The DIYSG Magnum 12 General Discussion Thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 75Likes
post #61 of 114 Old 08-11-2017, 07:35 PM - Thread Starter
eng-399's Avatar
Quoted: 1742 Post(s)
Liked: 2998
Matt great work on this kit it looks great! If someone one built a bigger slot ported box for the magnums instead of sealed modules would it still work with the crossover design.
eng-399 is online now
post #62 of 114 Old 08-11-2017, 09:07 PM
mtg90's Avatar
Quoted: 496 Post(s)
Liked: 974
Yes larger ported enclosures would work with the same crossover design.
eng-399 likes this.
mtg90 is offline
post #63 of 114 Old 08-11-2017, 10:05 PM
Quoted: 92 Post(s)
Liked: 87
My double 1.77cuf boxes and the CD/mid range section would work well with out needing to rework the cross over? Is this the exact same section from the titan?
Trimlock is online now
post #64 of 114 Old 08-12-2017, 09:40 AM
mtg90's Avatar
Quoted: 496 Post(s)
Liked: 974
Just to make it clear the crossover from the Titan-615 or 615LX will not work with the magnum woofers (at least not optimally). The crossover for the new Titan-612DC works fine with those woofers in sealed or ported enclosures.
For most speaker designs switching from sealed to ported or vice versa does not require crossover changes.
It's not noted anywhere but you can run the 615's sealed if you wanted or plug one port and have ~28hz tuning instead of the normal 40hz for possibly more low end extension if room gain is good.
brian6751 likes this.
mtg90 is offline
post #65 of 114 Old 08-12-2017, 09:49 AM
tk123's Avatar
Quoted: 17 Post(s)
Ok guys. Thanks for being so patient and helpful with me here. I'm trying to learn on the fly. I have another question.
What differentiates this design from say, the Fusion 12 or even Fusion 15 in terms of output, frequency response, etc. It seems that all three are designed with roughly the same frequency range and price points.
Since I've never heard any DIYSG speakers, I have no point of reference to determine differences. Thanks again.
tk123 is offline
post #66 of 114 Old 08-12-2017, 11:02 AM
tuxedocivic's Avatar
Quoted: 2202 Post(s)
Liked: 2078
For starters those are two way designs, so horizontal centers are a no-no. The woofers cover more of the midrange so they give up bass capability to do that. Which is a common 3way vs 2way trade off. Those also use the very good seos waveguide and we're talking about coaxials and other horns. Different devices to accomplish different objectives. The nice thing about a coaxial design is you could use the coax portion for surround duty and get a uniform timbre around the room.
My youtube channel: Impulse Audio
tuxedocivic is offline
post #67 of 114 Old 08-12-2017, 11:26 AM
tk123's Avatar
Quoted: 17 Post(s)
The coaxial design you mention, I assume is the tweeter/midrange horn combination.
I saw another thread that discusses a Fusion 8 Tower build with a larger enclosure to increase low frequency output. Maybe that's the kind of thing I'm looking for. Or even the Cohesive 893 ported. Don't really know.
tk123 is offline
post #68 of 114 Old 08-12-2017, 01:17 PM
Liked: 2078
Yes the coax is a mid and tweeter combo.
A ported 893 can extend pretty low.
post #69 of 114 Old 08-12-2017, 01:52 PM
tk123's Avatar
Quoted: 17 Post(s)
tux, do you have any knowledge about the ported 893? There are no details on DIYSG website about it other than the difference in frequency response compared to the original. I haven't seen anything about it.
tk123 is offline
post #70 of 114 Old 08-12-2017, 04:46 PM
Liked: 2078
The 893 thread got nuked by the photobucket scam
What would you like to know? I designed the speaker if you weren't aware. So any questions about it I can help with.
post #71 of 114 Old 08-12-2017, 04:58 PM
Quoted: 92 Post(s)
Liked: 87
Before the talk of the titan 612, the 893 was my favorite speaker on the DIYSG website. When I'm ready to move from my klipsch towers it's going to be a tough time to which one I pick.
post #72 of 114 Old 08-12-2017, 05:12 PM
tk123's Avatar
Quoted: 17 Post(s)
Well. Sorry we got so far off topic here. Not intentional.
I found the "Lil Bro to the 1099" thread that discusses the 893 from start to finish. I read through it but think I need to read it again. Lots of cool stuff and good info there !
