Stereo Integrity HT-18 v2 18" available again May-23-2017 - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 82Likes
Old 05-09-2017, 03:35 AM
PsychoM3's Avatar
Quoted: 396 Post(s)
Liked: 341
Originally Posted by Augerhandle View Post
I'm pretty sure Lukeamdman and notynt never tested the 3000. All I can find on teslaman is his classified ad. [EDIT: I found where teslaman tested the 6000, not the 3000] DIY audio lists some numbers ("power output was pretty darn close to..."), but no test results. Lots of info on the 6000, but not the 3000. Maybe you could help me out with some links? Thanks.
Sorry, I assumed you knew the architecture of the iNukes
The key is a 6000 is essentially two bridged 3000s under the hood and a NU-4 6000 is essentially two 3000s in the same case. This is the reason the 6000 is not 2 ohm stable and can't be bridged since it is already a bridged 3000 on each of the two channels. Lukeamdman's tests of the NU-4 give you the information you need for the 3000.
PsychoM3 is offline
Old 05-09-2017, 05:36 AM
Liked: 1
Originally Posted by PsychoM3 View Post
I got you. That is just the quoted specs, tests show what they can actually do, my numbers are based on actual tests of the amps.
Got you, I thought we where talking quoted specs. I know that tests have shown the inukes arent running as hot as advertised. I just bought 2 of the new ones and plan on running them each at 4ohm to one channel of the inuke 3000. Plan on putting them in a MArty cube most likely.....Thoughts??
Brazle likes this.
Ryan White is offline
Old 05-09-2017, 06:06 AM
Nima's Avatar
Quoted: 89 Post(s)
Liked: 112
Does anyone know how much shipping to Europe (Germany) would be?
Nima is online now
Old 05-09-2017, 06:22 AM
STL D's Avatar
Quoted: 286 Post(s)
Liked: 286
http://www.diyaudio.com/forums/class...surements.html
STL D is online now
Old 05-09-2017, 06:39 AM
klipsch's Avatar
Quoted: 189 Post(s)
Liked: 96
Sign me up as another requestor of dual 4 ohm option ... I"ll take 4 @ $150 to add to the 8 HT18v1s dual 4 ohm I already have ... @Electrodynamic
2 HT18 dual 4 ohm drivers in dual opposed boxes off of 1 channel of inuke 6000 = great bass per $
klipsch is offline
Old 05-09-2017, 11:04 AM
Augerhandle's Avatar
Quoted: 811 Post(s)
Liked: 707
Originally Posted by frenchfries View Post
6000 is literally two bridged 3000s. Extrapolate from there
Sent from my ASUS_Z017DA using Tapatalk
I've been extrapolating, that's the point. Thanks anyway.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
Old 05-09-2017, 11:06 AM
Quoted: 811 Post(s)
Liked: 707
I understood that, but thought there might be differences in power supplies. Thanks.
Old 05-09-2017, 11:07 AM
Quoted: 811 Post(s)
Liked: 707
Originally Posted by STL D View Post
Thanks @STL D
Old 05-09-2017, 02:17 PM
Quoted: 410 Post(s)
Liked: 298
Given the 2 inuke amp options on these, is there really going to be any discernable difference at 30db below max db levels.
Is it as simple as I would just lose a few db of max headroom..........or is there other dynamics at play here.
Link to budget Home Theater build
http://www.avsforum.com/forum/19-ded...i-version.html
unretarded is offline
Old 05-09-2017, 02:25 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5637 Post(s)
Liked: 4596
Only the 6k is compatible with nearfield bass.
And the quads are better too.
Patzig and unretarded like this.
Scott Simonian is offline
Old 05-13-2017, 10:51 PM
LondonBenji's Avatar
Quoted: 133 Post(s)
Liked: 45
I am no sure where you go 680w you may have miswritten the Behringer spec of 880wpc @ 4ohms for the 3000. The 3000 with both channels driven will give you about 450wpc RMS so you are giving up a little, the 6000 will give about 1400 wpc @ 4ohms. The reason people were wishing for a 4 ohm version of the driver is wiring them for a 2 ohm load gets about 750 wpc RMS from a 3000 so you can fully drive 2 on a 3000 and 4 on a 6000, as it is you have to decide to give them less than full power with an iNuke 3000 or have power to spare with the 6000 and spend $120 more. In reality you are probably only giving up about 2-3dB with the 3000 and 2 v2 vs a 6000 and 2 v2.
According to these measurements, the iN3k is about on point for 600wrms with both channels driven:
Output Power:
No load max output voltage was 50Vrms per channel.
With resistive loads, power output at clipping was pretty darn close to:
300Wrms/8ohm/channel
600Wrms/4ohm/channel
1000Wrms/2ohm/channel
2000Wrms/4ohm/bridged
So that should put is right on the limit for the HT18v2, one per channel no? A iN6k should be able to run 4xHT18v2's with two in series on each channel, at roughly the same power going to each speaker it seems.
