frontfiring or downfiring for sealed??? - AVS Forum | Home Theater Discussions And Reviews
Old 02-19-2006, 03:18 PM - Thread Starter
crackyflipside's Avatar
Im going with a 12" sevo sub and I would like to know which placement of the driver is better for home theater with a sealed enclosure?
Front firing
http://www.stealthsoundsystems.com/SUB-12A.jpg
Down firing
http://www.3dsoundsurge.com/reviews/..._bottom_sm.jpg
crackyflipside is offline
Old 02-19-2006, 04:31 PM
bobgpsr's Avatar
A bit tongue in check ---- downfiring is better for less intermod (doppler) distortion. ;)
Another factor is that the cone is safely out of the way --- from tots.
More serious is that all subs will eventually sag so some opine that not down/up firing is better for longevity. And gravity takes the center of the voice coil out of its most optimum neutral position, thereby sacrificing some Xmax (which can make it more subject to distortion at max power/SPL levels).
bobgpsr is offline
Old 02-19-2006, 05:37 PM
Darin's Avatar
FWIW, I did the calculations to figure a driver's suitability to vertical mounting for the TC sounds drivers the Rythmik kit uses, and they were WELL within the acceptable "sag" limit. Can't remember the exact amount, but it was at LEAST 1/4 the "acceptable limit.
My dual Rythmik Servo sub project (actually quad now, need to update page)
HDM format neutral thanks to the pricing wars of the '07 xmas shopping season :)
Darin is offline
Old 02-19-2006, 05:49 PM
kramskoi's Avatar
Liked: 27
as noted, their may be some miniscule drawbacks to down-firing but i think it's more a matter of aesthetics. The subwoofer operates over such a limited range (especially depending on the x-over point and slope) that doppler/IM distortion, though real, is almost negligible in the real world. Personally, i've always been fascinated with watching the driver push and pull. ;)
"Frequency response is NOT efficiency response."
Klipsch RB-35's main
Klipsch RB-35's surround
Acoustech HT-65 center
Cerwin-Vega CV-2800
Subwoofer
B&C 21SW152-4  [21" critical-Q]
kramskoi is offline
Old 02-19-2006, 07:47 PM - Thread Starter
So very true. I see myself going the front firing route for aesthetics also, but I also cant stand seeing those cloth grills covering up the perrty drivers. :D
