Horn Dampening Ay one do this ? - AVS Forum | Home Theater Discussions And Reviews
 24Likes
post #1 of 61 Old 08-17-2017, 05:45 PM - Thread Starter
dashpuppy's Avatar
Quoted: 408 Post(s)
Liked: 241
I created a new youtube video on how to dampen you're horns. Thought it would be a good video, You can "definitely" hear the difference with and with out the "elephant-Poop"
Shed some input if you want.
Next video will be up in a few days from the measurements.
LTD02, EarlK and Al Toid like this.
dashpuppy is offline
post #2 of 61 Old 08-17-2017, 05:56 PM
Quoted: 986 Post(s)
Liked: 329
good vid thanks for posting but id want to see how it impacts the measurement.
thanks
THANK YOU!!! for your selfless contribution to the audio world
Anders Torger for Brutefir
Thomas Drugeon for Rephase
John Mulcahy for room eq wizard
Denis Sbragion for DRC room correction
Juha Hartikainen for Winisd
1201 is offline
post #3 of 61 Old 08-17-2017, 05:57 PM - Thread Starter
dashpuppy's Avatar
Quoted: 408 Post(s)
Liked: 241
thanks
Subscribe to my channel video should be up in a few days
post #4 of 61 Old 08-17-2017, 06:54 PM
Al Toid's Avatar
Quoted: 195 Post(s)
Liked: 178
I am also very interested in this. Is it a tonal difference (ie what you hear), is it a measurable difference or is it both? It would be nice to hear a song on it if it is a tonal difference.
dashpuppy likes this.
Al Toid is offline
post #5 of 61 Old 08-17-2017, 10:28 PM
Face2's Avatar
Quoted: 346 Post(s)
Liked: 208
Not to take sway from your testing, but I did a similar experiment with SEOS12 waveguides, no difference in measured response or distortion. As for thinner plastic or metal horns, I could definitely see it being beneficial.
Sent from my SM-G935V using Tapatalk
Scott Simonian likes this.
Face2 is offline
post #6 of 61 Old 08-18-2017, 02:55 AM
notnyt's Avatar
Quoted: 2773 Post(s)
Liked: 2559
Horns don't get tapped on when playing music The last time I tested this it didn't make a difference in measurements. That said, it was with a JBL horn and they're generally pretty beefy.
notnyt is offline
post #7 of 61 Old 08-18-2017, 08:04 AM - Thread Starter
dashpuppy's Avatar
Quoted: 408 Post(s)
Liked: 241
I know horn's don't get tapped on during music, the point of the taping was to show that they resonate, just like how they would when certain frequency play "through" or around them.
It's like putting insulation in your walls, it's dampening the walls and absorbing the resonate frequency.
post #8 of 61 Old 08-18-2017, 09:07 AM
bscool's Avatar
Quoted: 687 Post(s)
Liked: 550
I recently did the horn and the whole front plastic section of my Studio 590 using dynamat type damper https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 on the back of the plastic fronts and horns. I can't say I can hear any difference while listening to music, I can hear a difference hitting my finger nail on the enclosure but that is probably as valid of a test as knocking on a speaker enclosure to judge how well it is made and braced, which I don't think tells you much when it comes to actual speaker performance and enclosure.
I still haven't done the other main speaker so I could measure them to see if there is a difference but I don't there is going to be one so I haven't been motivated to do the testing with REW. Probably as much or more of a variance between the individual drivers as what the dampening did.
Edit. I didn't really plan on doing any before and after measurements but I just took some measurements after posting this and do see quite a bit of difference between the two speakers. But I don't know they could have measured quite different out of the box. I had only measured them before at the MLP. These measurements I did just now were with the microphone 36" away from the speaker and 33" up from the ground.
I do not have enough room to get them away from any walls or boundaries so I just put tape on the floor where each speaker was in its L& R location and then took a measurement of each speaker and then switched their locations and redid the measurements. I know it is probably not the correct way to do this but is it how I did it I also forgot to switch the calibration file from the 90 degrees to the on axis file so the top end is around 6dB hot.
I think it still is valid for showing the difference between the two speakers. Maybe after I am finished with putting the dynamat on the untreated speaker I will remeasure and see if it changes it any. I am just posting 1 graph of the averages and purple is treated and green stock.
File Type: jpg Average between untreated vs treated.jpg (117.5 KB, 46 views)
HTPC, Sony 40es, 120" Silver Ticket, 7702mkii, Sunfire Amp 225w, JBL 590, JBL 520
PSA XS30, Seaton Submersive, 2 Um-18 8cf sealed, Outlaw Ultra x 12, Kappa Pro 18LF, BFM Tuba 60 horn, B&C 18TBW100 6cf 41hz, 34hz, 28hz tune
iNuke 3000 & 6000 DSP's, Crowson Motion Actuator
bscool is online now
post #9 of 61 Old 08-18-2017, 11:03 AM
notnyt's Avatar
Liked: 2559
easy test. keep everything in exactly the same position and measure before and after.
