Black Speaker Finish! What do you use? - AVS Forum | Home Theater Discussions And Reviews
Old 02-20-2006, 03:57 PM - Thread Starter
LordContrary's Avatar
Title says it all....
I am making speaker stands and a rack for my goodies... I want them to have the same finish as my speaker set ( Onkyo HT-S780 )... but I am having limited luck finding a black finish... what do you use?
I found only a single dye ( rockler )... other than that I have had no luck at all... I do NOT want a black paint. I want to see the wood grain, so stains and dyes are in.
-LordContrary
LordContrary is offline
Old 02-21-2006, 09:03 AM
JZ50's Avatar
I used Minwax Ebony stain. Home Depot does not carry it but some local hardware and lumber yards will stock it. Takes several coats to get it really dark. You might also try diluted black paint wiped on with a rag.
JZ50 is offline
Old 02-21-2006, 03:37 PM
Jack Gilvey's Avatar
Quoted: 35 Post(s)
Liked: 34
I've not done a black stain. For a cheapo "piano black", I used a laminate. Did the PR's, too. This one's a little beat up at this point, my first and only attempt:
http://home.comcast.net/~tgilvey/IMG_0786.JPG
Jack Gilvey
SVS Customer Service
Jack Gilvey is offline
Old 02-21-2006, 05:55 PM - Thread Starter
I have deep ebony ( bought from lowes? not sure ) ...but even with several coats it's more like a chocolate bar color. I used it on a bird stand i made for the lady next door. It's nice but not black. :)
Old 02-21-2006, 06:06 PM
ericgl's Avatar
Quoted: 25 Post(s)
Liked: 24
http://www.woodfinishsupply.com/PLaniline.html
I don't think stains are going to get you where you want to be.
ericgl is offline
Old 02-21-2006, 07:42 PM - Thread Starter
Thanks for the link... looks like a good place to start.
Old 02-22-2006, 12:24 PM
cobbpa's Avatar
I've read about people using high-gloss industrial enamel, found at most local hardware or paint stores.
cobbpa is offline
Old 02-23-2006, 03:23 AM
Vinculum's Avatar
Quoted: 13 Post(s)
How about the industrial black "speckled" look. Anyone know whats used to do that? Maybe some textured paint from Home Depot?
Jack, Thats a nice lookin' box... you even "tuned" the PRs with the laminate! Do you have a link to the details of your build?
Dr V
Vinculum is offline
Old 02-23-2006, 05:21 AM
cobbpa's Avatar
I think the speckled look comes from spray paint w/ flecks in it. Never used it, but I'm pretty sure that's what I've seen.
cobbpa is offline
Old 02-23-2006, 05:55 AM
Quoted: 35 Post(s)
Liked: 34
Thanks. Nahh, no links to the box, sorry. ~62L marine ply cube which the 1400g PRs (Lambda) would tune to 24Hz or so. The lam would add a bit of weight, but I think I confimed Fb at around what was predicted.
Jack Gilvey
Old 02-23-2006, 08:00 PM
micagreenmachine's Avatar
I think I found what you're looking for...
micagreenmachine is offline
But can't post a link....
Old 02-23-2006, 08:01 PM
Until I have
at least 5
Old 02-23-2006, 08:02 PM
posts under my belt...
Old 02-23-2006, 08:04 PM
Try here (bottom of page) or here (middle of page).
They used black analine dye over oak veneer. I like the look and may have to give it a shot.
HTH,
-todd
Old 02-24-2006, 08:09 AM
stoli147's Avatar
Here's what Jim Salk used for some HT3's. It was a 'Pearl Grey' aniline dye.
http://www.salksound.com/gallery-votm-1105-1.html
stoli147 is offline
Old 02-24-2006, 02:56 PM - Thread Starter
Thanks so much for the info.
Looks like the analine dye is what i was after... I want the grain to show thru... oh and nice work everyone... those speakers look great!
-lordContrary
Old 02-26-2006, 06:33 AM
jsalk's Avatar
Quoted: 41 Post(s)
Liked: 135
Lord -
If you want the grain to show through, analine dye is the only way to go. Stains are pigments that mask the grain. Analine dye is basically transparent. I would suggest alcohol-based dye as the water-based versions tend to raise the grain of the veneer.
I usually thin mine out pretty much so I can put on multiple coats until I reach the color I am looking for. This is less risky than trying to do it all in one pass. This is especially important with black since you can get it so black it is no longer transparent.
If you want to end up with a high-gloss topcoat, it may be a good idea to use multiple coats of sanding sealer until the grain is filled and the surface is completely flat. They use the dye and finally clear top coats that can eventually be rubbed out.
If you do not have spray equipment, you can use cans of gloss nitro lacquer. You will need about six coats or so. This will then need to cure for a week to 10 days and you can then rub it out to any level of gloss desired.
- Jim
SalkSound.com
Custom-crafted Speakers
jsalk is offline
