Sources for "Qaulity" components - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-17-2006, 12:07 PM - Thread Starter
cory.jenkins's Avatar
Hi,
I am interested building some home theater speakers. Initially, I would like to do it for Training purposes, and to learn some fundamentals.
Assuming I enjoy building the "Trainer", eventually, I would like to build some "Quality" (meaning higher-end type) speakers.
What where a few places I could look for high quality parts?
cory.jenkins is offline
post #2 of 9 Old 02-17-2006, 12:17 PM
---k---'s Avatar
Partsexpress.com in the number one source. Go to thier website and order a catalog. Also check out their tutoirals and stuff. They have a ton of stuff about DIY speakers, and a lot of partially built kits.
---k--- is offline
post #3 of 9 Old 02-17-2006, 12:45 PM
rlj5242's Avatar
Quoted: 48 Post(s)
Liked: 40
www.speakerbuilder.net has some low cost designs using the classic Dayton line from PE and some good articles on speaker building. The DIY forum at www.htguide.com has some designs using the Dayton RS line from PE. It's a jump in price, complexity and sound quality. Not that the classic line is bad. They are better than most speakers in Best Buy or Circuit City.
-Robert
rlj5242 is offline
post #4 of 9 Old 02-17-2006, 12:49 PM
rastanearian's Avatar
Try www.madisound.com or www.zalytron.com. There is alot of info to be found there.
rastanearian is offline
post #5 of 9 Old 02-17-2006, 03:01 PM
V.X.Donique's Avatar
Quoted: 52 Post(s)
Liked: 45
V.X.Donique is offline
post #6 of 9 Old 02-17-2006, 09:56 PM
thylantyr's Avatar
http://www.e-speakers.com/
The storm was gone, but dark clouds still hung around
The perfect setting for things to come......
thylantyr is offline
post #7 of 9 Old 02-18-2006, 08:50 AM - Thread Starter
For all the quick replies.
post #8 of 9 Old 02-19-2006, 12:29 PM
bimmerboy750's Avatar
i also love partsexpress.
Bimmerboy750
The Theorem theorem: If if, Then then
bimmerboy750 is offline
post #9 of 9 Old 02-23-2006, 11:33 PM
tsang1101's Avatar
www.solen.ca www.rawacoustics.ca are two more excellent companies. Although they are in Canada.
On a side note, why not snag a kit from one of the above mentioned websites? The only reason I say this is that I learned more from building a kit than I did from hacking it on my own....Once I finished one of those kits, I ended up being pretty confident with the whole building process, and on the plus side I ended up with an excellent set of speakers! It's very difficult if you have no prior knowledge to 'R&D' your own speaker from scratch...hard enough when you do know what you're doing I find :mad: (even though i'm far, far, away from being any kind of good at this). Also generally speaking you get great support from the websites themselves should you have any difficulties.
Best of luck,
Tristan
tsang1101 is offline
Closed Thread DIY Speakers and Subs