LTD02 and dashpuppy like this.
notnyt is offline
post #10 of 61 Old 08-18-2017, 12:12 PM
OJ Bartley's Avatar
Quoted: 259 Post(s)
Liked: 347
Interesting to see measurements for this. Like Face2 said above, I think this would have a lot more impact on thinner plastic horns that it would on beefier models like the SEOS, but I had the same thoughts as you and put some Dynamat on there anyway, just because I had it on hand.
I didn't measure anything, but figured it was something I could do while they were open that MIGHT have a positive impact, and couldn't really hurt. (SEOS-15 pictured, by the way).
Edit: Not to be nitpicky, I'm actually wondering... is the correct term "damping" or "dampening"? I thought it was the former, but I'm no expert.
OJ Bartley is offline
post #11 of 61 Old 08-18-2017, 01:59 PM - Thread Starter
dashpuppy's Avatar
Quoted: 408 Post(s)
Liked: 241
That's exactly what im going to do. Making the jig, this weekend.
notnyt likes this.
post #12 of 61 Old 08-18-2017, 02:00 PM
notnyt's Avatar
Liked: 2559
Please share the mdats from before/after measurements
notnyt is offline
post #13 of 61 Old 08-18-2017, 02:04 PM
michael hurd's Avatar
Quoted: 112 Post(s)
Liked: 107
Your theory may have some validity, if the horn were freestanding without a compression driver bolted or screwed to it, nor attached to a baffle, hanging on a piece of fishing line.
Once screwed to a baffle, with a compression driver on the back, the resonant frequency will change.
LTD02, bwaslo and Face2 like this.
Spoon feeding with a 9 yd bucket.
michael hurd is offline
post #14 of 61 Old 08-18-2017, 02:08 PM - Thread Starter
dashpuppy's Avatar
Quoted: 408 Post(s)
Liked: 241
You think ? However, screwing it into a baffle still won't take the resonating plastic away in the center..
I'll also prove this in the next video.
post #15 of 61 Old 08-18-2017, 07:05 PM
bscool's Avatar
Quoted: 687 Post(s)
Liked: 550
Well, it did not make a difference in my case. Good or bad I cannot hear a difference so it is staying on. The variation between the 2 speaker is what was showing up in the measurements.
Edit. Add pics of the horn almost finished, woofer front baffle and the CD enclosure that separates the compression driver from the 8" woofers. I put a layer of the dynamat knock off on all of them.
LTD02 likes this.
post #16 of 61 Old 08-18-2017, 07:45 PM
notnyt's Avatar
Liked: 2559
Originally Posted by bscool View Post
Well, it actually does make a difference here is the after. And both speakers do measure the same also. Not sure it would be considered good. It looks it knocks off the high-end and creates more of a notch around 10,500khz applying the damping. Good or bad I cannot hear a difference so it is staying on.
Looks like you measured from a non identical position or with something changed. a resonance shouldn't affect that large of a frequency range.
notnyt is offline
post #17 of 61 Old 08-20-2017, 01:32 PM
augerpro's Avatar
Quoted: 137 Post(s)
Liked: 68
So you moved the mic AND use ungated measurements? Totally useless data. Not being a d@#$, just making sure you know and don't make any decisions based on it.
Face2 likes this.
augerpro is offline
post #18 of 61 Old 08-20-2017, 04:29 PM
augerpro's Avatar
Quoted: 137 Post(s)
Liked: 68
Like I said, don't take it personal. What is your gate length? What is the max gate before the first boundary reflection?
augerpro is offline
post #19 of 61 Old 08-20-2017, 06:08 PM
notnyt's Avatar
Liked: 2559
moving even a millimeter will give you a different response. Needs to be exact.
Face2 and bscool like this.
notnyt is offline
post #20 of 61 Old 08-23-2017, 11:09 AM
bscool's Avatar
Quoted: 687 Post(s)
Liked: 550
I believe in the last graph I posted I used 2.8ms. I'll just post the mdat so who ever can look at it. I know it was not the optimal and most accurate way to do it but I thought it gave pretty consistent results for what I wanted to see.
