thrilled at the result.
RoboAVS is online now
post #15 of 15 Old Today, 10:09 AM
BassThatHz's Avatar
Quoted: 2128 Post(s)
Liked: 1715
You might have to implement 8 8's, the bigger the better...
4 dual-opposed 8's, one in each corner or wall.
One sub (of any size) won't smooth bass over a wide area. Only one seat, if lucky...
BassThatHz is online now
audio , Dayton , diy , subwoofer , ultimax
