TriTrix build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 06-26-2007, 02:03 PM - Thread Starter
Satansfx's Avatar
So, a friend was over here last week, saw my catalog from PE and saw the TriTrix speakers..... and said to me "can you make those?" I said "sure can" so we headed off to Lowes.... got a sheet of MDF, came home cut it up and I started gluing. 2 days later I'm looking online to order the parts and the drivers are out of stock!!! OH NOES!! But I see the date when they should be back in stock 7/4/07 no big deal.... only a 2 week delay.... even though my buddy needs these since he has nothing after his roomate moved out, and i assured him I could have these done in about 2 weeks.....
Today im checking the date on the shipment..... and now its 7/10 uh oh!! so I tell my buddy.... he's not happy.... kinda disappointed with the deal, and now he want to go off and buy some Klipsch ones on ebay!!!! so now im stuck with cabinets that are 90% built, and just need to be finished.....
To top it all off.... I decided to check out PE's support.... and there is a topic in there about the drivers that I need 295-302. Someone called PE and they are saying that they wont be in untill aug/sep-ish NOOOOOOOOOOOO!!!!!!
So here I thought I could bang this one out of the park.... and im stuck at first base
My paperweights
Satansfx is offline
post #2 of 21 Old 06-26-2007, 02:40 PM
Willd's Avatar
This wouldn't exactly be as cheap as the TriTrix, but I think it would quite easily work with the enclosures you built.
http://www.eldamar.net/audio/rs150mtm/
Willd is offline
post #3 of 21 Old 06-26-2007, 04:40 PM - Thread Starter
Satansfx's Avatar
Thats for a ported design though.... im confused a tad bit here....
Satansfx is offline
post #4 of 21 Old 06-26-2007, 04:43 PM
BoomieMCT's Avatar
If you had already put in your order they will come on the projected date when you put your order in. What happened is the re-supply must have sold out. This happened to me once but PE sent me my order on the projected date when I put my order in.
Or, you could find a driver with the same cutout size and a similar Fs and Qts. Transmission lines are pretty forgiving I think.
Here are some possibilities;
*EDIT: Disregard - I used the wrong impedence*
BoomieMCT is offline
post #5 of 21 Old 06-26-2007, 05:05 PM - Thread Starter
Satansfx's Avatar
hmmm.... if it's forgiving.... then I might have to do that..... But what about the xover, do I have to change that a touch too?
all in all..... if these end up sounding decent, then im going to match em up with a center and surrounds. Center usign the same design, just in a sealed cabinet, and for the surrounds.... well, thats another build thread
Also, I read on PE's support site that you can't use the 8 ohm versions.... otherwise I would just use http://www.partsexpress.com/pe/showd...number=295-301 since its the same
Satansfx is offline
post #6 of 21 Old 06-26-2007, 06:14 PM
BoomieMCT's Avatar
Quite possibly. This would be something to do if a) you can't wait and b) you don't mind experimenting a bit. At the least you may want to buy some small non-inductive resistors to pad the tweeter with (since the woofer had a decent sensitivity).
And, yes, I should have noticed that the original woofers were 4 ohm - that will mess up the x-over. Disregard the ones I posted. Maybe try these?
http://www.partsexpress.com/pe/showd...number=295-372
The guys at DIYaudio have a lot more experience playing with TLs then I do. It may be worth a quick peek.
post #7 of 21 Old 06-27-2007, 05:42 AM - Thread Starter
Satansfx's Avatar
Well, I posted on PE's board hoping Curt C will see it and offer some advise, maybe I can just change the xover and go with another driver.... i dunno
Satansfx is offline
post #8 of 21 Old 06-27-2007, 03:45 PM - Thread Starter
Satansfx's Avatar
damnit all
http://www.pesupport.com/cgi-bin/config.pl?read=361076
"Due to the popularity of the "The TriTrix" speaker project the demand for this has exceeded our supply. We are doing our best to replenish stock and will air ship some in as soon as possible. However; it doesn't look like that will happen until August. We will have a better ETA in a week or so. We sincerely apologize for this but some things are just beyond our control. "
Satansfx is offline
post #9 of 21 Old 06-27-2007, 03:52 PM
thylantyr's Avatar
""Silly rabbit, Trix are for kids!" ?
