$5K budget for subwoofer (can't stretch anymore) - what would you recommend? - Page 29 - AVS Forum | Home Theater Discussions And Reviews
Old 06-13-2007, 01:42 AM
Doyle's Avatar
Jai,
Could you please post pictures of your boxes before mounting the drivers and PR's. Also, if you would please post any dimensional drawings of your box design I would really appreciate it. I'm considering a DIY project similar to yours, but I am having a hard time choosing between a simple sealed design or one using PR's.
Thanks a million.
Doyle is offline
Old 06-13-2007, 10:34 AM
04FLHRCI's Avatar
Jai,
What was the final design you arrived at?
I apologize; however, with this topic now hitting 29 pages I seemed to have lost focus.
I have a message out to TC inquiring to the 5400's availability; I want to pick up a pair on the next build.
Thanks for the update and please keep the photos coming!
Larry
04FLHRCI is offline
Old 06-13-2007, 10:39 AM - Thread Starter
jmcomp124's Avatar
UPDATE:
Please post your replies in this new thread as this one has gotten too long to the point of being useful to others
Jai's LMS-5400/Passive Radiator design.
This may help in avoiding reaching 1K posts
jmcomp124 is offline
Old 09-21-2007, 04:03 AM
buyerchoice's Avatar
"calibrated to 80dB reference at MV 0"
Could you explain what that means?
buyerchoice is offline
Old 09-21-2007, 06:33 AM
NickTF's Avatar
Not the cheapest solution but how bout an IB small cube with four of those RE XXX 18s? Would be the highest output/size ratio IB probably every implemented, lol. 54 mm xmax
Would need some serious amp muscle i'd guess, a PLX 3602 would probably drive four of those nicely in an IB i'd guess but maybe not.
On the other hand if size is not an issue multiple Q18s could destroy things if that's your fancy, ha. 8 Would cost right around 2300 with 12 being a 1150 more or so. Would be overkill but hey, you said ya had $5k to play with
29 Litres of Infinite Baffle Bliss. Oh, and the rest of the setup isn't too shabby either!
NickTF is offline
Old 09-21-2007, 06:35 AM
Willd's Avatar
Yeah, he had 5K to play with.
Willd is offline
Old 09-21-2007, 07:08 AM
NickTF's Avatar
Damn, that's me, always late to the show, ha
NickTF is offline
Old 09-21-2007, 08:25 AM
DonoMan's Avatar
Means you're getting 80dB SPL when your master volume level is at 0dB, I'd guess.
"Vintage" is good for wine, not for A/V equipment.
-Dan D.
DonoMan is offline
Old 09-21-2007, 08:56 AM - Thread Starter
jmcomp124's Avatar
Yes, 80dB with test tones and about 116dB peaks on bass intense movie scenes. Occassionally I calibrate the subs 3dB hot and I hit close to 120dB. New responses can be posted in this thread
