Any 18’s on the horizon with XBL^2? - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 711 Old 02-09-2008, 05:15 PM - Thread Starter
04FLHRCI's Avatar
Sweet!
Hmm, so if you're using a 1200 per driver; I suppose I need to order a second unit...Oh, by the way; I'm ready for my Maelstroms
Larry
04FLHRCI is offline
post #182 of 711 Old 02-09-2008, 06:57 PM
Willd's Avatar
WillD,
Right, but at that point you could just buy another driver. Maybe what we need is for the PR's to have the uber excursion instead of the drivers?
What would you do with the two drivers then, run them sealed? The same thing could be said for virtually any driver chosen. Why go with an SDX and two PRs when you could get two SDXs for the same money? Etc....
Willd is offline
post #183 of 711 Old 02-09-2008, 07:29 PM
Kevin Haskins's Avatar
You need both.... look at the excursion plots. That is two 18" PRs with the same suspension and mechanical travel as the driver.
Kevin Haskins
Exodus Audio
Kevin Haskins is offline
post #184 of 711 Old 02-09-2008, 07:36 PM
Ricci's Avatar
Quoted: 185 Post(s)
Liked: 473
Right. Running 2 sealed vs one PR'd could be an option.I'm not saying that either way is better. Its just when you start talking about 3 and 4 PR's per one driver it seems like a lot of trouble to go to.
Ricci is offline
post #185 of 711 Old 02-09-2008, 08:07 PM
Three doesn't work so well. You get some enclosure rocking. Having two PRs with the driver downfiring works good though. You can center the driver on the enclosure and the force from the two PRs on opposing sides cancels.
As shown in the simulations, the dual sealed would take up more space, require an extra amp and have more distortion down low. From simply looking at the simulation the dual PRs is an attractive way to go.
Figure:
$1K for the driver
$500 for x2 18" PR
$785 for the Amp
$300 Woofer Widget
$2585 Plus MDF for enclosure
That gives you everything you need including room measurement, 4-band PEQ, Subsonic Filter and other subwoofer signal processing functions.
You get >125db in-room from 14hz up.
About 114dB anechoic from 20Hz and up.
Kevin Haskins
Exodus Audio
post #186 of 711 Old 02-09-2008, 08:09 PM
Willd's Avatar
Both what?
Keep in mind, this is all w.r.t the Maelstrom, not the Extreme-x driver.
Willd is offline
post #187 of 711 Old 02-09-2008, 08:23 PM
Both what?
Excursion on both the PR & the driver.
The Maelstrom-X would work in the exact same enclosure with just less output.
$350 Maelstrom-X
$260 x2 18" PR's from Creative Sound
$300 Behringer Amp
$300 Woofer Widget
$1210
Same capabilities but output is lower: Still.... very good. Double up on these and you would have close to the same output.
>111dB @ 1M from 20Hz and up.
>123dB @ 1M from 15Hz and up in-room.
Kevin Haskins
Exodus Audio
post #188 of 711 Old 02-09-2008, 08:49 PM
Spezzy's Avatar
Just had a thought, why not use a 21" woofer basket for the 18"?
http://img.alibaba.com/photo/5210700...PA_Speaker.jpg
I can give you contact to the manufacturer if you like. Are your buildhouses in China?
They could probably do the manufacturing for you.
"The choices we make define our lives, because choice, not chance, determines destiny"
They call me the 18 year old DJ Audiophile-upgradeitis infected-guy!
Spezzy is offline
post #189 of 711 Old 02-09-2008, 09:11 PM
We almost get too much Sd with a 21". For our box sizes the 18" looks like about the right size.
Kevin Haskins
Exodus Audio
post #190 of 711 Old 02-09-2008, 09:33 PM
TheEAR's Avatar
21" drivers,no no boxes needed...to large. To make a 21" work well in the same box as a competent 18" you need one heck of a huge motor. And this would push prices up. Then all the excitement would result in a few orders.
A great 18" driver is all we need,multiples can be used if one is not enough.
Ask yourself mortal , do you have as much displacement as me ? The answer is no unless you have a Windmere fan sub.
TheEAR is offline
post #191 of 711 Old 02-09-2008, 10:24 PM
michael hurd's Avatar
Quoted: 43 Post(s)
Liked: 41
I think he meant use the 21 inch basket for the 18".... trouble is it would have a small spider land. This would give you room for a huge surround... but not enough of a spider.
