Stereo Integrity HT-18 v2 18" available again May-23-2017 - AVS Forum | Home Theater Discussions And Reviews
 223Likes
post #1 of 289 Old 05-04-2017, 09:09 AM - Thread Starter
filtor1's Avatar
Quoted: 190 Post(s)
Liked: 150
Although I am not in the market, it looks like these sold well enough that SI is receiving another production run of these at $149 shipped.
http://stereointegrity.com/product/ht18-v2-subwoofer/
In the event anyone is in need.
filtor1 is online now
post #2 of 289 Old 05-04-2017, 09:22 AM
notnyt's Avatar
Quoted: 2742 Post(s)
Liked: 2522
Lol, didn't see that coming 6 months ago.
filtor1 likes this.
notnyt is offline
post #3 of 289 Old 05-04-2017, 09:22 AM
uniquepattern's Avatar
Quoted: 723 Post(s)
Liked: 701
Whoo Hoo!
chadsmith013 likes this.
uniquepattern is offline
post #4 of 289 Old 05-04-2017, 09:22 AM
corradizo's Avatar
Quoted: 1141 Post(s)
Liked: 851
HT18 Dual 2 ohm voice coils
Re3.6 ohms
Fs21 Hz
Qes0.47
Qms3.9
Qts0.42
Le5.1 mH
Sd117841 mm^2
Vas299.3 L
Bl19.3
Mms416 g
Cms357.3
Sensitivity (1w/1m)89.7 db
Xmax22.5 mm
Sent from my SM-N900V using Tapatalk
corradizo is online now
post #6 of 289 Old 05-04-2017, 09:46 AM
Electrodynamic's Avatar
Quoted: 447 Post(s)
Liked: 673
Well we were talking about it six months ago so you should have seen it coming, haha.
Scott Simonian and filtor1 like this.
Electrodynamic is online now
post #7 of 289 Old 05-04-2017, 09:52 AM
tjcinnamon's Avatar
Quoted: 1190 Post(s)
Liked: 286
Re3.6 ohms
Fs21 Hz
Qes0.47
Qms3.9
Qts0.42
Le5.1 mH
Sd117841 mm^2
Vas299.3 L
Bl19.3
Mms416 g
Cms357.3
Xmax22.5 mm
I have the worst luck entering in SI drivers. What order did you enter them in.
I tried: Qes, Qms,Vas, Fs, Re,Le,Sd, Xmax, Pe.
Then tried: QMS, MMS, CMS, RE, BL, LE, SD, XMAX, PE
Each time the other non-calculated parameters were way out of whack.
Marantz 7010 for 7.2.4
2 x Paradigm Prestige 75F's
1 x Paradigm Prestige 55C
8 x Paradigm CI Pro P65-R's
Sub 2 x Rythmik LVX12's
TV: LG 65B6
tjcinnamon is online now
post #8 of 289 Old 05-04-2017, 09:53 AM
Hoodcom's Avatar
Quoted: 122 Post(s)
Liked: 82
Oh cool, I'm honestly tempted for a couple of these, especially for a nearfield setup.
Especially after seeing a lot of builds involving their drivers.
Hoodcom is offline
post #9 of 289 Old 05-04-2017, 09:53 AM
bgtighe23's Avatar
Quoted: 1595 Post(s)
Liked: 918
Originally Posted by uniquepattern View Post
Wow, don't bother trying to pre-order if your in Canada.... Sundowns site wants over $2k for shipping 8 of em up here.... Fed-Ex international econo....
Guess Ill have to call Nick if I want a few...
What about 4 UM-18s?
If ported, maybe the DCS450 over at PE would be a good option. Especially 8 of them.
Worried about how these will do sealed
bgtighe23 is offline
post #10 of 289 Old 05-04-2017, 09:57 AM
corradizo's Avatar
Liked: 851
This is my .wdr for use with WinISD 0.7.0.900
Rename to .wdr
File Type: txt SI HT18 v2 D2.txt (827 Bytes, 327 views)
post #11 of 289 Old 05-04-2017, 10:22 AM
tjcinnamon's Avatar
Liked: 286
Rename to .wdr
Odd that the CMS and MMS are no where near what is published.
