Jk's 1099 build thread - AVS Forum | Home Theater Discussions And Reviews
 26Likes
post #1 of 80 Old 08-23-2017, 06:24 PM - Thread Starter
Jk7.2's Avatar
Quoted: 415 Post(s)
Liked: 622
I picked up a set of components without cabs for a pair of 1099's, and an unbuilt, unopened horizontal center channel. This will be my next project. I contacted Erich to get the rest of the things I needed for this build. Three flat packs, new gaskets and screws for the once built pair, and two new baffles. He came through in classic DIYSG style. I love that shipping from there to SE MI is basically overnight. So I have my boxes to build, and the rest is in route. I'm going all out here. I've always wanted to build a nice set of speakers that sound great but also look great. I'll be asking questions about veneering cabs, and building grills with hidden magnetic attachment points under the veneer. I think I have a good idea where to start, but it's my first attempt at veneering, and making a speaker look good. Any thoughts and tips appreciated! This is a 'side project' so it's going to take a long time. I'll most likely use these for my living room setup. I'll post a pic of the veneer I chose.
ID:	2272170   Click image for larger version
ID:	2272172   Click image for larger version
OJ Bartley and eng-399 like this.
Jk7.2 is online now
post #2 of 80 Old 08-23-2017, 09:35 PM
I built a LCR set of 893s recently. I'd be glad to share the things I learned in the build. The veneer can be easy, as long as you take the right steps..
I'll watch your thread and chime in when you get to each stage.
scary1 is offline
post #3 of 80 Old 08-24-2017, 03:45 AM - Thread Starter
Jk7.2's Avatar
Quoted: 415 Post(s)
Liked: 622
Did you veneer the baffle as well? The cutouts on the front look difficult.
Jk7.2 is online now
post #4 of 80 Old 08-24-2017, 07:27 AM
Quoted: 16 Post(s)
Liked: 59
I veneered the baffles on my 1299's See this post here: Custom Maple Veneered Agressive 1299 Vented LCR Build
I got a "laminate trim bit" at the local home improvement store. I used that for the cutouts only. I used a "flush cut bit" to trim the veneer along the sides of the cabinet.
jehlinge is offline
post #5 of 80 Old 08-24-2017, 07:44 AM
FriscoDTM's Avatar
Quoted: 305 Post(s)
Liked: 278
Veneer is actually pretty easy. I put up some photos and explanation in my build thread and am happy to help.
Display 2013 Samsung 75" UN75F6300 TV Media Xbox One S, Dune Solo, QNAP TS-453A NAS
Pre/Amp Marantz 7702mk2 Processor + DIY 11ch Icepower 50ASX2BTL Monoblock Amp Amp Build Link
7.2.4 Speakers DIYSG 1099s (LCR), Volt 10LX (SL, SR), Volt 8LX (BL, BR), Volt 10LX (TF, TR) Volt Build Link
Subs Dual 19Hz DIY Ported UXL-18s + FP14k Amp + MiniDSP 2x4 Balanced Tactile Crowsons + iNuke 6000DSP
FriscoDTM is offline
post #6 of 80 Old 08-24-2017, 08:12 AM - Thread Starter
Jk7.2's Avatar
Quoted: 415 Post(s)
Liked: 622
Thanks for the info so far guys. I know once I get into it, I'll have more questions. I'll keep reading and planning.
Jk7.2 is online now
post #7 of 80 Old 08-24-2017, 08:56 AM
thebedbeard's Avatar
Quoted: 57 Post(s)
Subscribed! Have fun man
thebedbeard is offline
post #8 of 80 Old 08-24-2017, 09:52 AM
I did not veneer the baffle, mainly because I built grill covers. I also didn't know about the laminate trimmer that jehlinge mentioned above. When I built my 893 towers, I wanted the horns located at the top, so I ended up cutting the top woofer off, and grafting it below the other woofer. I did a build thread on the DIY Sound Group site, titled something like "Frankenstein 893 towers" Anyway, it was a nice project.
scary1 is offline
post #9 of 80 Old 08-24-2017, 10:19 AM - Thread Starter
Jk7.2's Avatar
Quoted: 415 Post(s)
Liked: 622
Glad you are gonna watch me have fun with these!
Jk7.2 is online now
post #10 of 80 Old 08-24-2017, 10:21 AM - Thread Starter
Jk7.2's Avatar
Quoted: 415 Post(s)
Liked: 622
I've seen your build. Awesome work. I thought the baffles would come with a large roundover. But they came square and that I like. So I will veneer everything.
