A question about Adhesives and enclosure bracing. - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 02-26-2006, 08:31 PM - Thread Starter
Exocer's Avatar
Heres the design so far with the current wood I already have cut. Keep in mind this drawing took 2 seconds and is a VERY rough draft.
http://i9.photobucket.com/albums/a79...typeDayOne.jpg
I plan to add Piece C to the mix. Piece C will be an 18.5" square of 3/4" MDF to overlap Piece A on the top and bottom, and the side walls. I'll need four pieces total. Any approval will help, making the trip to HD or Lowes tomorrow to get some more pieces cut. Thanks guys! you've been great! Any other thoughts?
Edit: Now i see the similarities to rabbetting..
Only time will tell what the future holds...so until then JAM LIKE THERES NO TOMORROW!
-Rob
My Natalie P project
Exocer is offline
Old 02-26-2006, 09:59 PM
fraDcat's Avatar
I got a dumb question. It seems like most of the shelf bracing I see uses square cutouts. Why not use a router with your circle jig? For those without routers I understand. Is it so the braces take up less volume?
Just something I've always wondered about is all.
fraDcat is offline
Old 02-27-2006, 06:21 PM - Thread Starter
Exocer's Avatar
fraDcat, I dont think it matters either way, round or square would be good.
-Rob
Exocer is offline
Old 02-27-2006, 09:33 PM
GeorgeHolland's Avatar
Quoted: 45 Post(s)
Liked: 46
I took the circle “route†myself.
http://www.pbase.com/georger/image/56628886.jpg
http://www.pbase.com/georger/image/56628904.jpg
GeorgeHolland is offline
Old 02-28-2006, 02:55 PM
steve nn's Avatar
Liked: 433
Darn nice circles to! :)
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
Old 03-02-2006, 10:03 PM
irfan's Avatar
clever idea with the feet there!
irfan is offline