Or am I (probably) missing something?
LondonBenji is offline
Old 05-15-2017, 05:58 AM
klipsch's Avatar
Quoted: 189 Post(s)
Liked: 96
I believe the new 18v2 is a dual voice coil driver, just like the v1; there will be 4 wiring terminal posts per driver which create 2 2 ohm connections per driver.
One of the reasons the Dual 4ohm option of v1 was popular is that you could present a 4ohm load of 2 drivers to 1 channel of the inuke6k ...
klipsch is offline
Old 05-15-2017, 08:04 AM
Dr.Evazan's Avatar
Quoted: 44 Post(s)
Liked: 61
these 150$ drivers are making me regret the purchase of my UM18-22's...
infinity06 likes this.
Dr.Evazan is offline
Old 05-15-2017, 09:58 AM
neo_2009's Avatar
Quoted: 108 Post(s)
Liked: 63
@Electrodynamic , could you please inform me what are the packaging dimensions of the new HT-18 V2?
neo_2009 is offline
Old 05-15-2017, 10:01 AM
markg35's Avatar
Has anyone heard when these will ship?
markg35 is offline
Old 05-15-2017, 05:46 PM
Hoodcom's Avatar
Quoted: 120 Post(s)
Liked: 81
I finally decided to place an order for a couple of these, they'll make for great near field drivers in an enclosure I'll be building for them.
Now I just need to pick which iNuke to go with.
unretarded likes this.
Hoodcom is online now
Old 05-15-2017, 08:16 PM
Brazle's Avatar
Quoted: 106 Post(s)
Liked: 130
That seems like a great plan to me.
HT setup: Vizio 50" 4K | Xbox & PS3 | Pioneer Elite VSX-94TX | Bose 701 towers (V1) | JBL S Center | Def Tech Reference SuperCube & Def Tech PF15TL+
Brazle is offline
Old 05-16-2017, 09:34 AM
bscool's Avatar
Quoted: 242 Post(s)
Liked: 113
Not sure how accurate WINISD is but it looks like it takes around 1200watts to get these close to xmax. 600watts gets around 14mm xmax in 4cf and in a ported enclosure depending on size and tune.
I think it is better to have more power and not need it than to run something like a inuke 3000 on the ragged edge. For one if you want a quite amp the less your pushing it the less strain and heat and slower fans speed etc. That is how I look at it anyway. But it also looks like you are leaving a decent amount of output untapped if you need it going with the 3000 since you are barely using half of the subs xmax.
Edit, added graph comparing output in 4cf sealed at 600w vs 1500w which pushed it close to xmax. Looks like around 4db left used by going with the 3000 vs 6000 if WINISD is accurate and I have everything entered correctly. If someone already posted these comparisons I might have missed it as I read so many threads on this board
ID:	2139858   Click image for larger version
LondonBenji likes this.
HTPC, Sony 40es, Marantz 7702mkii, Sunfire Cinema Grand 225w x 5, JBL 590, JBL 520
PSA XS30, Seaton Submersive, 2 Um-18 8cf sealed, Outlaw Ultra x 12, Kappa Pro 18LF, BFM Tuba 60 horn, B&C 18TBW100 6cf 41hz, 34hz, 28hz tune
iNuke 3000 & 6000 DSP's, Crowson Motion Actuator
bscool is online now
Old 05-16-2017, 11:06 AM
biliam1982's Avatar
Quoted: 427 Post(s)
Liked: 215
Are you just speaking theoretically about giving it 1200 watts? I see a lot of people mention powering it with much more than it's rated 600 watts RMS. Won't that damage it long term if fed continuously like some movies do?
biliam1982 is online now
Old 05-16-2017, 02:12 PM
kaiforce's Avatar
Quoted: 106 Post(s)
Liked: 129
I've been running mine with an 1100watt limiter for months with no ill effects. Lots of movies and dubstep with constant sine waves.
Brazle likes this.
kaiforce is offline
Old 05-16-2017, 02:30 PM
Quoted: 410 Post(s)
Liked: 298
I think it would be hard to cook one of these under normal movie watching levels, unless you were working on becomes deaf.
IME, I have seen speakers fried by cranking up the volume quickly with way too many watts used to a level that could only be endured for seconds...or under powered/over driven speakers driven at crazy levels for hours on end at a large party.
I have seen lots of tweeters give up the magic smoke.
My cheap subs running at demo levels for MMFR held up, they started getting a slight wire coating smell towards the end.....but that was at crazy levels for a very long time and a epic soundtrack of non stop thunder at a crazy listening level that made m ears ring loud for a hour after the movie was over.
I wanted to test my system while it was still new and under warranty.........the reciever was smokin hot and so were the plate amps as I am sure were the mains........
