B&C 21SW152 Ported Design Opinions - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By notnyt
post #1 of 14 Old 08-17-2017, 10:48 AM - Thread Starter
Liked: 0
Hey guys long time lurker, I was hoping I could get any opinions on a ported subwoofer I'm designing. This will be used heavily for music but also for movies and gaming.
I decided that response down to 25hz was the goal so a tuning of 27-28 hz was chosen.
Amplification will be a crown K2 so 2500 watts rms into 4 ohms.
Some basic specs:
Net volume: 9.03cuft (255.7L)
Port Area: 109.85 in^2 (708cm^2)
Port Length: 32" (81.28cm)
Tuning: 27.5hz
External Dimensions: 24x36x28in
I have attatched the CAD design, SPL and excursion in hornresp and port velocity from SUBSIM.
Hornresp sims have a 22hz subsonic applied and are 2pi with 100vrms
Hoping to get another opinion on the design because it looks good to me. It will constructed entirely in 18mm baltic birch.
Name:	21SW152 CAD Snapshot.png
ID:	2269112   Click image for larger version
ID:	2269124   Click image for larger version
ID:	2269126   Click image for larger version
Name:	Vent Velocity.png
BIGlep is offline
post #2 of 14 Old 08-17-2017, 11:08 AM
Samps's Avatar
Quoted: 925 Post(s)
Liked: 526
Did you consider the Othorn? It's not much bigger.
You might want to add more bracing. The braces can be smaller but more of them. A single brace on a 24" wide panel with this level of spl seems underbraced.
Samps is offline
post #3 of 14 Old 08-17-2017, 11:10 AM - Thread Starter
Liked: 0
Another CAD shot showing the bracing
BIGlep is offline
post #4 of 14 Old 08-17-2017, 11:15 AM - Thread Starter
Liked: 0
I did consider it but I honestly don't have the confidence at this point to be able to hold the required tolerances with the tools I have on such a complex design. It's actually the eventual goal but I figured to start with ported.
BIGlep is offline
post #5 of 14 Old 08-17-2017, 11:33 AM - Thread Starter
Liked: 0
I added more bracing in this version do you think this would be sufficient
Name:	CAD-updated bracing.png
BIGlep is offline
post #6 of 14 Old 08-17-2017, 11:45 AM - Thread Starter
Liked: 0
OK I think I realise which part you were saying was underbraced. I shorted the port brace and added two pieces to support the rear panel.
BIGlep is offline
post #7 of 14 Old 08-17-2017, 12:06 PM
notnyt's Avatar
Quoted: 2772 Post(s)
Liked: 2556
Drop the tuning, you have a decent hump there. you can get away with a lower tune with that enclosure.
notnyt is offline
post #8 of 14 Old 08-17-2017, 12:08 PM
Samps's Avatar
Quoted: 925 Post(s)
Liked: 526
Better, but the outside panel of the port is weak. Use two port dividers. The port size will shrink a bit but it will be stronger.
Samps is offline
post #9 of 14 Old 08-17-2017, 03:13 PM - Thread Starter
Liked: 0
I did what you said and the slightly reduced port length also meant I could shorten the port just enough to get rid of the second port piece. So the number of components actually dropped. I attached the new picture and hornresp stuff
Name:	CAD final bracing.png
ID:	2269234   Click image for larger version
Name:	hornresp inputs.png
ID:	2269236   Click image for larger version
BIGlep is offline
post #10 of 14 Old 08-17-2017, 05:23 PM
LTD02's Avatar
Quoted: 2524 Post(s)
Liked: 2867
overall your plan seems fine and everything checks out. tuning may come in a hz lower or so.
Listen. It's All Good.
LTD02 is offline
post #11 of 14 Old 08-17-2017, 05:35 PM
notnyt's Avatar
Liked: 2556
notnyt is offline
post #12 of 14 Old 08-17-2017, 05:44 PM
chrapladm's Avatar
Quoted: 937 Post(s)
Liked: 350
I would second the option of lowering the tuning. Or you can make the cabinet smaller and stay with the current tune.
chrapladm is offline
post #13 of 14 Old 08-17-2017, 08:03 PM - Thread Starter
Liked: 0
I might change the port back to an "L" to lower the tuning but as it is in terms of construction it should be really easy to build and is smaller than a lot of dual 18 bins. This driver seems to always have a tuning hump.
BIGlep is offline
post #14 of 14 Old 08-19-2017, 12:29 AM
chrapladm's Avatar
Quoted: 937 Post(s)
Liked: 350
It may have a small hump but in your case you have a lot more volume than is needed for this high of a tune. Hence the large hump/spike. 200L looks good with a 22hz tune.
21SW152 , ported , subwoofer
