A question about Adhesives and enclosure bracing. - AVS Forum | Home Theater Discussions And Reviews
Old 02-22-2006, 05:16 PM - Thread Starter
Exocer's Avatar
Hey guys,
I am in the process of building a 2cu sealed cube enclosure first DIY project. The MDF is sitting downstairs in the living room and cut to proper dimensions. Some guy at the local lumber store suggested "Polyurethane Premium Construction Adhesive" for glueing my 3/4" mdf together. Is this ok or should i return it for some elmer's wood glue? Also, do i need to purchase a sealent like silicon filling to make sure things are airtight if i do end up using the polyurethane adhesive?
And about bracing...is bracing a 2cu enclosure THAT important? So far, this is my plan. I have two peice of MDF cut to 17"x17" for the top and bottom. The side pieces are cut to 15.5"x17" to join the top and bottom pieces. I have two more peices cut to 15.5"x15.5" for the front and back. The driver and amp will be installed into the smaller 15.5" squares. How do i go about bracing this box without using too much internal volume? I have a lot of unused MDF, so I want to make some use of it.
Here is all the wood i have available for the enclosure:
a total of 4 peices cut to 17"x17", 2 peices 15.5"x17", and two peices 15.5"x15.5".
Only time will tell what the future holds...so until then JAM LIKE THERES NO TOMORROW!
-Rob
My Natalie P project
Exocer is offline
Old 02-22-2006, 06:07 PM
whphel's Avatar
For all my speaker boxes I always (you dont have to) screw and glue. I glue with elmers wood glue and counter sink holes for screws and you can build your box or boxes faster. I always also use silicon caulk for all seams on the inside just to make sure to be air tight. Also 1lb of fill for every cf of box area.
Oh by the way if you go thr glue and screw method the best filler for the holes is bondo. but make sure to get any of the sawdust in the holes with an air compressor. And avoid wood putty if you plan on doing any veneir. Standard wood putty has been known to work loos and cause bubbles.
whphel is offline
Old 02-22-2006, 06:24 PM
Jack Gilvey's Avatar
Quoted: 35 Post(s)
Liked: 34
The various wood glues are more than strong enough, but the poly glue (I use Gorilla Glue) will expand to fill gaps so you don't have to use caulk, sealer, etc. A pain to use compared to everything else, though, so as my cuts have gotten better (thanks to a table saw), I've gone back to Titebond or Elmers' for ease of use and cleanup. I don't use screws, just lots of clamps.
Stick some crossbraces in to tie opposite sides together, should be fine.
Jack Gilvey
SVS Customer Service
Jack Gilvey is offline
Old 02-22-2006, 06:31 PM - Thread Starter
Exocer's Avatar
Cool, thanks. Im thinking about possibly doubling the thickness of the mounting area for the driver.I'll have one peice of 15.5"x15.5" wedged as the first layer, and since i have an extra sheet of 17"x17" i'll glue this to the 15.5"x15.5" piece to re-inforce the driver mounting area (which seems important.
Jack when you say you use lots of clamps, do you mean something like a furniture clamp to hold things together (with the help of crossbraces) to hold things in shape while the glue dries? And also, for a first project, would it be smarter to just go the elmer's glue method and then use the Poly glue to make sure things are air-tight?
-Rob
Exocer is offline
Old 02-23-2006, 08:04 AM
doatis's Avatar
Poly glue (such as Gorilla or other brands) is great stuff. Applied properly you will have a strong joint for centuries.
A word of caution. . .Yes poly glue does expand (which can help fill joints), however it expands with significant force. If you go too crazy on the amount of glue or do not have your joints clamped or screwed firmly during set-up, the poly glue may actually force the joint apart as it sets-up and expands.
Bondo or a similar 2 part auto body filler makes a great filler on joints, screw holes, and various mistakes. It is quick and strong and most importantly, very easy to machine and sand smooth. Since you are going to laminate or paint the box you don't have to worry about tiny cosmetic boo-boos- that’s what the filler is for.
Handle the joints however you want. Screws (give square drive screws a try- it will make your life much easier) are great for putting the box together and holding while it sets. Remember that MDF is tricky and it is easy to 'strip out' screw holes. Be sure to pre-drill and counter sink. Sock down the screw enough to pull the joint tight but don't over tighten- the screw will pull the MDF apart around the hole. MDF is wonderfully strong, dense, and stable. It is, however, very weak when it comes to holding fasteners. (Give biscuit joining a try as you progress).