TV: LG 65B6
post #12 of 289 Old 05-04-2017, 10:42 AM
gworrel's Avatar
Quoted: 367 Post(s)
Liked: 318
There is a help page link in the software that explains the order to enter the parameters:
The suggested procedure for entering driver parameters is following (check first that "Auto calculate unknowns" option is checked):
1. Enter Mms and Cms
This gives fs. If either is not available, then enter fs and other parameter.
2. Enter Sd, Bl and Re
Now, you should get all but Qms (and Qts), Vas. Please note that Vas may not match exactly what is specified by manufacturer, because exact value of Vas depends on environmental parameters. See FAQ.
3. Enter Rms or Qms.
Either one will do, although I tend to prefer Qms over Rms, because it can usually be measured in driver measurement procedures.
4. Enter Hc, Hg and Pe.
If Hc or Hg or either is available, then enter Xmax and optionally either Hc or Hg if available.
5. Enter number of voicecoils.
This procedure is most accurate. Also note that it also calculates true SPL (1W/1m) value. So it might not match the marketing SPL value, which is generally somewhat vague. Not in all cases, though.
6. Correct Znom, if necessary.
There seems to be a problem with Fs and CMS. When Fs is 21 as per spec, I am seeing a calculated value for CMS of 138.1. Everything else seems to match up. Be sure the units in Winisd are correct, which can be a problem when manufacturers don't specify, but if you get weird results, it is likely a units discrepancy. Just click on the unit description to change it.
tjcinnamon and Electrodynamic like this.
gworrel is offline
post #13 of 289 Old 05-04-2017, 12:17 PM
Quoted: 447 Post(s)
Liked: 673
We just fixed Mms and Cms as those were the same numbers from the previous driver. Numbers should match up much better now. My apologies.
tjcinnamon and uniquepattern like this.
post #14 of 289 Old 05-04-2017, 12:23 PM
Augerhandle's Avatar
Quoted: 858 Post(s)
Liked: 775
@Electrodynamic
Nick,
Any plans for a D4 version? I have an HT15 and an HT18, wanting to upgrade the 15 to 18 without changing amps.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
post #15 of 289 Old 05-04-2017, 12:28 PM
Quoted: 447 Post(s)
Liked: 673
Originally Posted by Augerhandle View Post
@Electrodynamic
Nick,
These drivers are going to be Dual 2 Ohm.
Dual 2 Ohm for now. We will monitor interest for Dual 4's and go from there.
post #16 of 289 Old 05-04-2017, 01:42 PM
tjcinnamon's Avatar
Liked: 286
WOAH! WinISD defaults to 6 for sealed and 12 for vented. I can see how these differ from the HST18's. Likely box size and max SPL.
TV: LG 65B6
post #17 of 289 Old 05-04-2017, 01:44 PM
eng-399's Avatar
Quoted: 1642 Post(s)
Liked: 2767
eng-399 is online now
post #18 of 289 Old 05-04-2017, 02:28 PM
notnyt's Avatar
Liked: 2522
For some reason I derped and confused this with the ds4 18 lol. These going to remain in production a bit?
notnyt is offline
post #19 of 289 Old 05-04-2017, 03:57 PM
Quoted: 136 Post(s)
Liked: 54
Dude Fedex just delivered 4 PA 460 drivers yesterday for me. I guess I figured the si18 drivers were gone for good.
Anyway glad they are back and shipping. You are making some bass heads dream a reality.
jake515 is offline
post #20 of 289 Old 05-04-2017, 04:10 PM
corradizo's Avatar
Liked: 851
post #21 of 289 Old 05-04-2017, 04:11 PM
eng-399's Avatar
Liked: 2767
Jake 4 pa460's nearfield and 8 ht18v2's up front. Now we're talking!
filtor1 and chadsmith013 like this.
post #22 of 289 Old 05-04-2017, 04:13 PM
Johnny P's Avatar
Quoted: 72 Post(s)
Liked: 69
Ill bite. Ill get 2 of the SI 18v2 farfield in a cyclops enclosure and use the 3 PA460 nearfield and retire the INFINITYS.
