Stereo Integrity HT-18 v2 18" available again May-23-2017 - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 258Likes
post #271 of 362 Old 07-24-2017, 05:33 PM
markg35's Avatar
Quoted: 47 Post(s)
Liked: 40
Originally Posted by unretarded View Post
Thanks, saves me from digging for that......and remindes me I forgot to ask them to include the gasket....
Gaskets are now extra!Ask me how I know....
unretarded likes this.
markg35 is offline
post #272 of 362 Old 07-24-2017, 05:52 PM
unretarded's Avatar
Quoted: 769 Post(s)
Liked: 688
How much ?
Link to budget Home Theater build
http://www.avsforum.com/forum/19-ded...i-version.html
unretarded is offline
post #273 of 362 Old 07-24-2017, 05:57 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5973 Post(s)
Liked: 5036
Most people aren't using them so...
It's easier not to include them from now on.
Scott Simonian is offline
post #274 of 362 Old 07-24-2017, 06:03 PM
unretarded's Avatar
Quoted: 769 Post(s)
Liked: 688
So they are basically ornamental ?
If so, then I am good, not going for cosmetics here.....
post #275 of 362 Old 07-24-2017, 09:13 PM
bgtighe23's Avatar
Quoted: 1662 Post(s)
Liked: 971
No, most people use a different type of gasket.
_____ _____ _____ _____ _____ _____ _____ _____
Receiver : Denon x5200
Front Stage : Martin Logan Motion 60XTs/Elac Debut F5 Center
Surround Speakers : HTD Level 2 and 3 Towers
Subwooferage : Dual UM-18s/6 SI HT18s
Born in 1995 and still continuing my HT journey
bgtighe23 is offline
post #276 of 362 Old 07-24-2017, 11:37 PM
bscool's Avatar
Quoted: 753 Post(s)
Liked: 590
I have used this https://www.parts-express.com/parts-...-roll--260-542 just beware for enclosures that flush mount the sub it can be a PAIN to get them out. Practically, glues them in
HTPC, Sony 40es, 120" Silver Ticket, 7702mkii, Sunfire Amp 225w, JBL 590, JBL 520
PSA XS30, Seaton Submersive, 2 Um-18 8cf sealed, Outlaw Ultra x 12, Kappa Pro 18LF, BFM Tuba 60 horn, B&C 18TBW100 6cf 41hz, 34hz, 28hz tune
iNuke 3000 & 6000 DSP's, Crowson Motion Actuator
bscool is online now
post #277 of 362 Old 07-25-2017, 06:38 AM
markg35's Avatar
Quoted: 47 Post(s)
Liked: 40
How much ?
I was quoted 20.00.
I built the new DIY Soundgroup SI flatpack.Without the gasket, there is a large gap.
The build I did,the gasket is ornamental.
I believe Erich is including the gasket in the flatpack kit!
Thank You Erich!
markg35 is offline
post #278 of 362 Old 07-25-2017, 08:47 AM
eng-399's Avatar
Quoted: 1744 Post(s)
Liked: 3004
eng-399 is offline
post #279 of 362 Old 07-25-2017, 09:53 AM
Erich H's Avatar
Quoted: 1493 Post(s)
Liked: 1902
Originally Posted by markg35 View Post
I was quoted 20.00.
Thank You Erich!
The first run of the Baltic birch cabinets comes with the gasket. I bought enough from Stereo Integrity and include them with the flat pack. I need to make a note about it only being with the first run though.
When they first came out I asked Stereo Integrity if these were the same diameter as the previous model and they thought I just meant the inner hole cutout. But the outer hole recess diameter is less because the new subs have a stamped frame and no gasket. Instead of getting new front baffles cut and repackage everything, the easiest fix was to just get the thick gaskets and include them with the flat packs.
The next run will not have them though.
Electrodynamic and K9woofer like this.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #280 of 362 Old 08-03-2017, 11:47 AM
Shreds's Avatar
Quoted: 401 Post(s)
Liked: 382
Originally Posted by eng-399 View Post
Hey guys I just cut a few circles out on my jasper jig with my router and the hole cut out that was 16 9/16 fit the best. I tried everything from 16-3/4th down.
Hey eng, after the route did the actual diameter of the hole end up being 16-9/16" too or was it a little bigger? The site says 16.7", that would be closer to a tad heavier than 16-11/16". The tighter the better though. Thanks in advance.
