Inside stuffing, what is the best? - AVS Forum | Home Theater Discussions And Reviews
Old 02-26-2006, 06:16 AM - Thread Starter
crackyflipside's Avatar
Fiberglass, rigid or in batts?
Foam, egg crate or flat?
Which would be best in a sealed enclosure?
crackyflipside is offline
Old 02-26-2006, 08:14 AM
bimmerboy750's Avatar
i use fiberfil... it's the white stuff that goes into pillows and quilts. get it at wal-mart. fiberglass makes me itch just looking at it.
Bimmerboy750
The Theorem theorem: If if, Then then
bimmerboy750 is offline
Old 02-26-2006, 08:57 AM
Darin's Avatar
I didn't stuff mine, I just lined it with fiberfill. Brian Ding @ Rythmik doesn't recommend stuffing, just lining. Seems that somewhere I read some detailed comments from him on this, but right now all I can find is what's in his FAQ, along with the recommendation on the main servo page to line the walls with 2" polyfill. I went to Hancock Fabrics, because there's one right by my office... they had quite a selection of both loose fill and batt type, but they didn't have any 2". I ended up using the thickest they have, which I think was 1.25-1.5", and lined all the interior walls with it:
http://home.comcast.net/~consumes/bass/top_lined.jpg
My dual Rythmik Servo sub project (actually quad now, need to update page)
HDM format neutral thanks to the pricing wars of the '07 xmas shopping season :)
Darin is offline
Old 02-26-2006, 09:31 AM
Jack Gilvey's Avatar
Quoted: 35 Post(s)
Liked: 34
I only use pure goose down due to the warm sound.
Jack Gilvey
SVS Customer Service
Jack Gilvey is offline
Old 02-26-2006, 10:25 AM
steve nn's Avatar
Liked: 433
Well I cant say I'm crazy about certain fills. In my short experience with fill, it seams as though adding fiberglass batts was a a little like eqing above the cross. Your not serious about the goose down though are you Jack? :) Your dryer than myself at times so who's to know? :o
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
Old 02-26-2006, 10:44 AM
Quoted: 35 Post(s)
Liked: 34
I'm occasionally asked "Jack, how do we know when you're being serious?" (I'm much drier in person). I always say "If my lips are moving...I'm kidding".
FWIW, I use "Acousta-stuff" I got from PE years ago. I move it from sub to sub as I get bored with them. :)
Jack Gilvey
Old 02-26-2006, 11:30 AM
thylantyr's Avatar
Depends on what you are doing. For woofers? For midrange? Are you changing
box volume ? Trying to mimimize standing waves? If it was ported, the recipe
could be different too.
The storm was gone, but dark clouds still hung around
The perfect setting for things to come......
thylantyr is offline
Old 02-26-2006, 01:29 PM
steve nn's Avatar
Liked: 433
Chuckle... :)
and again:)...Building a extra shelf out in the garage just to store enclosures seams very appropriate..no!
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
Old 02-26-2006, 06:22 PM - Thread Starter
How does 1.5" rigid fiberglass sound for lining the inside of the box.
Old 02-27-2006, 07:03 PM
Darin's Avatar
I wouldn't use rigid. It's too dense. It will end up reducing your effective internal volume, and may even cause some coloration due to less linear compression of the acoustic compression.
Darin is offline
Old 02-27-2006, 08:09 PM
steve nn's Avatar
Liked: 433
That has a nice ring ring to it Darin. :D
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
