BIG BOX sub – 85 feet^3 - AVS Forum | Home Theater Discussions And Reviews
Old 04-05-2006, 11:39 AM - Thread Starter
VasiliyK's Avatar
Idea is to build the sub between the screen and front wall. The room dimensions is 17’*16’*9’ so I decide to make a fake wall to mask the speakers and bass traps, put the screen on it and build the sub box inside that wall. The size of the box is 11 feet wide 8 feet high and 1 foot deep. For driving this sub I will use 4 of AV15 speakers
I'm in process of making the box and have a question – how much insulation(for sound absorption ) I’ll need to put inside?
Any help really appreciated! :)
VasiliyK is offline
Old 04-05-2006, 11:48 AM
ssabripo's Avatar
Quoted: 66 Post(s)
Liked: 35
good luck Vassily... :)
you don't need to muff the sound with too much insulation....for a box that size, a some foam with do well all around the inner walls (at around 1"). If you are going to use the "pink" insulation fiber used in homes (found at home depot, etc), then I suggest you use a single layer all around the inner walls again, and perhaps even take off 1/2-1/3 so that you dont over stuff it and cause the sound to be muffed.
although in a box that size you should be fine.
4 AV15's will be an IMPRESSIVE box!! :D I just got done with one, and can only imagine what 4 will sound like:
http://server4.ihostphotos.com/imgt/39017.jpghttp://server4.ihostphotos.com/imgt/39018.jpg
ssabripo is offline
Old 04-05-2006, 12:01 PM
BlakeN's Avatar
I suggest you brace the heck out of it. If your screen is attached and it vibrates at all your picture will be blury. Cool Idea though I cant wait to see it. Take lots of pictures.
BlakeN is offline
Old 04-05-2006, 12:17 PM - Thread Starter
VasiliyK's Avatar
Thanks SSABRIPO that helps. First I’m planning to fit 2 of AV15’s with the room to add two more later.
BlakeN - with those bracings the box will survive a direct hurricane hit :)
I’ll post some pictures later.
VasiliyK is offline
Old 04-05-2006, 12:39 PM
Tom Brennan's Avatar
Vented box? If so and if used as a subwoofer rather than a woofer you probably need no damping material at all inside the box.
Tom Brennan is offline
Old 04-05-2006, 12:50 PM
SightSeeker1's Avatar
Quoted: 16 Post(s)
I can't even imagine how loud that will be. LOL Did you model it to that size with software?
SightSeeker1 is offline
Old 04-05-2006, 12:55 PM - Thread Starter
VasiliyK's Avatar
It’s not vented and will be used as a sub. Thanks ;)
VasiliyK is offline
Old 04-05-2006, 01:07 PM - Thread Starter
VasiliyK's Avatar
I didn’t model it with software. Originally it was to be IB setup but when it come closer to built time I decided to use the space behind the screen. Also with the drivers located under the screen close to the main towers that plan helps with phase issue (i hope :D )
VasiliyK is offline
Old 04-05-2006, 02:21 PM
Thomas-W's Avatar
Quoted: 20 Post(s)
Cover all the interior surfaces with 6"-8" thick batts
Thomas-W is offline
Old 04-05-2006, 02:49 PM - Thread Starter
VasiliyK's Avatar
The total interior space will be 12in deep inside (13in external) so can’t use 6â€-8†for interior. :eek:
I’ll post some pics soon hope that will help. Thanks Thomas-W :)
VasiliyK is offline
Old 04-05-2006, 03:23 PM - Thread Starter
VasiliyK's Avatar
VasiliyK is offline
Old 04-05-2006, 04:10 PM
Even in a sealed box absorbent material is only needed if you want to "increase" the size of the enclosure.
At subwoofer only frequencies fiberglass batting or foam will not absorb sound and since no midrange material is being reproduced there's no need to absorb midrange sound waves.
Note that historically most IBs and vented systems that used batting used it to absorb MIDRANGE and upper bass reproduced by woofers (less it be reflected back to the cone and produce distortion) and that often only three of the six sides were lined, that being sufficient to kill midrange reflections.
Old 04-05-2006, 04:40 PM
M NEWMAN's Avatar
At 88 cu ft, its still an infinite baffle alignment as far as the woofers are concerned. Just a little less infinite than most IB setups, but your final box Qt will still be critically damped at .577 or less.