Sure it is possible, but no matter how many watts you feed it, it will only use whats needed to reach X volume.......other than demo`s, the ears usually submit before the woofer.
I have seen speakers endure crazy abuse and seen a few pop for no reason.......they really are a wear item like tires on a car, it amazes me any of them hold up as long as they do given the constant movemet they endure for hours on end.
I wonder what produces more heat on the voice coil....under powered with loss of control/over driven or pumping max rated watts while still in control of the cone.......?
My guess is over driven without enough watts to control the speaker.....I have no idea, but thats my guess.
Old 05-16-2017, 08:12 PM
Craig S King's Avatar
One on one, any ideas how these subs would compare to the Dayton Audio HO-18? For listening to music purposes?
Craig S King is offline
Old 05-16-2017, 09:33 PM
bscool's Avatar
Quoted: 242 Post(s)
Liked: 113
I would literally run that much or more and back off if it makes bad noises I am not saying someone else should do it, that is up to them to decide or ask Nick for his input on how much power they can take in the actual box/application the person is using.
I have never had any problems running more power to subs than they are rated for. I have probably had some luck and had subs that could take it(also ran enough subs that they weren't constantly needed to be ran 100% wide open to get the output I wanted). I also don't sit there playing sine waves thru my subs. For music and most movies, it is fairly short bursts on and off.
Probably one of the more extreme movies that I can think of is EOT intro scene, maybe there are other movies that are harder a sub, I really don't know. I suppose some music that has basically test tones or long drawn out constant bass could damage a sub when running too much power but it comes down to you have to know the limits of your equipment and how to set things up to prevent damage or minimize it.
Anyway, I just brought it up because I was checking what it was showing for xmax at 600watts in 4cf and looks like it takes at least 2x rated RMS to even get close to xmax so there is a lot left in the tank only feeding these with a single channel of an Inuke 3000 in my opinion. At least if the model is even close to accurate.
Old 05-16-2017, 11:34 PM
alamez's Avatar
Quoted: 45 Post(s)
Noob here. Sorry but I'm confused. So how many of these can I run with a nu3000dsp? And how many with the nu6000dsp
alamez is offline
Old 05-17-2017, 12:41 PM
Quoted: 133 Post(s)
Liked: 45
Yes, the question was more around the fact that a measured iN3k could actually match the necessary 600wrms per channel for two v2s and an iN6k could match the 1200wrms per channel for four v2s.
Old 05-17-2017, 01:56 PM
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
Geez, great bass for a great price is back!
I have 8 D4 V1s hanging around in the original boxes, unopened doing nothing, but I don't want to let them go. They're overbuilt and I'll hang on to them. Bought 2 DS4 and THOSE rock! Now, the V2s are out at a great price...
Nonononononono....
Panasonic AE-2000, Carada BW 120", Paradigm Studio 40v3 x 2, Paradigm 690v4, Paradigm ADP 470v3 (rears), Micca M-8C x 4, Volt 6 x 2 (SR), SI DS4-18 in 12cuft X 2, Marantz 7702MKII, OPPO 103D, Emotiva XPA-3,
vitod is offline
Old 05-17-2017, 02:21 PM
Quoted: 410 Post(s)
Liked: 298
The IN6K 4u looks interesting, too bad I did not see a dsp version......but a 2x4 dsp solves that easily.....
Old 05-19-2017, 01:11 PM
xFreshEntrailsX's Avatar
Quoted: 60 Post(s)
Liked: 391
Ordered 2 of these yesterday. Going to put them in seperate sealed cabinets in a 1,200cubic ft room. Looking for a good deal on an inuke 6000dsp or may just do the 3000dsp.
xFreshEntrailsX is offline
Old 05-19-2017, 03:46 PM
K9woofer's Avatar
Quoted: 63 Post(s)
Liked: 38
The 3000 will only give a pair of these 500w each.
bscool likes this.
K9woofer is offline
Old 05-19-2017, 05:57 PM
bscool's Avatar
Quoted: 242 Post(s)
Liked: 113
http://www.vipproaudio.com/behringer...interface.html
Use the 15% off coupon and free shipping. If the code won't activate once you are logged in call them. I think it comes to around $340 for the 6000dsp shipped. I would highly suggest the 6000 over the 3000. Always better to have a little more than you need that to be pushing the 3000 to its edge or into clipping. The new SI HT should be able to take a lot more than a DSP 30000 can give if the T/S parameters are accurate.
For example, go look at http://www.data-bass.com/data?page=system&id=90&mset=97 Stereo Integrity HT18D2 Sealed and how much voltage was needed to reach those numbers. That happening with a DSP 3000 and you won't even get that levels of output with a 6000dsp.
With the 3000 you would want to run the amp bridged to get more output but then that limits you from having seperated channels if you have the subs placed in locations that you need to set different delays with having them different distances from your listening position.
xFreshEntrailsX likes this.