Shreds is online now
post #281 of 362 Old 08-03-2017, 12:34 PM
eng-399's Avatar
Liked: 3004
The sub was really snug with the hole cut out being 16-9/16. If you make it that size it's the tightest fit for that sub. You can try the next size down but there was no wiggle room left with the cut out being 16-9/16 so I think you would run into a problem. This was cut again with my Bosch router using a jasper jig and 1/4 cut bit for it. Hope this helps.
brettus, Shreds and unretarded like this.
eng-399 is offline
post #282 of 362 Old 08-03-2017, 12:57 PM
unretarded's Avatar
Quoted: 769 Post(s)
Liked: 688
I marked 11/16ths and cut the line which ended up closer .750 and there seemed to be plenty of room on mine.....my best guess is the 11/16ths number has maybe a 1/8th inch of clearance/room built into that measurement......1/16 clearance all the way around or 1/8th total.
Shreds likes this.
post #283 of 362 Old 08-12-2017, 03:43 PM
biga6761's Avatar
Quoted: 42 Post(s)
Liked: 74
I broke out both of the V.2's I picked up a few weeks ago today for some free-air/break-in fun with my Inuke 6k. I ran thru some tones and sweeps with REW then a few Bassotronics tracks just playing around and prob got to about 3/4 Xmax or so. Both drivers were strikingly smooth and quiet to as far as I was comfortable pushing things.
It really is insane IMHO that you can buy this much driver for this kind of money.
@Electrodynamic you have outdone yourself sir......again. In today's $ I don't know how you could beat the deep bass value on tap in the Ht-18 v.2
Thank you Nick for all your DIY community support and world class products.
I would not have the system I do today or will tomorrow(once I build the new enclosures) without the original Ht-18 or the V.2!
Panasonic PT-AE4000 100" 16:9 125" 2.35:1 - Xbox One S - Philips BDP7501 UHD
Marantz av7702 - 2 Crown Xls 2000 - 1 Crown Xls 1500 - 1 Qsc rmx 850 - 2 Inuke 3000dsp -
Speakers= 5.1.4 Atmos NHT's} 2 _ 2.9's - 2 _ Sb 3's - 1_ Ac-2
Subs= 1 Si HT18 D2 Stonehenge - Full Marty UM18-22 - 2 Buttkicker LFE's -
biga6761 is offline
post #284 of 362 Old 08-14-2017, 03:35 PM
sotwell's Avatar
Quoted: 102 Post(s)
Hey guys, I just ordered 2 HT18s and should receive them tomorrow and i just built 2 martycubes. Please validate my setup as these will be added to my existing 2 subs. Upfront in my theater i have dual SVS PC13 ultras (required due to small footprint) connected to my Denon 6200 which has audyssey multieq xt32 which has dual sub outs. I will use a Y spliter and run my 2 SVSs to sub out 1. For my SI HT18 martycubes, I am planning on getting a Crown XLS 2502 and will connect to the Sub 2 out from my Denon and split into Input 1 and Input 2 for the Crown. I will then wire the HT18s in Stereo. Prior to Audyssey I will level set the trim for each sub then run Audyssey xt32. Is this plan sound? Thanks!
sotwell is offline
post #285 of 362 Old 08-21-2017, 02:46 PM
biga6761's Avatar
Quoted: 42 Post(s)
Liked: 74
So I'm sitting home in my media room yesterday watching Game of Thrones when I get a text.
The guy I bought the 2-1 month old Ht-18 V.2's from a couple weeks back says he is in the middle of moving and if I wanted the other 4 drivers( he had 6 total in a sport utility but decided to abort) he would make me a hell of a deal.
I only payed him $200 for the first 2 and I can't really afford to buy them right now (even though I'd crawl to him on broken glass for them) I said "What kind of deal"??......UHhhh all 4 for $300.....YES PLEASE!!!!!! (All 6 for $500 total)
Needless to say at noon today I was in a parking lot meeting him with the money. Got'em home just in time for the eclipse.
Gotta love when the Sun, Moon, and Subwoofer Gods all align on the same day. Can you say once in a lifetime????
Anyway working on building out my new room at our new place. So if I can ever get all the enclosures done.....10-18's ( 8 of which are ht-18's) will drive the new 3100 cuft. all concrete and block space. Will prob add a Clone for power before christmas.
I'm building 2 platforms (with 4 Buttkickers) one with a riser for 2 rows of seating and putting up my first PJ with a drop down AT screen so I can keep my 4k LG for everyday viewing.
