To T-nut or not to T-nut?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-29-2007, 07:22 AM - Thread Starter
TJEli's Avatar
If I were to T-nut the drivers in, whats a good size to use?
-Eli
AV Nut
TJEli is offline
post #2 of 10 Old 01-29-2007, 07:35 AM
Darin's Avatar
I considered t-nuts, but in the end, I just glued small blocks of wood to the back of the baffle in each spot where a screw would be. I already had some red oak that I was using for bracing... it's hard and holds screws well without stripping. It was right there in front of me instead of having to wait and pay for shipping, and is probably stronger anyway.
My dual Rythmik Servo sub project (actually quad now, need to update page)
HDM format neutral thanks to the pricing wars of the '07 xmas shopping season :)
Darin is offline
post #3 of 10 Old 01-29-2007, 08:00 AM
snackmasta's Avatar
-Eli
You have to pick the correct size for the holes in the flanges of your drivers, but probably #8 for tweeters and #10 for midranges and woofers would work. The beauty of T-nuts is that you don't have to worry about stripping the wood on the baffle, even if you remove reinstall the drivers repeatedly.
snackmasta is offline
post #4 of 10 Old 01-29-2007, 09:04 AM
Willd's Avatar
But if you don't install the T-nuts correctly, or in the right kind of wood, they will just strip out.
Me, I have had fine luck using good wood screws in straight MDF (and some OSB). After all, that is whats holding my 15" TC-2K in a vertical orientation.
Willd is offline
post #5 of 10 Old 01-29-2007, 09:07 AM - Thread Starter
TJEli's Avatar
I suppose if the wood srews ever started to lose their grip that you could always drill out and switch to t-nuts.
-Eli
AV Nut
TJEli is offline
post #6 of 10 Old 01-29-2007, 09:11 AM
ecir38's Avatar
This is where toothpicks come in handy.
BR
ecir38 is offline
post #7 of 10 Old 01-29-2007, 09:37 AM
chasw98's Avatar
-Eli
Look into the "Hurricane Nuts" on the Parts Express site. They seem to work much better than a standard T-Nut.
Chuck
chasw98 is offline
post #8 of 10 Old 01-29-2007, 10:31 AM
thylantyr's Avatar
Another idea is to use insert nuts {home depot cabinet hardware area}, something like so.
http://www.woodpeck.com/media/main_inserthex.jpg
You drill the correct hole to install those, but before you install them you get some
JB weld epoxy glue as it hardens like a rock and you apply the glue to the nut and
then install it. It's pretty tough after a 24 hour cure. The 5 minute epoxies are rubbery,
don't use those.
The storm was gone, but dark clouds still hung around
The perfect setting for things to come......
thylantyr is offline
post #9 of 10 Old 01-29-2007, 01:19 PM
Jack Gilvey's Avatar
Quoted: 35 Post(s)
Liked: 34
Chuck
That's what I've been using, they work well.
Jack Gilvey
SVS Customer Service
Jack Gilvey is offline
post #10 of 10 Old 01-29-2007, 01:28 PM
PLincoln's Avatar
T-Nuts and some Poly Based Glue (gorilla, etc), right into the MDF. Have never had one fail yet...
PLincoln is offline
