Sonosub + RL-p15 - Design confirmation - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 401 Old 11-17-2006, 06:09 PM
SteveCallas's Avatar
Quoted: 142 Post(s)
Liked: 56
There must be a big tolerance for what stores can classify as MDF, as that looks like particle board Rune
SteveCallas is offline
post #92 of 401 Old 11-17-2006, 06:16 PM
steve nn's Avatar
Liked: 433
That caught my eye also Steve. His sono is darn nice though! stout
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #93 of 401 Old 11-17-2006, 06:52 PM
ssabripo's Avatar
Quoted: 66 Post(s)
Liked: 35
Yo RUne.....what kinda wood is that? looks awefully close to particle board
ssabripo is offline
post #94 of 401 Old 11-18-2006, 01:20 AM - Thread Starter
RuneW's Avatar
That is 100% correct. Is particle board a bad idea for this paricular use?
I didn't think it would matter as long as I spackled/sanded it to get it smooth at the end. I didn't think this particular piece needed to as be strong or "dead" as MDF. I just happened to have some lying around.
Just to be perfectly clear this is NOT the material that I use for the endcaps. For the endcaps I'll use 22mm MDF.
My sonosub project pictures all in one place (PS! Norwegian text!)
RuneW is offline
post #95 of 401 Old 11-18-2006, 01:49 AM
Favelle's Avatar
Great pics guys!!!! Thanks for sharing.
Rune, I doubt it matters that its particle board for port flares. I can't see why is would matter.
In terms of LFE, size does matter!
Favelle is offline
post #96 of 401 Old 11-18-2006, 02:04 AM
steve nn's Avatar
Liked: 433
No, if it's just for the flares it wont matter at all. Don't let anybody tell you that it will. That was a close one though. You do want your caps as strong and as dead as possible, but then you know that.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #97 of 401 Old 11-18-2006, 07:33 AM - Thread Starter
RuneW's Avatar
Oh my God - did you guys think I was going to use 13mm particle board for the endcaps? No wonder you were concerned
RuneW is offline
post #98 of 401 Old 11-18-2006, 08:57 AM
steve nn's Avatar
Liked: 433
Not after your prior post. I think br C and Sherv were kind of worried because that's how they built their first subs. ..don't tell them I told you though. That Sherv can be a real hothead and I don't need the lecture from Steve C.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #99 of 401 Old 11-18-2006, 10:18 AM
ssabripo's Avatar
Quoted: 66 Post(s)
Liked: 35
well, after you clarified it, I was ok....you definitely need the end caps to be as strong as possible. Anyways, all is clear now
Not after your prior post. I think br C and Sherv were kind of worried because that's how they built their first subs. ..don't tell them I told you though. That Sherv can be a real hothead ........
LOL....are you sure you aint confusing me with your first sub? hehehehe ....dont forget before this DIY home stuff, I've been running the car audio/AISCA circles for years!
nah man, i'm pretty level headed, but two things just get to me...kinda like my red buttons: hard headed/closed minded individuals, and arrogant/pompous individuals....just doesn't fly with me. Other than that, I'm not a real hot head...heheheheheheh
ssabripo is offline
post #100 of 401 Old 11-18-2006, 12:10 PM - Thread Starter
RuneW's Avatar
I'll probably go for an EP2500, but a PA-guy recommended the Phonic Max2500 over the EP2500 (better build quality etc.). The price is about the same (or a little less, actually).
I've never heard about the Max 2500, but browsing through the manual I came upon this passage:
"Subsonic: Frequencies below 10 Hz contain high level of energy that can be harmful or stressful for many speakers. Since normal human listening range (is) from 20Hz to 20kHz, this unit comes with a feature that helps filter out any frequency that is below 10 Hz to prevent speakers from harm".
In addition the user can set a Hight Pass filter to PASS, 30Hz or 50Hz.
I'm not entirely sure what this 10Hz thing is all about. From what it says, it doesn't look like they write about a "natural roll off" for a typical amplifier, but more like some kind of active measure? 10 Hz may be a few Hz to low as a HP filter for my sub, but since the use of HP filters in LLT designs is debated anyhow, maybe this 10 Hz HP is exactly what I'm looking for?
I'm not sure if the EP2500 has something similar?
RuneW is offline
post #101 of 401 Old 11-18-2006, 12:51 PM
Willd's Avatar
If you're PA guy is right about the quality of that amp, then go for it. It looks good to me, but I've never heard anything about it.
