Small DIY Sub - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-21-2006, 08:44 AM - Thread Starter
JZ50's Avatar
I know it's not a very popular idea on these forums, but has anyone come up with a small musical sub similar to the HSU SF-1 or Outlaw LFM-2. Is it not cost effective or does everyone just want a bigger bang for the buck? I was trying to build something small for my in-laws mid-sized TV room.
JZ50 is offline
post #2 of 3 Old 02-21-2006, 11:05 AM
porterhaus's Avatar
If a kit is something you might consider... the 10" Titanic MkIII kit from Parts Express is very easy to assemble. It is very good for music. I have one and believe it is one of the best bang for the buck deals around.
If you remember the 70's...you weren't really there!
porterhaus is offline
post #3 of 3 Old 02-21-2006, 12:21 PM
crackyflipside's Avatar
It sounds like you are describing a servo sub ;)
Small sealed enclosure. 12" long throw driver. Selectable damping. Flat as a ruler to 10hz.
http://www.hometheaterhifi.com/volum...er-4-2004.html
The least expensive kit there can be had for $350 and shipping.
crackyflipside is offline
Closed Thread DIY Speakers and Subs