Jk7.2 is online now
post #11 of 80 Old 08-24-2017, 10:23 AM - Thread Starter
Jk7.2's Avatar
Quoted: 415 Post(s)
Liked: 622
I will be reading your thread when I have a chance to give it the attention it deserves. Awesome work. Your cabs are the look I'm going for. Except I bought a laminated product. Not real wood. Don't tell anyone.
Jk7.2 is online now
post #12 of 80 Old 08-24-2017, 01:21 PM
ja00's Avatar
Quoted: 216 Post(s)
Liked: 144
if you need crossover pcbs let me know. I believe I have a set of 3left.
ja00 is offline
post #13 of 80 Old 08-24-2017, 01:27 PM - Thread Starter
Jk7.2's Avatar
Quoted: 415 Post(s)
Liked: 622
Thanks, but I have them.
Jk7.2 is online now
post #14 of 80 Old 08-25-2017, 04:01 AM - Thread Starter
Jk7.2's Avatar
Quoted: 415 Post(s)
Liked: 622
Hey @jehlinge
Can you expand on exactly what router bit you used and the process to laminate your baffles? I've done a quick search for a laminate bit and can't really figure it out.
Jk7.2 is online now
post #15 of 80 Old 08-25-2017, 05:12 AM
dtsdig's Avatar
Quoted: 901 Post(s)
Liked: 1015
Hey @jehlinge
This is the bit I used for the solid walnut that I used on my 1099 baffles. Worked perfect, even for the super shallow midrange recesses.
https://www.whitesiderouterbits.com/...products/sc28c
I also have this one, but the rounded tip is too long for very shallow recesses.
https://www.amazon.com/Bosch-85285M-.../dp/B0009H5M3O
dtsdig is offline
post #16 of 80 Old 08-25-2017, 08:57 AM - Thread Starter
Jk7.2's Avatar
Quoted: 415 Post(s)
Liked: 622
Hey @jehlinge
Thank you. I will grab one of those.
Jk7.2 is online now
post #17 of 80 Old 08-25-2017, 10:38 AM
Quoted: 16 Post(s)
Liked: 59
Hey @jehlinge
I used the bit mentioned earlier in this thread.
It worked fine for my 1299's...but just barely. The other one mentioned by @dtsdig might be a better option.
You just apply veneer like you normally would to the baffle. Be careful pressing it down around the cutouts....you don't want to press though a cutout void and "crack" the veneer when applying. Then I just used a utility knife to make a cut through the veneer in which I could insert the laminate bit and trimmed away..easy peasy.
I only used this bit for the cutouts. All of the other cabinet edges I used a flush trim router bit with a bearing. Since the laminate bit lacks the bearing, I was afraid it would damage the veneer on the opposite face to what I was trimming.
One last piece of advice...make sure you check all the woofers and mids for fit after trimming the veneer and BEFORE you apply your finish. On the 1299's, the cutouts for the woofers are pretty tight. The laminate bit leaves just a bit of extra veneer...maybe 1/64". None the less, the woofers would no longer go in...so I had to do some gentle hand sanding to get them in there. You will want that done before you stain and finish.
jehlinge is offline
post #18 of 80 Old 08-25-2017, 10:58 AM - Thread Starter
Jk7.2's Avatar
Quoted: 415 Post(s)
Liked: 622
Hey @jehlinge
Great advice thank you. My veneer is a laminate product, so it's pre finished. That should save me a little. I had time last night to glue up the first flat pack, but I didn't. I got lazy.
Jk7.2 is online now
post #19 of 80 Old 08-25-2017, 11:46 AM - Thread Starter
Jk7.2's Avatar
Quoted: 415 Post(s)
Liked: 622
I found the router bit on amazon. Thanks for the help.
Jk7.2 is online now
post #20 of 80 Old 08-27-2017, 06:50 AM - Thread Starter
Jk7.2's Avatar
Quoted: 415 Post(s)
Liked: 622
How much denim insulation should I install per compartment? I'm assuming in the woofer compartments just the sides and bottom is enough? I know to stay away from the ports. How about the midrange compartment? Stuff it on every surface? Any advice / knowledge appreciated.