Willd is offline
post #102 of 401 Old 11-18-2006, 12:56 PM
steve nn's Avatar
Liked: 433
I dunno? From what I here the 10 and 15 hz hing point doesn't make that much difference. I think that has to be specific to the sub in question though?? Anyway it is interesting and this is a new amp that I have never heard of..if anything it will help keep BEHRINGER on their toes price wise no?
OOPS! I forgot about that, I bow down to you then. Seriously though...I couldn't help pulling your chain, I'm getting kind of giddy thinking of all the subs I have slotted with whatever 18" driver I go with next. One thing we both know is RuneW is going to have quite a rig on his hands. I have had dual sono's in the same room, but only one hooked up. I know they/dual would come in a couple dB better than my 21 cu ft dual driver rig with better SQ to boot.
Your most likely planning on parting your subs 4-5' RuneW? If so, that should still put you very close to the dual driver rig that I built. Headroom will not be a issue even though it's imo that a single 15" option will provide much more than what many realise.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #103 of 401 Old 11-18-2006, 01:04 PM
Quoted: 142 Post(s)
Liked: 56
You gotta consider that the 10hz filter probably isn't a brickwall, it's just centered at 10hz. This means that the FR could be dropping before 10hz, and this could take away some in room extension - though a 15hz tuning might be high enough that it won't. It's also gonna degrade transient response - might not be audible, but it's defeating a fair chunk of the purpose of building a large and low tuned sub to begin with. I'd say take an in room FR measurement with it on and off, and decide from there.
post #104 of 401 Old 11-18-2006, 03:08 PM - Thread Starter
RuneW's Avatar
I don't think you can't turn it off... Maybe I'll stick to the EP2500. It's no big deal.
RuneW is offline
post #105 of 401 Old 11-18-2006, 03:11 PM
bossobass's Avatar
Quoted: 78 Post(s)
Liked: 667
Typical pro sound specs
It says that the low cut (HP) filter is at 10Hz. Assuming a 2nd order filter, it would be down 3dB at 10Hz and down 15dB at 5Hz.
But, the FR specs say that the 3dB down points are at 5Hz and 50KHz and the 20-20K specs are listed as (+/-) 1dB
The 10Hz HP is not user-defeatable, per the block diagram on page #15, so something isn't right.
Also, as usual, the power ratings are at 1KHz, so expect considerably less output in the subwoofer range. I would bet that this amp is a rebadged EP2500, as the specs are nearly identical.
This would probably mean that the EP2500 has the same 10Hz HP filter in place, making the specs pure BS (they simply get the FR BEFORE the 10Hz HP).
I personally wouldn't use these amps (or the Crown XLS series, Samson, Nady, etc.) if you gave me one free. The QSC RMX series is the lowest quality I would use, and actually, the QSC PLX-04 series is a great amp for the money.
Both the QSC's RMX and PLX series have a 2nd order 5Hz HP (down 3dB at 5Hz).
Rune...Nice project. Looking forward to more pics and some subjectives
Bosso
bossobass is offline
post #106 of 401 Old 11-18-2006, 03:58 PM - Thread Starter
RuneW's Avatar
Bosso
Thanks for the nice words and information, Bosso!
The problem, of course, is money... The QSC's looks nice (I really don't know anything about PA amps...), but they cost 2-3 times as much as the EP2500, and I really have to draw the line somewhere God knows I have enough other things to use up my money on (like the rest of my home theater).
RuneW is offline
post #107 of 401 Old 11-18-2006, 04:12 PM - Thread Starter
RuneW's Avatar
Todays work...
I flipped over the DIY flares to round the other side. The flare is fastened on a piece of port pipe which in turn is recessed in a circular groove in the board below. This means that it is relatively easy to keep the router still while rotating the flare. Here the inner edge is rounded:
And here's the result after one round of filler (?) and (coarse) sanding. I'll probably do another round. Don't know how critical it is, however. I think maybe I'll paint them later:
And I finally got my act together and cut the other port pipe. Those pipes are made of 5mm PVC and it's %/¤&%¤ hard keeping them still while sawing...:
RuneW is offline
post #108 of 401 Old 11-18-2006, 04:59 PM - Thread Starter
RuneW's Avatar
BTW, I've started the break-in of the drivers:
I was considering using the state of the art pre-war Bulgarian break-in device under the table, but went for the old DiscMan-with-pre-LPF'ed-break-in-CD routine instead:
RuneW is offline
post #109 of 401 Old 11-18-2006, 05:25 PM
ssabripo's Avatar
Quoted: 66 Post(s)
Liked: 35
very nice Rune.....keep it coming!
ps- I hope all buckeyes die in a Fire!
ssabripo is offline
post #110 of 401 Old 11-18-2006, 05:34 PM
crackyflipside's Avatar
What content is on a woofer 'breaking-in' cd?