... constant struggle to obtain the unobtainable elicits a degree of sympathy from many viewers.
The storm was gone, but dark clouds still hung around
The perfect setting for things to come......
thylantyr is offline
post #10 of 21 Old 06-27-2007, 04:33 PM - Thread Starter
Satansfx's Avatar
Satansfx is offline
post #11 of 21 Old 06-27-2007, 10:10 PM
armystud0911's Avatar
Still not quite as cheap as the TriTrix, but close http://www.zaphaudio.com/BAMTM.html
armystud0911 is offline
post #12 of 21 Old 07-03-2007, 02:09 PM
patsnyanks45's Avatar
Hey I'm thinking about building the Zaph Audio MTM project too after not being able to get everything for the TriTrix in time.
I just have 2 quick questions before I start building:
1. What enclosure would be best? I'm not going to use a subwoofer with it and space isn't a HUGE concern (although smaller is always better). From just glancing over the link, it sounds like I should use a large sealed enclosure (1.5-2 cu ft.)
2. What would be a good amp to power them? They are going to be used as bookshelf speakers in a college dorm room. I would want to play CDs, hook up an iPod, and possibly hook up a laptop (though an external sound card maybe?)
Thanks for the help
patsnyanks45 is offline
post #13 of 21 Old 07-03-2007, 02:52 PM
cc00541's Avatar
Location: latitude 40.8510 longitude -96.7592 altitude 362 meters
I'm presently designing a redo of the Triune TL. This is the same enclosure as the Tritrix TL only uses the 295-301 drivers in a parallel configuration. I've redesigned the crossover, but haven't yet had a chance to listen to it yet. I should have a solution for you yet this week.
-Keep an eye on the PE forum, I'll announce it there...
Curt C
cc00541 is offline
post #14 of 21 Old 07-04-2007, 04:42 AM - Thread Starter
Satansfx's Avatar
So your redesign only uses the 295-301??? no silkies or anything?
Satansfx is offline
post #15 of 21 Old 07-05-2007, 10:03 AM
cjd
cjd's Avatar
FWIW I can confirm the design Willd linked *should* work in the TL box for the TriTrix assuming the Triune drivers drop right in (with, of course, a Triune specific crossover). It works in any box tuned for a Triune - one nifty thing about the RS150 is its box match for the classic Dayton drivers. Makes a nice upgrade path for folks.
C
cjd is offline
post #16 of 21 Old 07-05-2007, 10:07 AM - Thread Starter
Satansfx's Avatar
Curt, I've already listend to 1 of the triunes.... and the sound is great..... I kept it together for about 45-60 mins.... couldn't get enough of it
sadly.... I couldnt get both of them done we had a fatality (see thread angry speaker gods)
Satansfx is offline
post #17 of 21 Old 07-06-2007, 09:17 AM
cc00541's Avatar
Looks great!
See my post on your angry gods thread on how to listen to 2 of them...
C
cc00541 is offline
post #18 of 21 Old 07-06-2007, 09:34 AM
Willd's Avatar
C
Thanks Chris, I honestly thought that it work well. Good to know I wasn't talking crazy.
Willd is offline
post #19 of 21 Old 07-06-2007, 10:22 AM - Thread Starter
Satansfx's Avatar
Originally Posted by cc00541 View Post
Looks great!
C
Thanks C
Satansfx is offline
post #20 of 21 Old 07-09-2007, 11:04 PM
Vic C's Avatar
I bet those have nice bass like my designs
TS 206.5 towers!
I designed these about 5 years ago and have them in use now for the last 3 1/2 years. I love they way they sound
I built the prototypes to listen to and then sell I liked them so much I kept them and got rid of my od Cerwin Vegas.
http://www.emersiveav.com/Screen%20wall.jpg
Vic C is offline
post #21 of 21 Old 07-10-2007, 04:45 AM - Thread Starter
Satansfx's Avatar
I'll let you know how they both sound later today.... I just need to finish the second one, its already filled, sanded, primed.... now for the topcoat today!!
Satansfx is offline