Best of all this new room is detached from the house so I can make all the waves I want while my lady sleeps. Oh joyful day.
filtor1, bscool, eng-399 and 1 others like this.
biga6761 is offline
post #286 of 362 Old 08-21-2017, 03:09 PM
markg35's Avatar
Quoted: 47 Post(s)
Liked: 40
^^^^^WOW!!! Great Score! Congrats!
biga6761 likes this.
markg35 is offline
post #287 of 362 Old 08-21-2017, 03:10 PM
corradizo's Avatar
Quoted: 1182 Post(s)
Liked: 891
corradizo is offline
post #288 of 362 Old 08-21-2017, 03:52 PM
coolrda's Avatar
Quoted: 1086 Post(s)
Liked: 992
Attaboy!
coolrda is offline
post #289 of 362 Old 08-21-2017, 06:13 PM
biga6761's Avatar
Quoted: 42 Post(s)
Liked: 74
Originally Posted by corradizo View Post
Moarrrr. Congrats!
Lol, love this. I think I just found my next Tattoo. LMAO
uuhhaa..Don't Shoooot da chappa....uuhhaa (in best Arnold voice)
corradizo and unretarded like this.
biga6761 is offline
post #290 of 362 Old 09-19-2017, 04:03 PM
Quoted: 96 Post(s)
Liked: 27
sooo i nuke 3k or 6k for running two of these?
NickyB210 is offline
post #291 of 362 Old 09-19-2017, 08:19 PM
bgtighe23's Avatar
Liked: 971
3k. One per channel.
If you think in the slightest you might get 4 ht18s down the road, get the 6000DSP.
post #292 of 362 Old 09-19-2017, 10:17 PM
unretarded's Avatar
Quoted: 769 Post(s)
Liked: 688
I am running one off a inuke 1000dsp and it sucks up everything it can output at approx. 660 watts bridged..........I would like to feed it more power but the inuke is maxed out......
I would go for the 6000 anyway....what is it like 50 bucks difference from the 3000....
With the 1k it is maxing the amp all the time, be nice to have the 3000 for just a single...
post #293 of 362 Old 09-19-2017, 10:29 PM
Quoted: 26 Post(s)
Liked: 5
I have the 3000 non dsp with no limiter and I think it's perfect. I think this driver loves power. I haven't been able to bottom it out!
So I would definitely go with the 6000 for two of the Ht18s
biga6761 and unretarded like this.
Cnguyen1127 is offline
post #294 of 362 Old 09-20-2017, 06:31 AM
Quoted: 96 Post(s)
Liked: 27
I have a baby on the way so I know I wont be adding any more subs in the foreseeable future, wife is barely letting me put 2 marty cubes as is lol
post #295 of 362 Old 09-20-2017, 06:41 AM
bgtighe23's Avatar
Liked: 971
If you're going with a ported box, you need to make sure you have the DSP version of the amp you end up choosing.
post #296 of 362 Old 09-20-2017, 06:57 AM
Quoted: 96 Post(s)
Liked: 27
More than likely I will go sealed boxes. Unless ported has crazy benefits.
post #297 of 362 Old 09-20-2017, 09:58 AM
corradizo's Avatar
Liked: 891
As a sealed owner I would say that unless you plan to build a bunch of sealed go ported. Sealed will yield a smaller, simpler box and give you more below 15hz (requires multiples to achieve high spl below 15hz). Ported will give you much more at 15hz (essentially near tune). Problem I had was I thought lower is better but didn't know it would take a whole bunch of 18's to really chase going below 15hz. If I could do it again, assuming I had the room, I'd build ported boxes. I'm not going to be able to afford chasing sub 15hz content, (though I have experienced it before) so I'd rather get a crap load of 15hz and above as I'm limited to 2 to 4 18's.
post #298 of 362 Old 09-20-2017, 12:19 PM
bgtighe23's Avatar
Liked: 971
Unless you're going very large sealed, I would suggest LLT ported (large low tuned). I suppose it depends on output needs, but the new V2 HT18s aren't really going to like 4 cu ft sealed.
Personally with this driver, I see crazy benefits going ported.
If you're going for large output on a small budget, then ported is the way to go. If you're just looking for clean output at moderate output levels, go sealed.
post #299 of 362 Old 09-20-2017, 12:22 PM
Quoted: 96 Post(s)
Liked: 27
I plan on making marty cubed for these babies. Ordered the subs earlier today. Hopefully get the boxes cut and put together this weekend.
post #300 of 362 Old 09-20-2017, 12:32 PM
bgtighe23's Avatar
Liked: 971
Good choice,
Be sure to share lots of pics!
