18" HST 18 MKII or 24" HS24 MKII? - AVS Forum | Home Theater Discussions And Reviews
 31Likes
  • 7 Post By filtor1
  • 3 Post By Phonzo07
  • 2 Post By JohnDean
  • 1 Post By notnyt
  • 1 Post By JohnDean
  • 1 Post By paulys55
  • 1 Post By corradizo
  • 3 Post By notnyt
  • 2 Post By SpeakerPower
  • 1 Post By Gorilla Killa
  • 3 Post By uniquepattern
  • 1 Post By Tuning
  • 2 Post By coolrda
  • 1 Post By popalock
  • 1 Post By BassThatHz
post #1 of 26 Old 09-20-2017, 09:00 AM - Thread Starter
Quoted: 66 Post(s)
Liked: 29
I am planning on building a couple of sealed subs. The room size is 19x15x7.5 and the room usage is both for music and movies (40/60). I was originally planning on getting a couple of SI HST 18" MKii, but looking at the recent build, I am also interested in the HS24 MKii.
For my room, which of the two would be better? Will the 24" be overwhelming? will the 18" be sufficient? I am looking for tight musical low frequencies. I am not looking for overkill (maybe ).
Please share your thoughts and suggestions.
Tuning is offline
post #2 of 26 Old 09-20-2017, 10:29 AM
filtor1's Avatar
Quoted: 213 Post(s)
Liked: 166
If the 24"s are in your budget and size constraints I would grab those. If they are too loud....... never mind, get the 24"s.
filtor1 is offline
post #3 of 26 Old 09-20-2017, 10:32 AM
Phonzo07's Avatar
Quoted: 49 Post(s)
Liked: 39
Go BIG or Go Home.. ...
Well you'll be home already... JUST GO BIG..
If you KRANK it.. They will Listen..
Phonzo07 is online now
post #4 of 26 Old 09-20-2017, 10:35 AM
JohnDean's Avatar
Quoted: 470 Post(s)
Liked: 207
The only reasons I can think of to get the 18 over the 24 would be space or budget constraints. Otherwise, get the 24.
Electrodynamic and Tuning like this.
JohnDean is offline
post #5 of 26 Old 09-20-2017, 11:11 AM
notnyt's Avatar
Quoted: 2791 Post(s)
Liked: 2575
he said couple of 18s... having multiple subs lets you place them to even out room modes.
Tuning likes this.
notnyt is offline
post #6 of 26 Old 09-20-2017, 12:41 PM
JohnDean's Avatar
Quoted: 470 Post(s)
Liked: 207
lol. I don't see where he said he'd only get 1 24.
Here's my corrected statement...
The only reasons I can think of to get the 18s over the 24s would be space or budget constraints. Otherwise, get the 24s.
Tuning likes this.
JohnDean is offline
post #7 of 26 Old 09-20-2017, 12:58 PM
Liked: 1
What is your current electronics setup? Do you have a sub and are upgrading? What will these be powered with? As others have mentioned, are you comparing two 18"s to two 24"s or two 18s and one 24? Just trying to get a clearer picture.
Tuning likes this.
paulys55 is offline
post #8 of 26 Old 09-20-2017, 01:35 PM - Thread Starter
Quoted: 66 Post(s)
Liked: 29
Currently own a seaton submersive. I was thinking of either 2 18" or a single 24". Would love to go dual 24, but budget constraints
The sub will be powered using speakerpower amp.
Tuning is offline
post #9 of 26 Old 09-20-2017, 08:22 PM
corradizo's Avatar
Quoted: 1182 Post(s)
Liked: 891
corradizo is online now
post #10 of 26 Old 09-21-2017, 04:57 AM - Thread Starter
Quoted: 66 Post(s)
Liked: 29
If i get a speakerpower 4000w plate amp, can I use that to power two subs by connecting the dvc of each in series and the subs in parallel for a 2 ohm load on the amp? Or should I go for a separate amp for each box? This will help me identify which of the subs to get as well.
Tuning is offline
post #11 of 26 Old 09-21-2017, 11:01 AM
JohnDean's Avatar
Quoted: 470 Post(s)
Liked: 207
It looks to me like the plate amps have a slave out to power a second sub. I'd also suggest 2 HST18's over a single 24, unless you're also keeping your submersive.
Maybe @SpeakerPower will pop in and clarify.
Tuning likes this.
JohnDean is offline
post #12 of 26 Old 09-21-2017, 11:20 AM
notnyt's Avatar
Liked: 2575
the amp outputs are paralleled. So if you have two 4 ohm units hooked up to it, load will be 2 ohms, good to go.
notnyt is offline
post #13 of 26 Old 09-21-2017, 02:30 PM
SpeakerPower's Avatar
Quoted: 47 Post(s)
Liked: 100
That's Right.