I didn't indent to post any measurements either but the post came up asking if anyone had done it and I figured I would take some quick measurements. I wouldn't build a speaker design taking measurements like this
I may not be clear either in my writing this is two separate speakers(my left and right mains). I had already finished 1 speaker(right main) and had not measured it. I decided to take a measurement after seeing this post. First I measured the finished speaker and then I measured the unfinished speaker in the same location using tape to mark the speaker's placement. Then I applied dyanamat to the unfished speaker and took a measurement with it in that same location.
https://1drv.ms/u/s!Alekwwtstb8wj-ISxAXQ_CEj7Qscxg
post #21 of 61 Old 08-23-2017, 12:31 PM
notnyt's Avatar
Liked: 2559
These measurements are completely useless. Not trying to be offensive, but as you said, you measured two different drivers at two different locations. the location needs to be exact, like in a jig exact.
notnyt is offline
post #22 of 61 Old 08-23-2017, 12:45 PM
tuxedocivic's Avatar
Quoted: 2186 Post(s)
Liked: 2055
He said he measured the unfinished speaker with and without dynamat and a mm wouldn't make a significant difference IMO.
Sent from my SGH-I337M using Tapatalk
My youtube channel: Impulse Audio
tuxedocivic is offline
post #23 of 61 Old 08-23-2017, 01:35 PM
bscool's Avatar
Quoted: 687 Post(s)
Liked: 550
Yeah, they were measured from the same location just like I saw you do in your videos tux using the ladder and you line then up using a tape measure and your "ladder" would have been my tape marks on the floor where I placed the speaker.
I think there is confusion because in an earlier post I had measure both speakers in 2 separate locations so 4 measurements total for the first initial measurements to verify consistency but took those out because it just added more confusion.
Anyway, this isn't my thread and I don't want to take it over with my measurements and posts. Each can decide for themselves to decide if they measurements are of any use or totally worthless. I did my best at the time I know next time to build a jig if I want to post measurements like this
post #24 of 61 Old 08-23-2017, 01:38 PM
notnyt's Avatar
Liked: 2559
Yeah, got caught up when I just read "I measured the finished speaker and then I measured the unfinished speaker in the same location "
I'll give the measurements a lookover.
notnyt is offline
post #25 of 61 Old 08-23-2017, 01:56 PM
notnyt's Avatar
Liked: 2559
So which is which in the mdat? It's not clear.
I see
original R dampened 8/18 12:48
OrigLeftPostTreat 8/18 12:49
Swithced undamped to r 8/19 9:35
"origleftposttreat" and "original r dampened" appear to be taken at very close to the same position and have similar response, the "switched undamped to r" appears to be taken at a different location
notnyt is offline
post #26 of 61 Old 08-23-2017, 02:05 PM
bscool's Avatar
Quoted: 687 Post(s)
Liked: 550
I see
original R dampened 8/18 12:48 this was my RIGHT speaker that I had already applied dyamant
OrigLeftPostTreat 8/18 12:49 This was my LEFT speaker that I had not treated yet and I moved it to the RIGHT speaker location where I had measured them all.
Swithced undamped to r 8/19 9:35 This is the LEFT main after applying dynamat measured at the RIGHT speaker location
They were all taken at the same location. I know the OrigLeftPostTreat showed a different first reflection but they were in the same location as the other two.
post #27 of 61 Old 08-23-2017, 02:24 PM
notnyt's Avatar
Liked: 2559
Sorry, got the timestamps messed up, I'll assume your order is correct but the filenames weren't.
Code:
Original R dampened           8/18 12:48 PM        R TREATED
Swithced undamped to r        8/18 12:49 PM        L UNTREATED
OrigLeftPostTreat             8/19 9:35 AM         L TREATED
Expanding your windowing shows these were not taken with the mic at the same position.
I've renamed your graphs as indicated
These are with 125 left 500 right 1/48 octave width FDW
Left and Right after treatment are in the same position it seems, or quite close. They measure similarly.
Untreated left does not match that.
notnyt is offline
post #28 of 61 Old 08-23-2017, 02:46 PM
bscool's Avatar
Quoted: 687 Post(s)
Liked: 550
Code:
Edit, I don't think I KNOW I DID Crap I think I might have labeled them wrong and attached the wrong one? Argh lol. Do you want to look at all the files if I post the mdat and check them out? I think it will make more sense if you do. I am going to look at them again and see if I can make sense out of them
post #29 of 61 Old 08-23-2017, 02:48 PM
notnyt's Avatar
Liked: 2559
If you want I can check it out later
notnyt is offline
post #30 of 61 Old 08-23-2017, 08:09 PM
notnyt's Avatar
Liked: 2559
Thanks, I think these 3 are the correct ones as the impulse response first reflection lines up much closer and the FR is also much closer. I didn't include 5 or 7 files as I figured it might be even more confusing but I can include them if you want. I think these 3 will make sense now.
https://1drv.ms/u/s!Alekwwtstb8wj-IVKgu-ewP-WdQK7A
Edit change scale to match notnyts. My head hurts
Interesting results. There's definitely increased hf rolloff now. Was the CD removed from the horn? I don't see much difference in the time domain, but it's hard to tell since the noise floor was louder in one of em and the measurement's wasn't too far above it. I'd pick the before treatment plot if I had to choose.
edit: removed due to bad datas
notnyt is offline
