noremacyug's sub (eclipse SW8200) - AVS Forum | Home Theater Discussions And Reviews
Old 08-17-2006, 09:01 PM - Thread Starter
noremacyug's Avatar
Quoted: 48 Post(s)
well, i'm one step closer to getting this thing built now. changed my plans of building a sonotube enclosure, i'm too impatient and don't really have the time to put into it. i've had my sub sitting on my bar merely 10ft from my couch starring me down for about the past week or two and i can't take it anymore. i'm working too much right now to even go get the sonotube, let alone the mdf, cutting, painting, sanding ect, ect..... so, i went the lazier and faster route by means of the Dayton prebuilt box from PE. i'd like to have done the sono design for something a bit different, but i have no probs with a nice big cube sitting in the corner.
in any event, i think i will be quite happy with the finished product.
i ordered
-3cuft dayton enclosure
-2 bags of acousta-stuf polyfill
-set of dayton chrome spiked feet
-pair of dayton doubled ended spring loaded binding post
parts i've already got
-driver is a eclipse sw8200 http://www.eclipse-web.com/sw8000/sw8200.html
-amp is a crest cpx900
will keep you guys posted on progress, try to snap a couple pics of the install and of coarse give my impressions on the finished product. thanks a million to all you guys who've guided me thus far in terms of driver selection, enclosures, as well as invaluable knowledge. i wouldnt have made it this far without you and it's much appreciated!!!
God Bless America
Guy
noremacyug is offline
Old 08-18-2006, 09:03 AM
Manamb's Avatar
Quoted: 35 Post(s)
That is the beauty of DIY, if at the end you are not 100% satisfied you can go back and try another option. Your Sub seems to be very good for both Car and HT application and at a good price for all its features.
Good luck and keep us posted.
Manamb is offline
Old 08-18-2006, 09:29 AM
SteveCallas's Avatar
Quoted: 142 Post(s)
Liked: 56
I think it is recommended that you add a bit of bracing to the standard PE subwoofer enclosure to mak eit a bit more rigid.
SteveCallas is offline
Old 08-18-2006, 11:13 AM
Exocer's Avatar
Hey, looking good! I just read this on your driver http://www.diymobileaudio.com/forum/...ead.php?t=4147 Seems like a winner Although Kyle says there was a misallignment issue with the tested driver Bl still looks extremely linear.
Only time will tell what the future holds...so until then JAM LIKE THERES NO TOMORROW!
-Rob
My Natalie P project
Exocer is offline
Old 08-18-2006, 06:56 PM - Thread Starter
noremacyug's Avatar
Quoted: 48 Post(s)
thanks guys. steve, what extra bracing would be required and how in the heck would i go about getting it in there? do the PE enclosures dissasemble?
God Bless America
Guy
Old 08-18-2006, 07:59 PM
Quoted: 142 Post(s)
Liked: 56
If the baffle doesn't come off, you're in trouble lol Yeah, the baffle should be removable, as you have to make your own driver cutout.
Old 08-18-2006, 08:11 PM
Willd's Avatar
I don't believe the baffle is removeable..at least nothing suggests that it is.
Willd is offline
Old 08-18-2006, 08:19 PM - Thread Starter
noremacyug's Avatar
Quoted: 48 Post(s)
that was my take as well. i just figured you marked your hole, jigsawed it out, stuffed it, ect, ect. hooked it up. to my knowledge the baffle is not removable.
God Bless America
Guy
Old 08-18-2006, 08:25 PM
Willd's Avatar
Yeah, thats what I have always thought.
Willd is offline
Old 08-18-2006, 09:29 PM
soho54's Avatar
It doesn't come apart. There is a thread somewhere with someone adding bracing, and they had to cut it just right to get it though the driver cut-out. It might have been at HTG. ?
soho54 is offline
Old 08-18-2006, 09:34 PM - Thread Starter
noremacyug's Avatar
Quoted: 48 Post(s)
well, good grief, that's a big part of why i bought the PE box. i figured it would be sufficiently braced.
God Bless America
Guy
Old 08-19-2006, 03:33 PM
Exocer's Avatar
You'll probably be fine without the added bracing however adding more wouldn't hurt. Make sure you have lots of acoustic stuffing, this thing needs as much Vb as possible.