You guys don't need me after all!
Brian
SpeakerPower Alpha Geek
Tuning and 18Hurts like this.
SpeakerPower is offline
post #14 of 26 Old 09-21-2017, 02:51 PM
Gorilla Killa's Avatar
Quoted: 684 Post(s)
Liked: 791
Originally Posted by SpeakerPower View Post
That's Right.
Brian
Easy now, we need your powah!!
Tuning likes this.
If you can't stand behind our troops stand in front of them
Gorilla Killa is offline
post #15 of 26 Old 09-22-2017, 03:22 AM
uniquepattern's Avatar
Quoted: 736 Post(s)
Liked: 742
I agree, dual subs are always better then a single, but if you think you will ever have the budget to add a second 24 down the road.... go for the 24's, they are just crazy fun!
coolrda, Electrodynamic and Tuning like this.
uniquepattern is online now
post #16 of 26 Old 09-22-2017, 03:35 AM - Thread Starter
Quoted: 66 Post(s)
Liked: 29
Thanks for all the responses. Very much appreciated. Will start a build thread once I decide and get going.
uniquepattern likes this.
Tuning is offline
post #17 of 26 Old 09-22-2017, 10:05 AM
coolrda's Avatar
Quoted: 1085 Post(s)
Liked: 982
Get'em all. 2 18's and the 24. PayPal Credit rules.
coolrda is online now
post #18 of 26 Old 09-22-2017, 02:26 PM
popalock's Avatar
Quoted: 1315 Post(s)
Liked: 1814
Whatever you do, try to future proof yourself. Keep in mind...since you are even looking at these options, there is a high statistical probability that 2 18's, 1 24, 2 24's or whatever else isn't going to be enough for you in the long term...
If smoothing on a budget is your primary concern, seems as though the 18's would be your best bet.
Just have fun with it...
Tuning likes this.
popalock is offline
post #19 of 26 Old 09-23-2017, 02:01 PM
BassThatHz's Avatar
Quoted: 2386 Post(s)
Liked: 2159
If the SI-24's are anything like the 24 I have, I'd say 24's for sure. There is just no comparison. They walk all over the 18's...
Maybe start with one 24 hanging off the submersive plate, and then add a second 24 later with both on a dedicated speakerpower amp.
That would free up the submersive plate to hang a 3rd 24 off of it.
Then take the submersive cone out and throw it in the garbage and tie into its leads for a 4th 24!!!
Ok, I probably took it a step too far on that last part... (or did I? )
Electrodynamic likes this.
BassThatHz is offline
post #20 of 26 Old 09-24-2017, 09:10 AM
popalock's Avatar
Liked: 1814
Then take the subversive cone out and throw it in the garbage and tie into its leads for a 4th 24!!!
I mean...do you have SI 24's or not? Or do you have one of Mark's products?
popalock is offline
post #21 of 26 Old 09-24-2017, 11:11 PM
BassThatHz's Avatar
Liked: 2159
That's classified... NOFORN/TS/SCI/SAP//UNACK ZEBRA
Spoiler!
post #22 of 26 Old 09-24-2017, 11:57 PM
Quoted: 45 Post(s)
Liked: 33
Oooohhhhh ya I reminder following that 24 you ordered religiously. Cost more to ship than buy if I reminder right. We still need to order a freighter full of them 😀
Acrjoey is offline
post #23 of 26 Old 09-26-2017, 06:55 PM
BassThatHz's Avatar
Liked: 2159
Yeah, roughly $13000, plus import fees, plus the cost of double shipping them all over USA/Canada + whatever handling fees that may or may not be required, and that doesn't take into consideration any buyer risks, shipping risks/insurance, or overhead for defects, or temporary storage costs after container unload.
Might be easier to just buy some from SI or Mach5; let them worry about the supply-management, shipping-mangement, funding and bankruptcy.
post #24 of 26 Old 09-27-2017, 03:31 PM
popalock's Avatar
Liked: 1814
Que?
Got the TSP's for this driver you picked up?
popalock is offline
post #25 of 26 Old 09-27-2017, 06:50 PM
BassThatHz's Avatar
Liked: 2159
It's in my thread from a few months back. (I'll let you AVS-Search for thread creations, I'm in lazy-mode atm.)
It measured fairly well.
The beefiest subwoofer I own.
Heavier and beefier than the LMS-18's and the MalX-21's I have; and those are no slouches...
My only complaint is that the cone/cap isn't CF or GF, which is my preferred material of preference. (I guess you don't get what you don't pay for. )
post #26 of 26 Old 10-02-2017, 06:39 AM
popalock's Avatar
Liked: 1814
By far....the laziest post you have ever written.
popalock is offline