As for doubling up the front panel- go for it. If you double-up panels you can stagger-step the joints (sort of like rabbetting single panels) and get a much stronger joint. Be sure to leave some room around the driver so it can 'breath'. Lots of folks bevel the inside layer or cut the inside hole a bit large than the driver to give some room.
More important than just panel thickness is to cross brace as Jack suggested. A couple or 'shelf' braces or simple scraps across the inside adds a lot of strength.
Good luck and share your results.
doatis is offline
Old 02-23-2006, 09:53 AM
Quoted: 35 Post(s)
Liked: 34
yeah, just till the glue dries. These are my clamps, I could probably use a few more:
http://home.comcast.net/~tgilvey/IMG_0802.JPG
It's certainly cheaper to screw and glue, some of them weren't cheap and it probably wouldn't make sense for a single project.
Elmer's wood glue and sealant would be easier, I wouldn't bother using both Elmers and the poly.
Jack Gilvey
Old 02-23-2006, 10:07 AM
KANDREWS1Z's Avatar
liquid nail and screws has always worked best for me i use to build custom speaker boxes for car audio.
KANDREWS1Z is offline
Old 02-23-2006, 10:11 AM
KANDREWS1Z's Avatar
build your box first and then go back and seal the seams inside the box where the wood meets.make sure you cut the whole for the speaker before building the box.
Old 02-23-2006, 03:40 PM
derekbannatyne's Avatar
Is it alright to use finishing nails instead of screws?
derekbannatyne is offline
Old 02-23-2006, 04:36 PM
bobgpsr's Avatar
You can remove the screws after gluing if you are then going to use a router to round off the edges. After routing put the screws back in. Just a hint that I read elsewhere.
Bob
bobgpsr is offline
Old 02-23-2006, 05:03 PM - Thread Starter
Exocer's Avatar
Thanks a lot guys!, so the order is to screw then glue? or to glue then screw (before things harden)?
Doatis, when you say shelf braces, you mean metal L joints correct? I have a lot of extra MDF...but id rather use it for my next project and it would be easier to just buy some shelf braces than to cut MDF to the right size.
-Rob
Exocer is offline
Old 02-23-2006, 05:15 PM
Quoted: 35 Post(s)
Liked: 34
I would screw the box together first, making sure it all positions perfectly. Back the screws out, glue it up, then the screws go back in quickly and are just used as clamps really, holding it together while the glue dries.
Here's an example of shelf bracing from Dan Marx:
http://www.danmarx.org/audioinnovati...ics/Image7.jpg
It typically ties four sides together, and is not to be confused with braces for shelves. :)
Jack Gilvey
Old 02-23-2006, 06:41 PM
doatis's Avatar
Yeah - What Jack just posted is an excellent example of shelf bracing.
However, if that looks like too much work- don't worry. Even just using scraps of plywood (plywood do to its being constructed of mutliple layers with the grain running in different directions tends to be pretty stable- its just though to screw into the ends of it) or hardwood is better than no bracing (although its generally better to stick to the same material- the reasoning being then at least you should have similar rates of expansion and contraction due to humidity changes- but not a huge deal) .
Use MDF if you can but scraps of hardwood are good and even pine is better than nothing. It doesn't have to be pretty, just functional. The bracing is there to keep the walls of the box from flexing do to changes in internal pressure.
Metal 'L' brackets or metal corner braces won't do. For the same reasons I described above- its hard to fasten them into MDF. 'L' brackets are mainly designed to secure the joint. That shouldn't be a problem if you follow the advice posted by others. The joints (or corners) of your box won't be the problem. The weak point will be the big square or rectangular walls of the box. They will want to bow out under pressure, like blowing air into a milk carton (or a soymilk carton for us vegans). A simple pice of 1 x 4 going across the interior will probably provide more support than 10 metal corner braces. Four pieces of 1x4 (2 from front to back and 2 from side to side), glued and/or screwed to each other where the intersect at the center of the box is easy to do and will make a big improvement. The example posted by Jack is great but it would be just as good, instead of cutting the brace from a single piece of MDF, to glue it together with rectangular strips of MDF. It won't be quite as slick but it will do the job fine.
Remember to subtract the volume of the braces from the box volume when designing.
doatis is offline
Old 02-23-2006, 07:39 PM
---k---'s Avatar
Tightbond glue worked a lot better forme.
I would apply the glue, fit the box up, clamp tight, then add additional screws to hold the box together because I didn't have enough clamps, and because I don't trust glued joints, regardless of what eveyone here says, and then let dry. Make sure you are doing this in a heated space right now.
