I.S.C.T. – ‘Break-Out” Fold Back units for musician …. - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By UpperCut
post #1 of 6 Old 08-12-2017, 07:35 PM - Thread Starter
Quoted: 26 Post(s)
While waiting as so often for parts or any other materials like this time it is for large sheets of Felt which have not arrived as yet I did find time to approach the last out of my three projects for musician.
This time it is a set of Fold backs which after the main units (I.S.C.T – ‘Poetry Of Sounds’ Point Source w/ Dual Sized – Floating Face Plate(s)) LINK: and the Bass unit (I.S.C.T. – ‘Primal Instinct’ Dual 8” Sub Enclosure in a (Sealed/Vented) configuration …) LINK: now complete the reproduction speaker enclosure projects as the rest will all be electronics not only within the units themselves (Plate Amps etc.) to be used in different set up configuration, but also on the outside running equipment like D/A Mixing Desk for the Instruments in use & Balanced/Un-Balanced converter, Nano-Technology Valve Amps for the Instruments feeding both the main speakers as well as connecting to the Crossover / Hi-Fi Valve Amps running the Fold Backs & the dual Bass unit etc.
rgs UpperCut
New No. 03 Image(s): **** Image 877aa.jpg ****
In my projects I always like to have incorporated many different options because I like to test with one and the same unit a few different set us, but while the proportion of it & the calculations are correct I have found that I have a small problem with the deeps of the front component unit to be able to use all my options I wanted to build into!
I was truly trying to keep the weight down on this unit, but I’m simple short on 1” (25mm) deeps, and so I have to use another 18mm slice & a 12mm slice with another volume increase of about 4 liter in total to get that needed deeps measurement and to use not only low profile woofer speaker chassis but also other standard 6.5” & 8” chassis etc.
Anyway, I guess live, learn and adapt to suit the rest!
rgs UpperCut
Shreds likes this.
UpperCut is offline
post #2 of 6 Old 08-13-2017, 01:19 PM
zora's Avatar
Quoted: 51 Post(s)
Liked: 57
What???
zora is online now
post #3 of 6 Old 08-13-2017, 03:25 PM
Javs's Avatar
Quoted: 2926 Post(s)
Liked: 2434
Is English your second language? Your paragraphs are insanely difficult to make sense of.
JVC X9500 (RS620) | OZTS Majestic 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | Rotel RMB-1555B | DIY Javelin Audio TPL-150 L/C/R | DIY Faital MTM TPL-150 Surrounds | DIY Dolby Atmos MKII Modules | DIY Quad 18" Subs 30cf Net
Shootout - JVC RS500 (X7000) & Sony 320ES | My Panasonic UB900 HDR and SDR Settings | My MadVR Settings
Javs is offline
post #4 of 6 Old 08-13-2017, 05:34 PM
emilime75's Avatar
Quoted: 51 Post(s)
Posted...Please do not feed the trolls.
emilime75 is online now
post #5 of 6 Old 08-13-2017, 08:21 PM
Dave in Green's Avatar
Quoted: 1845 Post(s)
Liked: 1229
I believe it's been established that the OP is a native of Germany. But the sensibility aspect may not be limited to linguistics.
Dave in Green is online now
post #6 of 6 Old 08-13-2017, 10:58 PM - Thread Starter
Quoted: 26 Post(s)
New Image(s) in lead thread!
rgs UpperCut
UpperCut is offline