-Rob
Exocer is offline
Old 08-19-2006, 03:45 PM
soho54's Avatar
There is no such thing in DIY. It isn't nessesary, but it couldn't hurt either.
soho54 is offline
Old 08-19-2006, 06:10 PM - Thread Starter
noremacyug's Avatar
Quoted: 48 Post(s)
i may try adding some bracing if i can do it without a lot of difficulty. as to the stuffing, i bought 2 lbs of the acoustastuff. that should be enough shouldn't it. i'm going for a volume of 3.6 cuft, which is what kyle (tcsounds) recommended to me. the acousta recommends .5lb per 1cuft.
God Bless America
Guy
Old 08-20-2006, 08:38 PM - Thread Starter
noremacyug's Avatar
Quoted: 48 Post(s)
alrighty, parts are suppose to be in tomorrow. i think i'll stop by the parental units abode and rob my dads cordless drill and his jigsaw. not sure i'll actually get started on it tomorrow night, but i very well may as i'm ready to see what that clips will do.
with that said, any installation advice from you gurus? any commonly overlooked details? anything i should do to make the enclosure airtight? as always, much appreciated fellas.
God Bless America
Guy
Old 08-21-2006, 07:45 PM - Thread Starter
noremacyug's Avatar
Quoted: 48 Post(s)
well, i got the sub all put together today. didn't take too long. as this is my first sealed sub i didn't know exactly what to expect. i might have been happier with a llt or regular vented enclosure as the output of this thing is not as much as i was hoping for. i was really dissapointed at first because the output was less than the 10" onkyo sub that came with the htib system. however, i don't have all the port noise that came with the onkyo.
i dunno, i threw a older 10 band eq in there and boosted the lower a bit which helped some. but still i was expecting a lot more. to achieve the levels i'm looking to get i'd prolly have to build 3 more.
also, i can't hardly even turn up the gain (bout 1/5) on the crest before auto clipping function kicks in. but even at that level i can notice the lights in the kitchen dimming a bit. from what i gather i shouldn't port this sub as it's not suited for it. any ideas guys? i'm either gonna have to build a few more of these, or build a massive critter like stevecallas' and some other members.
heres some pics i took today.
arrival
just unwrapped
making a hole
installing spikes
installing binding post
snugging her down
finishing up
clips sitting next to the onkyo
God Bless America
Guy
Old 08-21-2006, 07:58 PM
Willd's Avatar
Something isn't right. Are you sure your amp is in good condition and has zero problems? That driver should take a lot of power, and output fairly high levels, even in a sealed setup.
To clear things up, you are running the CPX900 in bridged mode, using the Channel A input, and the bridge outputs, right?
I don't think you have it wired properly. It should be putting out ~900W, and with that much power, the Eclipse should be moving pretty dang good.
Willd is offline
Old 08-21-2006, 08:13 PM - Thread Starter
noremacyug's Avatar
Quoted: 48 Post(s)
yup, bridged. unless i have the driver hooked up incorrectly as the manual (what i thought was the manual) doesn't address the proper way to hook it up in bridged mode. i'm pretty sure the amp is in good condition. the GCL led comes on during bass heavy sceenes and the clips is huffing and puffing as if it's getting plenty of power. i've tried it with the GCL turned off, tried it in stereo mode utilizing only one channel. everything i can think of. it does ok, but not what i expected. perhaps i have something set wrong, but i can't imagine what.
(edit) - huh, well, i just actually found the owners manual in a pdf. all this time i must have been looking at the spec sheet pdf thinking it was the owners manual (i sure thought it was a piss poor owners manual, ha. instead, i'm just an idiot).
heres the link, i'm going to peruse it right now to make sure i have everything right.
http://www.crestaudio.com/media/pdf/CPX_manual.pdf
God Bless America
Guy
Old 08-21-2006, 08:21 PM
Willd's Avatar
Yeah, I just downloaded it as well. What puzzles me, is that the manual tells you that for a bridged-sub setup, you should turn on the low cut filter for channel a, as well as the bridge-mode switch.
Eitherway...experiement, check out the manual, because there has to be something wrong. If the Eclipse had 900W of power running through it, "output" shouldn't be a problem. Extension, sure, but not output.
