pc based crossover? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-23-2007, 10:27 AM - Thread Starter
goober07's Avatar
I am considering buying (eventually) the Behringer DCX2496 digital crossover and a pair of A500 power amps to bi-amp a pair of line arrays. My source, however, is most likely going to be a PC.
The PC has unbalanced outputs, and the DCX uses balanced XLR. I could pay $50 for a converter on partsexpress... but that's just another part to buy and another component in the audio path...
My question: Is there such a thing as a PC based crossover or sound card that could perform all the same functions as the DCX? The A500 has balanced XLR and unbalanced RCA inputs, so no concerns there. Using a PC crossover would eliminate any converters and the DCX
goober07 is offline
post #2 of 8 Old 06-23-2007, 11:04 AM
Thomas-W's Avatar
Quoted: 20 Post(s)
Thomas-W is offline
post #3 of 8 Old 06-23-2007, 02:11 PM
Badmoon23's Avatar
i want to know if some Active 3-way sub crossover for home HAVE the RCA plug input and output.
Badmoon23 is offline
post #4 of 8 Old 06-23-2007, 03:00 PM - Thread Starter
goober07's Avatar
Thomas: That is EXACTLY what I need
I need to look into this more... do you have any more info? And again, thank you
goober07 is offline
post #5 of 8 Old 06-23-2007, 04:04 PM
Thomas-W's Avatar
Quoted: 20 Post(s)
Nope don't know anything about it just ran across the link.
This maybe of help as well
http://www.duffroomcorrection.com/wiki/Main_Page
Thomas-W is offline
post #6 of 8 Old 06-24-2007, 09:52 AM - Thread Starter
goober07's Avatar
This may not be the correct forum to ask in, but...
That software's accuracy will be based on the mic used to measure the speakers. What would be a good mic to use that has a 3.5mm plug? (so I can hook to the line in on PC)
goober07 is offline
post #7 of 8 Old 06-24-2007, 10:16 AM
Thomas-W's Avatar
Quoted: 20 Post(s)
All measurement mics need special mic preamps and most need phantom power, so it's not too hard to get an RCA- mini adapter to use with a sound card.
Thomas-W is offline
post #8 of 8 Old 06-24-2007, 11:35 AM
zkaudio's Avatar
there's bound to be some latency in any of the pc based apps
zkaudio is offline
