$2500 for subs, what to build? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 01-25-2007, 10:36 PM - Thread Starter
BoomieMCT's Avatar
Sadly that budget isn't for me. . . I have a friend who was going to buy a JL Gotham for his 3500 - 4000 cubic foot HT room. Unfortunately his dog needed an operation and now his sub budget is $2500. I told him he could still get good performance if he went DIY.
He already has a set of B&W 801's, so what he mostly needs is something to dig down deep - crossover will probably be 40 - 50 Hz or so. I thought of two ideas, but I wanted to see what y'all had to say about it:
Option 1: Buy two Rhythmik 15" servo kits. I figure once you build the cabinets, buy the veneer and add a Behringer DSP-1024P BFD that would be about $1400 - well in the budget. I'm wondering if they could keep up with the mains in that big of a room. Any ideas?
Option 2: Two sonosubs using 15" TC-2000 SVC drivers. A single Behringer EP-2500 (to run both) and a Behringer DSP-1024P BFD + materials would be about $1700. With two 300L tubes I figure that should make 119 dB @ 16 Hz.
Any thoughts on either setups or choice of materials?
BoomieMCT is offline
post #2 of 11 Old 01-25-2007, 11:04 PM
Richard Mayer's Avatar
Option 3: 2x15" sealed using Tumult 15D2, TC-2000 15" SVC, RL-p 15D2. 5-6 ft^3 box and a decent 2000W amp should keep you under $2500.
Richard Mayer is offline
post #3 of 11 Old 01-25-2007, 11:38 PM
warnerwh's Avatar
If you wait I believe Soundsplinter is coming out with an 18". Then again four fifteen RL-p drivers will be under budget too.
Portland, OR
warnerwh is offline
post #4 of 11 Old 01-25-2007, 11:50 PM
Willd's Avatar
Ahh, you mean better performance for less...he's lucky his budget has decreased.
And unless he doesn't have any tools or access to then, Option 2 shouldn't be more than $1500, and that is leaving over $200 for items other than the drivers, amp, bfd, and sonotube.
Willd is offline
post #5 of 11 Old 01-26-2007, 06:18 AM - Thread Starter
BoomieMCT's Avatar
Yes, I'm a recent DIY convertee too. I'm not sure I'll ever buy a speaker again.
The $1700 I figure for option 2 included a BFD, the MDF, the tubes, veneer and such. I'm trying to figure out total costs, not just the amp and driver(s).
post #6 of 11 Old 01-26-2007, 07:58 AM - Thread Starter
BoomieMCT's Avatar
If I'm not muddling the thread too much - what about IB? I have no experience with them, but what drivers would it take to fill this volume to reference level and how much power would they need. IB may be an option.
post #7 of 11 Old 01-26-2007, 08:37 AM
TJEli's Avatar
Similar to what I am doing...
He could do 2X15 Adire Brahmas, 1 or 2 Buttkicker BKA1000s, and a velo SMS-1 and still be under $2500...even with dual amps.
-Eli
AV Nut
TJEli is offline
post #8 of 11 Old 01-26-2007, 09:13 AM
Willd's Avatar
http://www.avsforum.com/avs-vb/showt...3&page=4&pp=30
Total project cost, wood and everything was I think around $1600.
4 x 18" Fi Car Audio Qs
EP2500 amp
MDF/2x4s/sheets of plywood/Flex-mound for trim around the speaker grills/Grill cloth.
Willd is offline
post #9 of 11 Old 01-26-2007, 09:19 AM
thylantyr's Avatar
With that budget, many options, it's so easy even this guy can do it.
http://adweek.blogs.com/photos/uncat.../caveman_1.jpg
The storm was gone, but dark clouds still hung around
The perfect setting for things to come......
thylantyr is offline
post #10 of 11 Old 01-26-2007, 12:53 PM
penngray's Avatar
Liked: 43
If you have the ability to do IB then Im convinced is the best way to go.
With that budget you can do anything, go with 6 18" drivers in a manifold or array design....power them with two 2400 Watt amps and you have a sub system everyone dreams about. There is not a box design out there that can compete with something like this.
In the end though even if you decide on a box design and not an IB design, you are going to be happy. Because $2000 DIY subs systems generally compare to $5000+ retail Subs.
penngray is offline
post #11 of 11 Old 01-26-2007, 12:56 PM
penngray's Avatar
Liked: 43
Wild posted my costs for my IB solution. I never ever built speakers before so that was my first time and let me tell you words can not explain the final product.
IB is easier then building a box in my opinion because the box already exists. IB sound is something you have to experience, its not the same as a box.
Its fun to make the house shake
penngray is offline