I'm thinking that no matter what size ported enclosure you use, the crossover remains the same, correct?
tuxedocivic likes this.
tk123 is offline
post #73 of 114 Old 08-12-2017, 10:54 PM
Quoted: 92 Post(s)
Liked: 87
From my understanding is this only applies to the low end. If you change cross over frequency then it would.
post #74 of 114 Old 08-14-2017, 10:03 AM
tk123's Avatar
Quoted: 17 Post(s)
I feel responsible for derailing this thread. Sorry guys. So, bump
tk123 is offline
post #75 of 114 Old 09-03-2017, 03:31 PM
bossdog304's Avatar
Quoted: 85 Post(s)
Liked: 91
Could use a little help with my MBM's I bought for Nearfield use from DIYSG. So I have one built and I was playing around with the Inuke 1000dsp functions and realized that if I use the subwoofer output on my Onkyo 828 receiver is it going to cross over at 80Hz regardless of how I setup the amp? I built them using the flat pack and cut the port to tune them at 40 Hz and was planning on going up to 250Hz. Just an FYI I have 2 subwoofers on a y splitter and was going to put the 2 MBM's on another Y adapter. Also a little confused on settings for using the Inuke if someone had a good starting point for settings would appreciate it.
bossdog304 is online now
post #76 of 114 Old 09-03-2017, 05:49 PM
corradizo's Avatar
Quoted: 1182 Post(s)
Liked: 891
If the amps for your subs are also inuke dsp, then cross your speakers in the avr at 250hz, that will then feed your mbm and subs. Low pass/high pass your mbm and your subs to their respective frequency ranges.
corradizo is offline
post #77 of 114 Old 09-03-2017, 05:59 PM
tjcinnamon's Avatar
Quoted: 1277 Post(s)
Liked: 314
I have a thread to show you. I'm at a wedding but I'll fill you in when I get a chance. I'm literally looking to do the same thing.
tjcinnamon is offline
post #78 of 114 Old 09-03-2017, 11:17 PM
Quoted: 92 Post(s)
Liked: 87
Your sub pre outs auto to 80hz, but you can change it in the settings. Be aware though I think the max cross over on receivers and the LFE out is 150.
You should model the box in winISD and see where max excursion takes place and filter before that, to protect your speakers. Next is to get a mic and measure your room, use the results to use your PEQ settings to flatten your response - trust me this is important.
I have the gain turned up partially on my MBM's to better match my sub and the lower end gained by my room. It's pretty awesome, in Jurassic Park I can now feel when the t-Rex breaths, all thanks to the MBM's.
unretarded likes this.
post #79 of 114 Old 09-04-2017, 07:45 AM
brian6751's Avatar
Quoted: 1172 Post(s)
Liked: 1143
Don't mean to keep derailing this thread but what about using a different 12" for the Titan-12 like the one from the HTM-12 and tune it around 65hz to be able to cross at 80?
This would be for people that want the midrange and highs from the Titan but dont need the extension of the Titan-15. It would also be a little shorter.
That's not science! - Cyborg
FOR SALE: nothing at the moment
Rivers Edge Theater
brian6751 is online now
post #80 of 114 Old 09-04-2017, 08:13 AM
Erich H's Avatar
Quoted: 1493 Post(s)
Liked: 1902
We originally thought about the 12" Kappalite, or see if Eminence could get us a custom version similar to the 15" they made. But the cost difference between the 12" and 15" Kappalite is not very much and the price would be close. When that happens, most people just go for the larger model. The width of the speaker wouldn't change much between the two models due to the width of the horn.
I did draw up a 12" model where the cabinet was wider and not as tall, and then about 20 other variants of different shapes and sizes. But not really sure what everyone needs. Without reviews or community brainstorming on what people want, it's difficult to know which direction to move.
brian6751 and unretarded like this.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #81 of 114 Old 09-04-2017, 09:13 AM
brian6751's Avatar
Liked: 1143
That makes sense.
I'm just trying to think of a way to make it so it would work sitting on top of a sub. What about dual 8" woofers in an WTMW configuration? Maybe using the DW816 from the Cinema -8?
Rivers Edge Theater
post #82 of 114 Old 09-04-2017, 10:25 AM
Erich H's Avatar
Liked: 1902
Eminence made some very nice high end, high power 8" woofer samples that would work very well. But they're pretty expensive and I'm just not sure if there's enough demand for something like that. Once you add the cost of two nice smaller woofers, you're pretty much at the cost of a nice larger woofer. For example, there's only been one 88-Special ordered since the HTM-12 came out, because the two 8's cost nearly the same as the 12" and need almost the same enclosure size. A lot of the 'problem' is when kits are priced at the sum of their parts. It makes it more difficult to differentiate between some of the designs.
