? Converting Car Sub Woofer box for Home Theater use? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-22-2006, 10:45 AM - Thread Starter
MColeman's Avatar
I've been looking at a bunch of different subs and such. And have found that the pawn shops are Over Loaded with a bunch of these car audio sub boxes.
Question:
Let's say I bought a Sub Box with 2 14 inch Subs. And then installed a Home theater amp inside (or outside) the box. Woud this be of any good use for home theater stuff? Has anyone tried this yet?
MColeman is offline
post #2 of 5 Old 02-22-2006, 12:18 PM
rlj5242's Avatar
Quoted: 48 Post(s)
Liked: 40
I've never seen a 14" sub. Standard sizes are 10, 12, 15, 18.
Will it work? Probably not. Those pawnshop subs are not going to use high quality drivers and if they do, the boxes are designed to work in a car and not a home. For example, an older Adire Shiva will work great in a car when mounted in a 1cf box. Recommended home enclosures for the Shiva are 3 to 5 times larger. It's all due to physics and Hoffman's Iron Law.
-Robert
rlj5242 is offline
post #3 of 5 Old 02-22-2006, 07:44 PM
Jester 2's Avatar
Well i have 2 (12 inch) MTX thunder subs in a sealed (car type ) encloseure and they hit hard enough for me . IT is cheap, they are abundant , and for an entry level it is great. I am sure ppl will disagree but for the cost a sub is a sub . I use a 100 watt sony reciver to power them thru the sub out and am quite pleased.
Never let someone tell you its too cheap to work .... you gain more valuable experience if nothing else.
Any other questions feel free to ask
Just my 2 cents
Jester 2
Jester 2 is offline
post #4 of 5 Old 02-22-2006, 07:50 PM
rlj5242's Avatar
Quoted: 48 Post(s)
Liked: 40
If you have the budget to play with and want to learn, then it is great. I know I've gone through my share of Pyramid and Pyle subs.
-Robert
rlj5242 is offline
post #5 of 5 Old 02-22-2006, 08:18 PM
BlakeN's Avatar
If you could get a lot of the same sub realy cheap (like 6 to 10) you could make a line array subwoofer. With some eq it might be fun.
BlakeN is offline
Closed Thread DIY Speakers and Subs