Willd is offline
Old 08-21-2006, 08:32 PM - Thread Starter
noremacyug's Avatar
Quoted: 48 Post(s)
well, i just read it and it looks that i have it all hooked up right. i tried switching the phase, made no difference. i didn't turn on the low cut filter, sounds like that's for pro speakers. i dunno, i still have the gain set to approx 1/5 and the gcl light will still come on durring bass scenes. the eclipse is moving like crazy and the output isn't terrible, just less than i want. perhaps i'm just expecting more than it's capable of.
God Bless America
Guy
Old 08-21-2006, 08:37 PM
crackyflipside's Avatar
I went through the same thing, an SPL meter will measure what you need better than your ears can. It could be you are just used to distorted bass. Clean bass has alot less impact than you would expect.
crackyflipside is offline
Old 08-21-2006, 08:44 PM - Thread Starter
noremacyug's Avatar
Quoted: 48 Post(s)
i have a radioshack analog spl meter. what kind of spl do you get out of your subs? do i set it to A or C weighting? i through away the manual for it long ago when i bought it, not a wise move. i've always set it to C scale with calibrating the sub though.
God Bless America
Guy
Old 08-21-2006, 08:49 PM
Willd's Avatar
What receiver are you using? Have you tried lowering the sub pre-out level?
Willd is offline
Old 08-21-2006, 08:55 PM
Quoted: 142 Post(s)
Liked: 56
At this stage you may not have it configured just right, but in the end, I think the results will still be similar if not the same. Not a whole lotta output and the amp will be clipping every now and then. You gotta give the horses a rest before climbing the hill
You'll probably wanna try removing the ELF LT circuit first to see if the regular sealed output will be passable, though I think even that might be kinda weak.
If you can salvage some money from this project, I'd definitely go LLT - keep the amp. I bet the sound quality will be a lot better than what you are imagining too. What's your budget?
Old 08-21-2006, 08:59 PM - Thread Starter
noremacyug's Avatar
Quoted: 48 Post(s)
ht-r530. yeah, i've tried maximum gain on the crest and low output on the lfe of the reciever, visa versa and then a medium. it was set on +10db on the reciever and then the 1/5 on the crest. i just bumped the crest up to 1/2 and recalibrated the reciever which changed to -5db.
i kind of went through this a long time ago, around age 14 when i got my infinity bu-2 sub. at first i thought it sucked, cause i cranked it all the way up and it was distorted and what not. after i set it up a bit, it sounded a lot better.
however, i've grown a bit and didn't start maxed out. this sub is doing ok, but i want a whole lot more. i seriously would probably need 3 or 4 to get where i'm wanting. 2 might cut it, but i dunno. i may just need to start over with a 15" design.
God Bless America
Guy
Old 08-21-2006, 09:04 PM - Thread Starter
noremacyug's Avatar
Quoted: 48 Post(s)
what's the ELF LT circuit?
budget wise, well, i have around $600 wrapped up into this. so somewhere around that total, provided i tackle a different design. one more identical sub powered by my current amp would run me around another $400.
God Bless America
Guy
Old 08-21-2006, 09:07 PM
Willd's Avatar
Steve - He is using an ELF LT circuit? I thought it was a regular sealed sub. If he is using an LT circuit, then it makes more sense why his amp is clipping so much.
And, IIRC, it is better to keep the output on the receiver lower, but the amp gain higher.
Willd is offline
Old 08-21-2006, 09:10 PM
Quoted: 142 Post(s)
Liked: 56
Oops, my fault, I confused him for Habs4Life. So many new project threads that I am slipping a bit
Old 08-21-2006, 09:16 PM - Thread Starter
noremacyug's Avatar
Quoted: 48 Post(s)
pull it together man!
God Bless America
Guy
Old 08-21-2006, 09:25 PM - Thread Starter
noremacyug's Avatar
Quoted: 48 Post(s)
the driver moves like crazy, i can't imagine it not having greater output. i still have a half of a bag of acousta stuff, but i can't imagine tossing that in there helping much.
(edit) - i kicked the output on the reciever down to -7db and cut back the output on the crest to bout 1/3 cause the amp was shutting down in some bass heavy scenes in batman begins.
God Bless America
Guy
