noremacyug's sub (eclipse SW8200) - Page 7 - AVS Forum | Home Theater Discussions And Reviews
Old 04-09-2007, 08:39 PM - Thread Starter
noremacyug's Avatar
Quoted: 48 Post(s)
i retested with everything the same except that i tried out a max volume of 65 on the receiver and these are the results from that. what gives with the 40hz drop?
80hz - 102db
60hz- 106db
40hz- 84db
20hz- 101db (max volume attained was 61, 62 created distortion)
God Bless America
Guy
noremacyug is offline
Old 05-14-2007, 06:24 PM
Confusedsoul's Avatar
267.5 L
tuned to 15.35 Hz
6" round port x 29.17" long
is what i'm showing. but there really isn't much difference is there. i'm really tempted to use this subwoofer instead of going the SVS route. Cost would be similar to the 10" nsd with hopefully the performance of the 12" nsd or greater. Not sure which amp to go with though I know I wouldn't want to be spending more than 300$ on it. Another problem is Sonotube. The local UBC doesn't carry anything bigger than 16" and while hes got good prices on it, I don't know if he can get the bigger stuff nor whether he can order just one if thats all I want.
Confusedsoul is offline
Old 05-14-2007, 08:53 PM
TheEAR's Avatar
Originally Posted by noremacyug View Post
here's a pic of the damaged cone from my first go round.
OUCH the driver did reach some kind of limit! With sealed and no limiters and proper filters it is unfortunate but drivers can take a beating. Plus EQ boost often pushes the cone travel beyond its design limit...
I was wondering how a damaged looked,this will make me go mellow ....on my drivers.
Ask yourself mortal , do you have as much displacement as me ? The answer is no unless you have a Windmere fan sub.
TheEAR is offline
Old 05-14-2007, 09:09 PM
Willd's Avatar
Hey mon', you got the TC-3000 with Ti cone, no worries!
Willd is offline
Old 05-14-2007, 10:08 PM - Thread Starter
noremacyug's Avatar
Quoted: 48 Post(s)
yeah, the old driver took some abuse. i've managed to keep my current one in working order so far but would still like some info on getting the most output from it whilst still protecting the driver.
God Bless America
Guy
Old 05-14-2007, 11:00 PM
TheEAR's Avatar
Willd,
No problem mon. Forgot about them titanium cones .
TheEAR is offline