Jk7.2 is online now
post #21 of 80 Old 09-04-2017, 09:13 AM - Thread Starter
Jk7.2's Avatar
Quoted: 415 Post(s)
Liked: 622
Making slow progress on my 1099's. My laminate showed up. No idea how I'll cut it into manageable pieces. Maybe I'll try our aluminum sheer at work. It sheers aluminum up to .063 thick. So maybe it will handle this product. I'm just nervous about chipping and cracking. First box is all glued up and ready for sanding. Cutout for terminal cup is done and crossover installed and wired. I'm happy I tested a hole saw and my router with the right bit and I can flush mount my terminal cups. I'll probably get all three boxes to this point and then sand and veneer.
ID:	2277758   Click image for larger version
ID:	2277760   Click image for larger version
ID:	2277762   Click image for larger version
ID:	2277764   Click image for larger version
brian6751 and eng-399 like this.
Jk7.2 is online now
post #22 of 80 Old 09-04-2017, 01:02 PM
eng-399's Avatar
Quoted: 1697 Post(s)
Liked: 2887
The cabinet looks great you lined the inside of the cabinet right the only thing I've seen differently is guys using poly fill for the mid and cd section of the box but I don't see any problems using the denim insulation. I can't wait to see how these are going to look with the laminate on the boxes.
eng-399 is online now
post #23 of 80 Old 09-04-2017, 04:43 PM - Thread Starter
Jk7.2's Avatar
Quoted: 415 Post(s)
Liked: 622
Thanks. I read in a few places that the denim insulation works for the cd mid section and the ported woofer sections. I hope it is good. I'm still wondering how to route out and trim the veneer around the baffle openings. The woofers are set in 5/16 or so, but the mids are hardly an 1/8". See my pics with the bit that I bought for this part. Doesn't look like it will work.
ID:	2277966   Click image for larger version
Jk7.2 is online now
post #24 of 80 Old 09-09-2017, 11:27 AM - Thread Starter
Jk7.2's Avatar
Quoted: 415 Post(s)
Liked: 622
Change of plans
I couldn't live with the laminate I chose. It was too shiny and cheap looking. So I just ordered real wood veneer and decided to duratex the baffles. I like the look of black speaker fronts and wood veneer sides and back. I'll just have to put in the work staining and finishing the cabs. It will be worth it in the end. Any suggestions on a stain and matte finish clear coat product and or application methods please share.
eng-399 likes this.
Jk7.2 is online now
post #25 of 80 Old 09-09-2017, 01:18 PM
FriscoDTM's Avatar
Quoted: 305 Post(s)
Liked: 278
sounds like a nice choice - which type of veneer? I used 5 coats of pure tung oil, put on with a rag https://www.woodcraft.com/products/w...tung-oil-quart
post #26 of 80 Old 09-09-2017, 01:26 PM - Thread Starter
Jk7.2's Avatar
Quoted: 415 Post(s)
Liked: 622
I just ordered 4 rolls of parts express walnut veneer. Tung oil? I have heard of it. But I want to go dark with the finish. How dark will tung oil get? Do you have a pic of your finished cabs?
Jk7.2 is online now
post #27 of 80 Old 09-09-2017, 02:39 PM
FriscoDTM's Avatar
Quoted: 305 Post(s)
Liked: 278
That's five coats dry close up, with a bit of glare from a nearby window.
And here's a comparison before and after one coat, still wet.
And 5 coats from a distance:
OJ Bartley likes this.
post #28 of 80 Old 09-09-2017, 03:06 PM - Thread Starter
Jk7.2's Avatar
Quoted: 415 Post(s)
Liked: 622
Wow! Those are fantastic. Beautiful. You wouldn't happen to have a pic before any tung oil went on?
Jk7.2 is online now
post #29 of 80 Old 09-09-2017, 04:42 PM
FriscoDTM's Avatar
Quoted: 305 Post(s)
Liked: 278
Thanks. The second pic has no oil on the left half. here are another couple of the veneer as received. It is bubinga from gl veneer
post #30 of 80 Old 09-09-2017, 05:20 PM - Thread Starter
Jk7.2's Avatar
Quoted: 415 Post(s)
Liked: 622
How did you sequence your finishes? Veneer then paint the baffle? How did you trim your veneer? I plan on using my flush trim bit. Good idea? Bad idea? I can get a down cut spiral bit too. Then with contact cement, I assume you can only do one panel a day right? Sorry for all the questions. I've never done any speaker finishing at all. Other than flat black paint.
Jk7.2 is online now