Mike
M NEWMAN is offline
Old 04-05-2006, 05:23 PM
Thomas-W's Avatar
Quoted: 20 Post(s)
Okay, go ahead and fill it up since the drivers will be so close to the rear-wall.
You're a little over 4 times summed Vas. That will bump the "Q" up by a multiplier of ~1.4. So not a Qts = Qtc situation, but it should sound much better than a small sealed box..... :cool:
Thomas-W is offline
Old 04-05-2006, 06:05 PM
SteveCallas's Avatar
Quoted: 142 Post(s)
Liked: 57
How deep are the drivers you are going to use? 1' depth seems like it may be a bit detrimental.
SteveCallas is offline
Old 04-05-2006, 07:47 PM
crippledchicken's Avatar
wow! that's bigger than my whole living room! :D
crippledchicken is offline
Old 04-05-2006, 08:32 PM
crackyflipside's Avatar
Freeking SPECTACULAR! Get those pics up or you will be greeted tonight by an angry mob!
crackyflipside is offline
Old 04-06-2006, 07:19 AM
Quoted: 16 Post(s)
How come some sub manufactures put insulation in their subs then? SVS comes to mind since someone posted pics of the plus 2 interior recently.
Not trying to argue, just wondering. :)
I lined my walls with the egg crate foam just because I saw some ported subs with it. Also EM reviewed the EP-500 and said he wished they lined all the walls instead of just the sides/top/bottom.
Old 04-06-2006, 10:20 AM
SS1----The use of absorbent material can give an increase in apparent box size, theoretically of 1.4 but Eargle says in actual practice more like 1.2.
Absorbent material can damp standing waves in an enclosure but only waves in an enclosure with a dimension equal to one or more wavelengths. Since a 100hz wave is 11.3' long very few subwoofers will benefit from such intended treatment.
However WOOFERS, which are often run up past the 1000-2000hz range can benefit from such treatment.
I think many people use stuffing without having thought out what the stuffing is intended to do or whether it can actually do what is intended.
Old 04-06-2006, 10:25 AM
Quoted: 16 Post(s)
That makes sense. Well hopefully it will act as an increase for me since I never calculated the port into my internal space when I started. Now only if my speaker will come in. Due tomorrow finally but we will see.
Old 04-06-2006, 11:45 AM - Thread Starter
VasiliyK's Avatar
Some pcs - like I sad : :)
Frame core - 2 layers of glued drywalls + frame support screwed to the studs
http://server4.ihostphotos.com/imgt/45655.jpg
Trying to put things together
http://server4.ihostphotos.com/imgt/45654.jpg
Supervisor
http://server4.ihostphotos.com/imgt/45656.jpg
What are you doing! take this one!!!
http://server4.ihostphotos.com/imgt/45657.jpg
Half way done
http://server4.ihostphotos.com/imgt/45658.jpg
Another point of view
http://server4.ihostphotos.com/imgt/45659.jpg
Glued corner
http://server4.ihostphotos.com/imgt/45660.jpg
Close view
http://server4.ihostphotos.com/imgt/45661.jpg
The glue
http://server4.ihostphotos.com/imgt/45662.jpg
Thanks a lot to everyone for the answers!
VasiliyK is offline
Old 04-06-2006, 12:26 PM - Thread Starter
VasiliyK's Avatar
Tom Brennan – thanks for the detailed explanation. Because the 'pink staff' is already in my house, I’ll put some (hopefully that will increase my apparent box size closer to the IB).
P.S. I will update this tread with new pics later.
VasiliyK is offline
Old 04-06-2006, 01:15 PM
PLincoln's Avatar
pink staff
i couldn't resist quoting that for posterity... :)
PLincoln is offline
Old 04-06-2006, 01:18 PM
PLincoln's Avatar
while it might increase the box size, another advantage of an optimal IB is that the rear of the driver is relatively far away from any walls/obstructions, allowing the rear wave to dissapte and not get reflected back into the driver
PLincoln is offline
Old 04-06-2006, 04:40 PM - Thread Starter
VasiliyK's Avatar
You are right. :confused: If I will not be satisfied with the results, I’ll go back to the IB setup :eek:
VasiliyK is offline
