A Vulgar Display of Nearfield Power 6-15's Slot Ported at 12.86 HZ. - AVS Forum | Home Theater Discussions And Reviews
 343Likes
post #1 of 219 Old 05-24-2017, 09:31 AM - Thread Starter
eng-399's Avatar
Quoted: 1638 Post(s)
Liked: 2743
The Plan for this build is to have 6-15's nearfield slot ported about 1 inch away from my back and butt. I first started out with 4-12's nearfield then moved up to 8-12's sealed nearfield then the last build was 4-15's sealed nearfield and the bass was improved in each build. Now that I have 6-15 inch drivers which are 15'' Legacy Xtreme xd drivers I got from Parts Express when they had a buy out I can complete what I was thinking up.
The Plan is to have 2 boxes ''the wedge 2 box'' which will be a perfect fit to the shape of any Home Theater room chair. These will be slot ported to 12.86 hz and each box will be 10 cubic ft. The slot ports will be on the bottom facing the back of my chair. These boxes will take up every last inch of room I have back there lol.
The slot port is 2 inches wide with no divider down the middle and 48 inches long to help keep the air port velocity down. The amps that will be powering these subs are 3 inuke 3,000 dsp amps and all three will be bridged to power all 6 subs.
The paint I will use is duratex to finish these and a few coats of primer before hand.
Here's a few charts to show how these drivers look with the rest of my subs which a 4-21's slot ported to 15.5 hz.
Name:	21's and 15's all ported.png
ID:	2153146   Click image for larger version
ID:	2153426   Click image for larger version
ID:	2204889   Click image for larger version
ID:	2204897   Click image for larger version
sonichart, SBuger, esappy and 11 others like this.
eng-399 is online now
post #2 of 219 Old 05-24-2017, 09:31 AM - Thread Starter
eng-399's Avatar
Liked: 2743
post #3 of 219 Old 05-24-2017, 09:45 AM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
I like where this is heading.
gogunbaba, esappy and eng-399 like this.
gpmbc is online now
post #4 of 219 Old 05-24-2017, 09:48 AM
sonichart's Avatar
Quoted: 547 Post(s)
Liked: 454
Yea buddy!!
Can I request a Pantera concert demo upon completion?
STRONGER THAN ALL \m/
JVC RS600 ¤ 130" Wide Seymour XD 2.35:1
HTPC GTX1080 (MadVr) ¤ Zidoo X8 ¤ Oppo UHD-203 ¤ HDFury Linker
Denon x4200 ¤ Onkyo M5010 ¤ iNuke 3000 ¤ 7.2.2
sonichart is offline
post #5 of 219 Old 05-24-2017, 10:04 AM - Thread Starter
eng-399's Avatar
Liked: 2743
Originally Posted by sonichart View Post
Yea buddy!!
4 sure Phil we can play many tracks in the room. The thread name was thought up after listening to the vulgar display of power album my thoughts were violent bass hitting the back of my seats.
sonichart, corradizo and Purenv like this.
post #6 of 219 Old 05-24-2017, 10:26 AM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
Will these cover the same range as your front subs or are you going to low pass them differently?
gpmbc is online now
post #7 of 219 Old 05-24-2017, 10:37 AM - Thread Starter
eng-399's Avatar
Liked: 2743
My plan is to have these the same range as the front subs. I've played around with different ranges like 35-80hz and so on but I personally like covering 10-80 hz. the best nearfield anddoesn't seem distracting to me like this. I'll do the same test once this build is done and go from there. This box is a little hard to build having the slot port in front but I'm sure I'll work through it. I'm excited to finally have a ported box nearfield instead of sealed!
On another note since they were buy out drivers I modeled the um18-22 and the new HT18V2 sub for this box and it will work out with the same size port. All I'll need to do is cut the hole bigger for the driver and install it. I tried to future proof this build the best I can in case I blow a driver.
hd0823 likes this.
post #8 of 219 Old 05-24-2017, 10:39 AM
Quoted: 35 Post(s)
I freakin love the name of this thread! My only wish is that I was anywhere near you to hear your room. You seem to come up with some of the best ideas. Cheers sir!
eng-399 likes this.