ID:	2117473   Click image for larger version
Johnny P is offline
post #23 of 289 Old 05-04-2017, 04:36 PM
PsychoM3's Avatar
Quoted: 401 Post(s)
Liked: 347
And our first battle for bass for the dollar has presented itself. 2 SI HT18 vs. 3 Dayton PA460. Go!
If you consider a decent amount of box size say 30cuft total for the 2 or 3 drivers and tune the PA460 low (say 21hz) the 3 PA460s will equal or beat the 2 HT18v2s (tuned @ 14hz) from about 19hz up below that the SIs will have more output.
In the end it is mid-bass vs sub-sonic frequencies.
On the amplification side the DVC 2 ohm SIs don't match well with the Inukes (we are talking BUDGET here) since at 4ohms a side the 3000 can't fully power the HT18v2. If the SI were available with 4ohm VCs then I would probably call it the budget winner as it is they are a draw until one decides how much they value <20hz vs >40hz.
EDIT: just buy 2 of each, build and tune them where they are happiest and let them eat.
Scott Simonian and dRwOOD73 like this.
PsychoM3 is offline
post #24 of 289 Old 05-04-2017, 04:38 PM
eng-399's Avatar
Liked: 2767
post #25 of 289 Old 05-04-2017, 06:28 PM
EndersShadow's Avatar
Quoted: 585 Post(s)
Liked: 908
Curious, but where you live man?
My Setup | FS: Nothing right now
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is online now
post #26 of 289 Old 05-04-2017, 06:55 PM
Quoted: 447 Post(s)
Liked: 673
Yes sir. This new version is sustainable long-term.
post #27 of 289 Old 05-04-2017, 06:58 PM
Johnny P's Avatar
Quoted: 72 Post(s)
Liked: 69
I live way down in south Texas. McAllen,Texas. I have 6-1262ws. Im thinking of putting 2 in my living room down fire ported with an inuke 1k dsp. And the other 4. Well who knows. I have all the original boxes so i might just store them. You need some?
Johnny P is offline
post #28 of 289 Old 05-05-2017, 05:04 AM
chadsmith013's Avatar
Quoted: 1137 Post(s)
Liked: 1050
Originally Posted by eng-399 View Post
@chadsmith013 @EnderShadow s
Infinity's ...
thanks Mike...appreciate the looking out.
will keep my eye on them...i placed an order with amazon for 2 of them..previously it said 1-2 months until shipped, but the other day it was updated to say 2-4 weeks..I still have my doubts they actually have them, but i placed the order..will see what happens..
Receiver : Denon x2300
Front Speakers: 3 DIYSG Fusion 10's
Surround Speakers :2 DIYSG Volt 6's
Atmos Speakers: 2 DIYSG Volt 6's
Subwoofers : Dual Dayton HO 18's in sealed cabs w/Inuke 6000 DSP
chadsmith013 is offline
post #29 of 289 Old 05-05-2017, 05:53 AM
brian6751's Avatar
Quoted: 1114 Post(s)
Liked: 1102
Nick,
I think you should really consider a dual 4Ohm version. You could run 4 of them off one iNuke 6000dsp. That combo would make these the default bass per dollar champ IMO.
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is online now
post #30 of 289 Old 05-05-2017, 08:47 AM
Quoted: 136 Post(s)
Liked: 54
Jake 4 pa460's nearfield and 8 ht18v2's up front. Now we're taking
Its going to be a combo of 4 PA 460 in cubes and 4 si18 d4's in Johnnies with 88's for the LCR channels. This should get it done!
eng-399 likes this.
jake515 is offline
