Infinte baffle upgrade questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-19-2017, 11:19 AM - Thread Starter
Liked: 7
I recently upgrade my front and center to a cinema max 10 and a special 88 and figured I might as well upgrade
the subwoofers. I currently have the adire audio tempests and a behringer feedback pro. The tempests use a plate amp. I am upgrading to the Fi IB318. I will only be using two of them and plan on moving the tempests to another spot in the room. Would the crown xls 1002 be enough amp? I want something quiet. What ohm subwoofer should I get? Appreciate any help.
rykerjen is offline
post #2 of 2 Old 05-19-2017, 11:23 AM
Mr. Electric Wiz's Avatar
Quoted: 80 Post(s)
Liked: 40
What's the wattage on that amp, any the impedance of your FI's?
I'm running 4x FI 18"s (all 2 ohms) in series, two per channel on an iNuke 3000.
Perfect combination.
I live the low distortion of infinite baffle.
Mr. Electric Wiz is offline