Don't buy clear silcone sealant for inside. You won't be able to see it as you apply it. Trust me. :)
Don't use liquid nails, the multi purpose one doesn't fully harden and remains slightly flexible.
---k--- is offline
Old 02-23-2006, 07:59 PM - Thread Starter
Exocer's Avatar
---k--- thanks, got it.
Also, I planned on countersinking the holes today but couldn't find my dremel tool ANYWHERE. Would there be any other alternatives? I do have a power drill handy.
-Rob
Exocer is offline
Old 02-23-2006, 10:23 PM - Thread Starter
Exocer's Avatar
Jack, that looks professional lol. It just looks like a lot of work to do such a clean complex cut on the MDF bracing (my cuts suck!)How does a few small rectangular strips of MDF along the seams sound?
Also, I already have a box of 3" lumber screws in the basement, are these WAY too long for this project?
Also about volume, My goal was to keep things at around 2cu but I can settle for about 1.8cu. With a lot of bracing I'll be around 1.8 Cu i assume. So things should work out okay.
-Rob
Exocer is offline
Old 02-24-2006, 05:14 AM
Quoted: 35 Post(s)
Liked: 34
doatis' post says it all, the problem won't be the seams, it'll be the larger unsupported spans.
And screws are great as clamps if you don't have enough clamps. Once dried, a glued joint is stronger than the wood itself, so you can pull the screws out at the point if you need to (if you can't countersink).
Jack Gilvey
Old 02-24-2006, 07:20 AM
hoggy's Avatar
I've built a few dozen boxes in the last 6 years or so and have always used liquid nails and brad nails. The brad nails holds the box together enough till the liquid nails dries and its worked great until the past few month, I started using titebond and elmer's. I like it a lot better, but I still bust out the liquid nails if I have a little extra gap. I've found that wood glue only works good if you box fits really close to perfect, anything beyond that, use liquid nails. Lots of people will tell you to use screws instead of nails, but the screws or nails don't hold the box together, the glud does.
hoggy is offline
Old 02-24-2006, 07:41 AM
---k---'s Avatar
---k--- is offline
Old 02-24-2006, 08:50 AM - Thread Starter
Exocer's Avatar
----k----, thanks, you've been very helpful.
My floorspikes, polyfill and acousta-stuf came in today. Since I have no class or work today i'll have some time to get things started. I will be practicing on some scrap pieces of MDF first, to get more comfortable with the process. Will report back how everything turns out later today.
Must make it to lowes to get that drill bit. I am also going to buy shorter screws. Looking online, the recommended for the enclosure seems to be about 2".
Actually, I am looking to buy a cheap router. I dont need one with lots of HP but something that would be more than adequete for flush mounting the driver to its 1.5" thick panel as well as cutting the opening for the amp.
Update: Im ditching the poly adhesive for Elmer's wood glue and silicon caulk sealent at this point. Just because wood glue seems easier to deal with, and this is my first DIY project.
-Rob
Exocer is offline
Old 02-24-2006, 06:01 PM - Thread Starter
Exocer's Avatar
I've decided on a 1.5" mounting wall for the driver. The first layer will be 15.5"x15.5" and will fit perfectly between the top bottom and side walls. From here I will place a 17" square on top of the 15.5" square to double the thickness of the mounting area. Basically the box will be simple. Two peices of MDF for the front, and one for all the sides. Once I choose a router i'll be able to get things started...
Do I have to cover all of the internal walls with some type of sealent or is it ok to just seal the seams?
-Rob
Exocer is offline
Old 02-24-2006, 06:09 PM
thylantyr's Avatar
Sealing the seams is only used when the woodworker makes errors in construction.
If you didn't error and sealed the seams anyways, then it's still ok but you are
just doing another step that you don't need. If you cut your wood straight and secure
it properly, the joint will be stronger than the wood itself.
To clarify, when you use yellow wood glue {Elmers, Tightbond, etc}, you apply
a generous amount and wipe off excess with a damp rag, use your finger to
clean the edge of the excess glue and it should be sweet.
The storm was gone, but dark clouds still hung around
The perfect setting for things to come......
thylantyr is offline
Old 02-24-2006, 08:22 PM - Thread Starter
Exocer's Avatar
Thanks for that.
http://www.acehardwareoutlet.com/(v5ai30u3oxlonl45iyi5p355)/productDetails.aspx?SKU=1200658
ok caulk for this project? assuming i make a few mistakes here and there. There are just so many different types of caulk out there. ----k----, you suggested not to get a clear caulk, however, should i make sure it is 100% silicon? The one i have linked above says it adheres to wood, which cant be said about the 100% silicon caulk products i've looked at online. The local hardware store was of no help, he just wanted to make a quick sale...
