6" port layout. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 22 Old 01-12-2007, 07:12 AM - Thread Starter
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
According to Winisd, I can get a 17.9hz tune with a 6" port at 24". The proposed box is 25" cubed, 9cuft. How much room does the port need to vent easily before reaching the rear panel? Or is there another suggestion based on the 25" cube?
UPDATE: Go to post 19.
Panasonic AE-2000, Carada BW 120", Paradigm Studio 40v3 x 2, Paradigm 690v4, Paradigm ADP 470v3 (rears), Micca M-8C x 4, Volt 6 x 2 (SR), SI DS4-18 in 12cuft X 2, Marantz 7702MKII, OPPO 103D, Emotiva XPA-3,
vitod is offline
post #2 of 22 Old 01-12-2007, 08:49 AM
Thomas-W's Avatar
Quoted: 20 Post(s)
6" port should be 6" away from the interior walls of the box. That's pretty much impossible with your design.
Low tuned 2' cubes use PR's
Thomas-W is offline
post #3 of 22 Old 01-12-2007, 10:15 AM - Thread Starter
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
So I guess I'd have to go with 4" port at 16" tuned to 14hz. Would that work?
vitod is offline
post #4 of 22 Old 01-12-2007, 10:36 AM
Thomas-W's Avatar
Quoted: 20 Post(s)
It will be fine for a modest excrusion 12" driver.
Thomas-W is offline
post #5 of 22 Old 01-12-2007, 10:41 AM - Thread Starter
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
It's a SS Rpl 15" D4.
vitod is offline
post #6 of 22 Old 01-12-2007, 10:45 AM
Thomas-W's Avatar
Quoted: 20 Post(s)
Then your options are....
1) different shaped box so you can use a 6" port
2) use PR's
3) go sealed
Thomas-W is offline
post #7 of 22 Old 01-12-2007, 10:50 AM
stevdart's Avatar
With 8" of play in port length between the Fb's of 18 Hz and 14 Hz, you should be able to make that port length anything that fits well in between 16" and 21". Keep the end of the port away from the wall or acoustic panel (if used) by at least 5". This space at the end will allow for proper end correction of the acoustical port.
stevdart is offline
post #8 of 22 Old 01-12-2007, 11:07 AM - Thread Starter
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
So a 4" port at, let's say 20" is fine?
vitod is offline
post #9 of 22 Old 01-12-2007, 11:37 AM
BoomieMCT's Avatar
Or just have the port stick out like a periscope.
BoomieMCT is offline
post #10 of 22 Old 01-12-2007, 01:16 PM
Thomas-W's Avatar
Quoted: 20 Post(s)
That driver needs a 6" port.
Thomas-W is offline
post #11 of 22 Old 01-12-2007, 04:04 PM
brandonnash's Avatar
Liked: 32
You'll probably get port noise, depending on the size of the amp, if you use the 4"
brandonnash is offline
post #12 of 22 Old 01-12-2007, 09:03 PM
stevdart's Avatar
Vitod, you meant to say 6" diameter, correct? If so, then yes, according to what you have written here.
stevdart is offline
post #13 of 22 Old 01-13-2007, 08:05 AM - Thread Starter
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
The amp is a EP2500.
vitod is offline
post #14 of 22 Old 01-13-2007, 08:05 AM - Thread Starter
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
Yes 6" diameter.
vitod is offline
post #15 of 22 Old 01-13-2007, 07:52 PM
derekbannatyne's Avatar
What about a slot port?
derekbannatyne is offline
post #16 of 22 Old 01-14-2007, 07:43 AM - Thread Starter
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
Can't do it. Round port is way easier.
vitod is offline
post #17 of 22 Old 01-14-2007, 09:49 AM
Vinculum's Avatar
Quoted: 13 Post(s)
How about multiple smaller ports?
Look at the new SVS Ultra13. 22x21.5x27 using 3 3.5" ports. Then you can experiment with tunings and even sealed. I believe they use elbows inside the box.
This design is screaming to be cloned by the DIY crowd if a decent third party driver can be used.
Sorry Ron & Tom, better get those Ultra to market soon!
Dr V
Vinculum is offline
post #18 of 22 Old 01-14-2007, 11:07 AM - Thread Starter
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
Dr V
That's very interesting. I'd have tuning options.
Maybe someone can add to this.
vitod is offline
post #19 of 22 Old 01-15-2007, 08:53 AM - Thread Starter
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
According to Winisd, I can have a 4" port at 15.2" and get 14.3 tune. (net) If I go with 6"x 23", I get 17.4hz tune. (net) I think with the 6", I'll get more SPL.
I have to work with 9cuft, 25" internal cube. (net) In the real world, would port noise be an issue or it won't be as noticeable? What do you people suggest?
I'm using a SS Rpl 15" D4.
vitod is offline
post #20 of 22 Old 01-16-2007, 05:50 AM - Thread Starter
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
Anybody?
vitod is offline
post #21 of 22 Old 01-16-2007, 06:31 AM
Willd's Avatar
In the real world port noise would certainly be noticeable with the 4". Most definitely go with the 6"....
Willd is offline
post #22 of 22 Old 01-16-2007, 08:33 AM - Thread Starter
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
Thanks willd!
vitod is offline
