A Center Channel Project - AVS Forum | Home Theater Discussions And Reviews
Old 02-24-2006, 07:56 PM - Thread Starter
LOW-FI's Avatar
I was in need of a new center channel speaker and had some time over the holidays to do a little DIY. The cabinet is white oak which works well and makes
for very stable cabs. I took a few liberties with my design while holding to the
specified volume.
The finished product was quite pleasing to both the eye and ear. Plans for this and other projects can be found here ; http://www.partsexpress.com/projects...ure/index.html
speaker pics at : http://community.webshots.com/user/roserbd
LOW-FI is offline
Old 02-25-2006, 06:58 AM
V.X.Donique's Avatar
Quoted: 52 Post(s)
Liked: 45
Very nice job indeed!
How long did it take you to complete that project? Kudos on the craftsmanship.
V.X.Donique
Introducing the Vier Systems Xero.1/Midbasiks Subwoofer builds....
Creator of the AVScience DIY Speakers and Subwoofers Forum
"Don't concentrate on the finger or you will miss all that heavenly glory." -Bruce Lee
V.X.Donique is offline
Old 02-25-2006, 07:29 AM - Thread Starter
LOW-FI's Avatar
About 2 weeks on and off , it took longer to get the x-over parts then put the box together.
LOW-FI is offline
Old 02-26-2006, 07:19 PM
PGPFan's Avatar
LOW-FI,
What speakers are you using for your mains? Overall, if you had to make this center all over again, would you? What might you do differently?
I'm seriously considering this as well, but I'd like to make the cabinet depth as small as possible.
-PGPfan
PGPFan is offline
Old 03-02-2006, 07:01 PM - Thread Starter
LOW-FI's Avatar
I'm currently working out my next set of mains. This speaker is strong enough
and powerful enough to be used as your mains also. I would simply move the
ports to the front or rear panel. You won't be sorry you built this speaker, it isn't
the cheapest out there but you reap the rewards for the buck spent.
LOW-FI is offline