Is it just like pink noise? Brown noise? Sweeps?
crackyflipside is offline
post #111 of 401 Old 11-18-2006, 11:15 PM
Quoted: 142 Post(s)
Liked: 56
Bosso, I believe the Behringer EP2500 is actually a rebadged QSC RMX. The cycle never ends.
post #112 of 401 Old 11-19-2006, 04:48 AM - Thread Starter
RuneW's Avatar
Didn't understand the one about "buckeyes" though... what does it mean?
RuneW is offline
post #113 of 401 Old 11-19-2006, 04:57 AM - Thread Starter
RuneW's Avatar
It's not a commercial breaking-in CD or something like that, just a self burned CD-R. As a warm up I'm just playing a 15Hz sine at moderate levels. This way I don't have to listen to it two floors above... After a few days, maybe I'll move on to something like this. But low pass filtered of course!
BTW: I'm absolutely not an break-in expert in any way. If you have any advice, please feel free!
RuneW is offline
post #114 of 401 Old 11-19-2006, 10:02 AM - Thread Starter
RuneW's Avatar
"parting your subs 4-5' "? You mean to separate the twins? What kind of parent would ever do that?
Anyway, I know that my two subs (in my 4.5 x 6 meter home theater) will be overkill DeLuxe, but they have a second purpose. Each year we have a "guy evening". I don't know what you call it, but you know, no females allowed. We rent this old "public house" out on the countryside and fill it with whatever we have that makes most noise and play 2-3 movies with some pizza in between. This has become a nice tradition and next year it's a ten year anniversary. Here's what we do:
1. Use 7-8 hours to rig the system (8 speakers, subs, cables, PJ whatever)
2. Watch 2-3 movies
3. Use 2 hours to dismantle the system
If this isn't crazy I don't know... But we love it! Let's us play around with different solutions very often. The thing is, we try to get it louder and better each year and it getting hard to do that...
I won't bore you with more details, but my sono's mission this next march is to fill a large room (about 475 cubic metres (find your calculators...)) with kidney crushing bass, so they will have challenge in front of them I happen to be the driving force behind this event, so I just had to take steps to ensure proper bass for the 10 year anniversary... hence the sonos.
But good/loud bass at home won't hurt (or will it?) either
RuneW is offline
post #115 of 401 Old 11-19-2006, 10:44 AM
ssabripo's Avatar
Quoted: 66 Post(s)
Liked: 35
hehehe...yeah Rune, we have that here too; it's called being single!
ssabripo is offline
post #116 of 401 Old 11-19-2006, 11:35 AM
Quoted: 142 Post(s)
Liked: 56
You're breaking it in by playing a continuous 15hz sine wave with the driver in free air?
post #117 of 401 Old 11-19-2006, 12:16 PM - Thread Starter
RuneW's Avatar
Yup. I get to be single once a year...
RuneW is offline
post #118 of 401 Old 11-19-2006, 12:31 PM - Thread Starter
RuneW's Avatar
Maybe not breaking it in as much as warming it up (and confirming that they work at all). I was hoping that by loosening them up in this way I could save some time when the real break in time comes (within an enclosure for sure).
But as I've said before - I'm absolutely not break in expert, so if you think I'm doing something harmful or is wasting my time by this "break in light", please do say so!
RuneW is offline
post #119 of 401 Old 11-19-2006, 12:40 PM
Willd's Avatar
As long as you're not bottoming them out or clipping the amp, you'll be fine. Its not as if you're using a high power amp with them anyway.
Willd is offline
post #120 of 401 Old 11-19-2006, 03:19 PM - Thread Starter
RuneW's Avatar
Originally Posted by Willd View Post
As long as you're not bottoming them out or clipping the amp, you'll be fine. Its not you're using a high power amp with them anyway.
No. I'm VERY careful. The drivers are moving less than 8mm (+/- 4 mm). As I said, I'm just loosening them up a little. I won't be "mean" to them before they're safe in their new homes...
RuneW is offline
