Havoc 18" modeling - AVS Forum | Home Theater Discussions And Reviews
Old 01-16-2007, 10:26 AM - Thread Starter
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
The response looks good except that nasty dip. Did I do this right?
T/S:
Znom - Dual 2 ohm BL - 21.4 n/a Cutout diam - 16 3/4
RE - Dual 1.5 ohms Sd - 1210 cm2 Outer diam - 18 5/8
FS - 22.9 Hz Mms - 360 g Mounting Depth - 10 1/2
Vas - 280 L Spl - 91.8 dB 1W/1M Weight - 40 pounds
Qms - 4.962 Rms - 1500 W Voice Coil Diam - 3 inch aluminum
Qes - .334 Xmax - 25 mm one-way Voice Coil - Dual 2 ohm
Qts - .318 Price - $350 Cone - Paper/Kevlar fibers
Le - 1.2 mH
Home Audio ~ 8-10 Cubic Feet / 18-20 Hz tuning
Car Audio ~ 6 Cubic Feet / 28-32 Hz tuning
Panasonic AE-2000, Carada BW 120", Paradigm Studio 40v3 x 2, Paradigm 690v4, Paradigm ADP 470v3 (rears), Micca M-8C x 4, Volt 6 x 2 (SR), SI DS4-18 in 12cuft X 2, Marantz 7702MKII, OPPO 103D, Emotiva XPA-3,
vitod is offline
Old 01-16-2007, 10:28 AM
PLincoln's Avatar
while i didn't plug the numbers into Unibox, the graph looks as it should for a ported enclosure. I think the "dip" you are referring to is the one of the graph labeled "SPL of the Driver"...you want to look at SPLtot
PLincoln is offline
Old 01-16-2007, 10:35 AM
Jack Gilvey's Avatar
Quoted: 35 Post(s)
Liked: 34
T/S:
Le - 1.2 mH
Strange, the upper right reports an Fb of 20Hz, but the graph shows it to be around 32Hz. Did you update the graph after you entered your parameters?
Not sure what dip you mean.
Jack Gilvey
SVS Customer Service
Jack Gilvey is offline
Old 01-16-2007, 10:46 AM
bossobass's Avatar
Quoted: 78 Post(s)
Liked: 667
Sorry guys, that's a sealed alignment. Wait, check that...it's a bird, it's a plane...I have no idea what that graph represents...
Bosso
bossobass is offline
Old 01-16-2007, 11:00 AM
Richard Mayer's Avatar
The Fb (tuning frequency) isn't 20 Hz, it's more closer to 32 Hz. You should update the graph...
And there WILL be a dip at Fb in driver's response. That's because the port will make the most of the output there. You should look at the dark blue line, that's the combined response.
Richard Mayer is offline
Old 01-16-2007, 11:13 AM - Thread Starter
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
I may have done it wrong. Can you do the same and let's see what you come up with?
The dip is "SPL produced by the driver".
I'm still learning this modeling stuff.
vitod is offline
Old 01-16-2007, 11:23 AM
PLincoln's Avatar
well here is what i came up with for a 260l enclosure with two 6" ports....
PLincoln is offline
Old 01-16-2007, 11:23 AM - Thread Starter
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
Thanks for clarifying that Rich. I get it now.
vitod is offline
Old 01-16-2007, 11:27 AM
I wold think about shrinking the enclosure a bit to get rid of the hump at 26hz
I would tune it much lower, 16 Hz should do the trick...
Old 01-16-2007, 11:29 AM
Quoted: 35 Post(s)
Liked: 34
I think the only thing you didn't do is hit "Update graph".As Richard mentioned, the driver's dip is just the damping of its motion/output as the port takes over. The SPLTotal is the actual FR.
Your 260L box tuned to 20Hz looks pretty good, won't let me attach right now.
Jack Gilvey
Old 01-16-2007, 11:39 AM - Thread Starter
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
6" is what in cm?
vitod is offline
Old 01-16-2007, 11:41 AM
Quoted: 35 Post(s)
Liked: 34
'bout 15.
http://joshmadison.net/software/convert/
Jack Gilvey
Old 01-16-2007, 11:44 AM - Thread Starter
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
Awesome, thanks!
vitod is offline
Old 01-17-2007, 08:27 PM
cecaa850's Avatar
I was wondering who got those drivers. How many of the 4 did you get? They look beastly.
120@20@14'
cecaa850 is offline
Old 01-17-2007, 10:16 PM
jjw350z's Avatar
Bl^2/Re = 100+ yummy
Jim
jjw350z is offline