Purenv is offline
post #9 of 219 Old 05-24-2017, 10:52 AM
Quoted: 48 Post(s)
Liked: 109
After this build there has to be a way to infinite baffle the entire house to the theater
I was fortunate enough to get a demo of the 4 sealed Legacy's which was fantastically awesome and I can only imagine putting those bombs into 10cft ported boxes. I have them in 4cfters and they are monsters just like that. The high Le in these drivers should go a long way towards creating a major tactile earthquake, I know they have a bit of a rising response which is perfect for this purpose.
Good luck, not that you'll need it. Well maybe stuffing those into that back row will be a challenge. You sure the risers are up to the challenge....
eng-399 likes this.
RoboAVS is offline
post #10 of 219 Old 05-24-2017, 12:41 PM - Thread Starter
eng-399's Avatar
Liked: 2743
My first nearfield to the latest nearfield setup and where this is all going.
The driver being used in his build 6-15's
The first nearfield setup 4-12" infinity 1260's
2nd nearfield setup 8-12" infinity's 4-1260's/4-1262's 8 total sealed
3rd nearfield setup 4-15's sealed same driver as this build.
uploads.tapatalk-cdn.com/20170524/331a9c22dbe54e772ebffeffe5402790.png[/IMG]
The 3rd nearfield setup had more low bass and the same amount of midbass so it was a win win for that install. Now that I'm doing 6 of these drivers ported I will gain a lot more bass and headroom.
Behind the screen up front as seen before.
post #11 of 219 Old 05-24-2017, 12:41 PM
OJ Bartley's Avatar
Quoted: 249 Post(s)
Liked: 345
Dude, just give me 5 Minutes Alone with your system and I'll be a happy man. Lol.
Sent from my LG-H812 using Tapatalk
esappy, filtor1, JCJetta and 3 others like this.
OJ Bartley is offline
post #12 of 219 Old 05-24-2017, 12:42 PM - Thread Starter
eng-399's Avatar
Liked: 2743
post #13 of 219 Old 05-24-2017, 01:33 PM
Quoted: 630 Post(s)
Liked: 486
OH yeah !
filtor1, JCJetta, andyc56 and 3 others like this.
Link to budget Home Theater build
http://www.avsforum.com/forum/19-ded...i-version.html
unretarded is online now
post #14 of 219 Old 05-24-2017, 03:16 PM
SpinMonster's Avatar
Quoted: 260 Post(s)
Liked: 111
That looks like a nice massage system. I hope all is well.
Isn't the port configuration using that narrow a dimension (2") with a long 48" dimension causing a lot of flow issues? I thought the rule of thumb was to have at least 1" per 12" LxW.
I hope you have another GTG so I can get ideas for a more finished theater when I upgrade houses next summer.
tjcinnamon likes this.
SpinMonster is offline
post #15 of 219 Old 05-24-2017, 03:26 PM
brazensol's Avatar
Quoted: 179 Post(s)
Liked: 48
I like what your doing here and am considering something similar. Will your bass modules make tuning the room easier or harder? How much of the bass "feel" would you lose if you were to incorporate those subs (the lower 4) directly into the riser? This would put them ~6" from the back of the seats. For my second row I was thinking putting one sub beneath each seat flush with the riser platform. It would look something like this with the dotted line being sub locations;
Name:	Subs in Riser.PNG
brazensol is offline
post #16 of 219 Old 05-24-2017, 04:28 PM - Thread Starter
eng-399's Avatar
Liked: 2743
I wanted to make the port wider to at least 2.5-3 inches to help with the port velocity but due to the room I have behind my seats I couldn't go that big and the only way to fit 3-15's in a box was the way I have the port planned out. I taped the box out on the ground to and tried every different way so basically the port is on one side of the box and and runs along the back side of it. Once I get further along it will all make better sense.