-Rob
Exocer is offline
Old 02-25-2006, 05:27 AM
Quoted: 35 Post(s)
Liked: 34
If you use silicon, make absolutely sure it's completely cured before installing the driver. The fumes given off can act as a solvent.
Jack Gilvey
Old 02-25-2006, 07:57 AM
steve nn's Avatar
Liked: 433
With the two subs I've built so far, I have found this method to be very effective. It only works if your going the double wall, so I guess it doesn't apply for your project. When a guy applies the veneer (or some other covering) it adds to the integrity of the seal. I did glue the inside seems for extra measure though. It sure is a good feeling when you load the driver for the first time and push it in looking for resistance..That sounds kind of odd, but you'll understand:). The extra room around the driver sure comes in handy like mentioned, along with a extra 6-12" on your lead...a little wriggle-room makes adjusting the fill and getting at the driver much more pleasant.
Going extra thick on the baffle is a good idea.. you'll be glad you did.
You want a plunge router. I made the mistake of not getting the plunge and had to take it back. I just went with a RYOBI at HD...cheap but effective. If this is going to be a one time project?.. you could probably barrow one no?
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
Old 02-25-2006, 08:00 PM - Thread Starter
Exocer's Avatar
Well steve, I doubt this will be my last project as I am already considering a DIY center for my 4 NHT sb2's. So maybe I should get a decent router? I just want something that will work well with the Jasper jig. That jig looks like an incredible tool for cutting professional level cuts for a flush mounting area for the driver as oppose to sitting on the front baffle (like most sunfire subs for example, this is what i mean by driver sitting on top).
There is however a local place that rents tools out, i'll have to see how much it'll run me before making a decision.
Edit: I dont understand a lot of the technical terms like "rabetting a joint" for example (had to go look that one up in an online dictionary lol, it even had cool diagrams to explain...). If it is even possible, can you guys try and explain this type of stuff for me in layman's terms? :D
Rabbeting a joint is almost out of the question at this point isnt it? since everything has been cut to accomadate standard joints wouldn't the rabbeting decrease overall internal volume significantly?
-Rob
Exocer is offline
Old 02-26-2006, 10:34 AM
steve nn's Avatar
Liked: 433
Is this what you mean by flush then? ;) One more 1/2" panel was added to the baffle after the two 3/4" panels set up which is pictured.
http://i3.photobucket.com/albums/y75...n/100_0819.jpg
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
Old 02-26-2006, 11:21 AM
Quoted: 35 Post(s)
Liked: 34
From experience, I'm not big on buying cheap tools. If you're really never going to use it again, see about renting. The Jasper jigs are great, great tools. I have all three models but the middle size never leaves my router:
http://home.comcast.net/~tgilvey/IMG_0809.JPG
The router's a DeWalt 621, which is a perfect plunge model for speaker-building (size, handling, dust-collection, power) and the compatibilty of which I made sure of with Jasper prior to purchase. There are other great ones, and you'll be glad you bought quality each time you use it.
Jack Gilvey
Old 02-26-2006, 05:38 PM - Thread Starter
Exocer's Avatar
This is exactly what I mean by flush. Is it necessary to add that 1/2" panel? If so, it isnt the end of the world...Also, at this point I am thinking of double the side panels too, to overlap the 15.5" x 17" panels with a bigger sized peice of MDF (not calculated yet) I wish i could use a program to further explain what i mean. I was this this to be built like a tank when done... Got my countersinking drill bit today and acrylic caulk in case of mistakes. I need the router, but I'll order that around the same time as the servo kit. I feel uncomfortable making cuts without the driver and amp already in hand.
-Rob
Exocer is offline
Old 02-26-2006, 06:59 PM
steve nn's Avatar
Liked: 433
Actually.. no it's not. Cone excursion will travel beyond, but you should be sitting pretty good. With me using the SS 15" RL-p D2 drivers, I added the third layer on the baffle more for strength.
A very good practice. It's not absolutely necessary, but it sure wont hurt. It'll only add to the integrity of the unit.
Looks like your getting close then. With overlapping the joints with your second layer, you should be pretty sealed up.
I can certainly understand that.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