Erich H is offline
post #83 of 114 Old 09-04-2017, 10:51 AM
brian6751's Avatar
Liked: 1143
Do the 8's have to be "high end"? Wouldnt the DW816 work? I doubt most people will be using more than 100-200 watts on them and are just looking for sound quality
Rivers Edge Theater
post #84 of 114 Old 09-04-2017, 12:46 PM
Erich H's Avatar
Liked: 1902
Yes, those woofers would work okay. The price would likely come in just a little under the standard Titan-615, but more than the 88-Special and 893 speaker. Less sensitivity than those speakers, same height as the HTM-12, but costs more than all of them. I'm not sure how demand would be for something like that. It's a tough call when you start comparing new ideas to what's already been designed.
Erich H is offline
post #85 of 114 Old 09-04-2017, 03:38 PM
tjcinnamon's Avatar
Liked: 314
So I done some research (although haven't brought it to light yet) because I want my LFE channel + 40 to 120Hz from my fronts but also want to keep my fronts with a standard crossover at 80Hz.
I was thinking this could be as simple as an RCA Y adapter but that will NOT work and potentially be damaging. so you can't combine signals with a Y adapter, only clone them. Then I looked at some passive hardware which is called an RCA combiner. However, it appeared there would be some crosstalk between the signals. I can't speak to the veracity of this claim but perhaps live sound and home theater have different standards for pross talk.
Finally, a digital mixer would be a solution to combine the signals with no crosstalk. I already own a MiniDSP 2x4 ($105) and can use that to combine 2 input signals to 1 output signal.
So I'm going to use this as an experiment and do LFE + Center Channel (pre-out on my AVR) and keep my crossovers at 80Hz and add an HPF at 30Hz and LPF at 120Hz. So my usable spectrum for my MBM Mag 12's will be around 35 to 140Hz.
I'll be sure to let you know how it goes.
Read from post 44 down:
Mid-Bass Questions for the Experts and Gallery
Marantz 7010 for 7.2.4
2 x Paradigm Prestige 75F's
1 x Paradigm Prestige 55C
8 x Paradigm CI Pro P65-R's
Sub 2 x Rythmik LVX12's
TV: LG 65B6
post #86 of 114 Old 09-04-2017, 04:17 PM - Thread Starter
eng-399's Avatar
Liked: 2998
I like all the ideas everyone is coming up with for these drivers. I personally want to see these drivers in a slot ported box with the waveguide used for the Titan to kinda be like the JTR Noesis 212T. I think these drivers can give that speaker a run for its money. I know most guys will run these with a 80hz crossover but so are the JTR's... full range these will be amazing 30-35 hz and up from what I've modeled. I really want to hear what the sealed version would sound like to that Matt's designing right now.
post #87 of 114 Old 09-04-2017, 05:02 PM
brian6751's Avatar
Liked: 1143
Yeah the more I think about it the 612DC is probably the best way to get what I'm talking about.
Rivers Edge Theater
post #88 of 114 Old 09-05-2017, 10:16 AM
bossdog304's Avatar
Quoted: 85 Post(s)
Liked: 91
Thanks for the responses, I guess it was an after thought. If I buy a Minidsp 2x4 it defeated the purpose of the Inuke DSP version. I'm going to play around with the AVR and Inuke and see what I can get figured out, maybe I can adjust the receiver crossover and use the manual settings for the PSA subs.
post #89 of 114 Old 09-05-2017, 12:29 PM
tjcinnamon's Avatar
Liked: 314
yes, you are correct. For a second I was worried that I didn't get the iNuke with DSP because I was going to use my miniDSP as a mixer and unable to PEQ my rear subs. I'll worry about that later.
TV: LG 65B6
post #90 of 114 Old 09-05-2017, 03:24 PM
tk123's Avatar
Quoted: 17 Post(s)
Now ......That's what I'm talkin' 'bout !!!!!
I really like the sound of this- slot ported, with the wave guide for full range music listening. Would also be great as Front L&R. Not too big. Not too small. Not too expensive. Just right !!!!
eng-399 likes this.
tk123 is offline