This is another reason why I have such a low tune to the box I need to get the air port velocity down and making it longer helped...hopefully it won't make things worse.
post #17 of 219 Old 05-24-2017, 05:14 PM
derrickdj1's Avatar
Quoted: 982 Post(s)
Liked: 714
Very catchy, a vulgar display of power, lol. This reminds me of a movie.....
eng-399 and k1n3t1k like this.
derrickdj1 is offline
post #18 of 219 Old 05-24-2017, 06:20 PM
esappy's Avatar
Quoted: 200 Post(s)
Liked: 150
To this day, still one of my all time favorite albums! \m/
Glad to see you are finally able to get to use these things. Looking forward to your impressions when it is done! I have a feeling you will be like
"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors." - Plato
esappy is offline
post #19 of 219 Old 05-24-2017, 06:26 PM
esappy's Avatar
Quoted: 200 Post(s)
Liked: 150
This should take the tactile response to A NEW LEVEL! His power grid is going to be screaming "I'M BROKEN!"
JCJetta, OJ Bartley and eng-399 like this.
esappy is offline
post #20 of 219 Old 05-24-2017, 06:53 PM - Thread Starter
eng-399's Avatar
Liked: 2743
post #21 of 219 Old 05-24-2017, 07:09 PM
N8DOGG's Avatar
Quoted: 1105 Post(s)
Liked: 1202
You better hope the subs don't start screaming "Im broken" lol
esappy, JCJetta and eng-399 like this.
N8DOGG is online now
post #22 of 219 Old 05-24-2017, 07:54 PM
corradizo's Avatar
Quoted: 1138 Post(s)
Liked: 843
corradizo is online now
post #23 of 219 Old 05-24-2017, 08:35 PM
Brazle's Avatar
Quoted: 113 Post(s)
Liked: 138
You had me at "vulgar" hehe.
Are there any subs available today that are comparable to those Legacy's? Man those things are beefy. Very nice.
eng-399 likes this.
HT setup: Vizio 50" 4K | Xbox & PS3 | Pioneer Elite VSX-94TX | Bose 701 towers (V1) | JBL S Center | Def Tech Reference SuperCube & DIY Nearfield cabinet ported UM18 dual ported PA380 ULF+MBM
Brazle is offline
post #24 of 219 Old 05-24-2017, 09:54 PM
Shreds's Avatar
Quoted: 360 Post(s)
Liked: 311
Just gotta say: one of the coolest thread titles ever and a really fun looking project. Your theater will be a unique experience, well done.
eng-399 likes this.
Shreds is online now
post #25 of 219 Old 05-24-2017, 10:48 PM
notnyt's Avatar
Quoted: 2717 Post(s)
Liked: 2505
where was subwoofers from hell?
notnyt is offline
post #26 of 219 Old 05-25-2017, 01:59 AM
chrapladm's Avatar
Quoted: 931 Post(s)
Liked: 348
Man those are some good looking 15's. Wish I was able to by them and be living i the USA. Too bad Nick didnt keep making his HT 15's. This looks like it will be another amazing addition.
eng-399 likes this.
chrapladm is online now
post #27 of 219 Old 05-25-2017, 06:45 AM
JCJetta's Avatar
Quoted: 176 Post(s)
Liked: 257
You serve too many [subwoofer] masters, Mike.
While I RE... SPECT... the whole idea, I think I'll WALK myself out of this thread.
JCJetta is offline
post #28 of 219 Old 05-25-2017, 06:45 AM
Quoted: 35 Post(s)
If @eng-399 plays Pantera at max volume he might just end up being buried behind "Cemetery Gates"!
eng-399 and unretarded like this.
Purenv is offline
post #29 of 219 Old 05-25-2017, 06:48 AM - Thread Starter
post #30 of 219 Old 05-25-2017, 07:34 AM
esappy's Avatar
Quoted: 200 Post(s)
Liked: 150
To funny guys I like where this is going I'm going to try and incorporate a song title to each post. Let's see how "Far Beyond Driven" we can all take this
At this point, it would be HERESY not to!
eng-399 likes this.
esappy is offline