"What the heck was that crashing noise?" Me: "oh, just tossed the shampoo bottles off the shelf on the opposite side of the house. "
michael hurd is offline
post #192 of 711 Old 02-09-2008, 10:50 PM
Spezzy's Avatar
Yeah, that's what I was thinking of.
Didn't know about the spider part, bad idea I guess.
Spezzy is offline
post #193 of 711 Old 02-10-2008, 12:40 AM
armystud0911's Avatar
WillD,
Army,
Actually 22ft tuned to 15hz looks do-able to me, or 25ft tuned to 14hz. These have a built in house curve. Of course what this thing really wants is 40ft tuned to 11hz. I think what I'm going to do at first is put it in 10ft sealed & stuffed. I got it for $710 and I'm pretty certain that I can get most if not all of that back if I decide to sell it. I just wanted to try it out. If it isn't doing it for me, I'll get rid of it. Somebody had to try one for HT at some point.
$710 is a NICE price, I looked into that driver a while back, the cheapest I was quite was $1800. They do have a built in house curve due to the lower fs and the fact that the cone just never stops going out, I tend to like woofers that are down 6dB or so at the tuning, I often times still wind up having to tame the response a bit so, more output down there is really a waste. That driver also seems to want perhaps even a sub 10Hz tuning, I'd to do something like 7Hz tune in a closet size box.
armystud0911 is offline
post #194 of 711 Old 02-10-2008, 01:16 AM
noah katz's Avatar
Quoted: 881 Post(s)
Liked: 304
Kevin,
That's for addressing our questions and for the interesting simulations.
You say 100% fill for the boxes; should your Q values perhaps be a bit lower?
I especially wonder about Qp, to which output is quite sensitive. Have you done any experimenting to see how far the stuffing needs to from the PR diaphragms to have minimal affect?
Noah
noah katz is online now
post #195 of 711 Old 02-11-2008, 09:26 AM
Kevin,
Are you talking about the Q mechanical for the PR, QL box loss or Qtc of the system?
I'm not sure how many variables Ingmar changes with the %fill. That is a good question. If you change the % fill its about the same as increasing the box size by 10-15% in terms of tuning frequency of either the PRs or a port. Box losses would be higher but not enough to make a significant change in the response. I play with a range of them when I'm simulating a design because its difficult to know exactly what its going to be in the finished box design. You tend to get overall lower Qtc but that goes hand-hand with the larger box size.
The Q of the PRs should be independent of fill. If I'm doing a final design I play with some of the variables. You can also play with % fill in final product to make subjective choices about the real system. The PR system would allow you to play with tuning frequency & % fill much easier than a port. Just change mass & add/remove fill.
I have the QL = 15 which is probably what your talking about. A more typical QL = 7 would probably have been a better choice. It doesn't make a huge difference in the response though.
And no... I've not done any experimentation with how far the stuffing should be from the back of either the driver or the PR. I just stuff the enclosure such that I have plenty of wiggle room between the fill & the driver. I figure a 3"-4" buffer is plenty.
Kevin Haskins
Exodus Audio
post #196 of 711 Old 02-11-2008, 01:46 PM
noah katz's Avatar
Quoted: 881 Post(s)
Liked: 304
"Are you talking about the Q mechanical for the PR, QL box loss or Qtc of the system?"
Good question
I guess not Qa at that low freq.
If the fill moves, I guess that would be equivalent to box leakage, Ql.
"I figure a 3"-4" buffer is plenty."
Maybe, but I wonder, when the PR is capable of moving to within an inch of it.
It would be interesting to put in a plexiglass porthole so you could see what the fill does in operation.
Noah
post #197 of 711 Old 02-16-2008, 09:25 AM
aduljr's Avatar
I am curious to what this beast of a sub will look like
aduljr is offline
post #198 of 711 Old 02-16-2008, 11:23 AM
Me too...
Kevin Haskins
Exodus Audio
post #199 of 711 Old 02-16-2008, 12:48 PM
Looneybomber's Avatar
Liked: 25
"Scariest environment imaginable...thanks. That's all you had to say, scariest environment imaginable" -Armageddon.
YID DIY
Looneybomber is offline
post #200 of 711 Old 02-16-2008, 08:28 PM
TheEAR's Avatar
To keep this thread alive....
Kevin,
Better make sure this beast ~$1000 driver is produced,I am waiting.
TheEAR is offline
post #201 of 711 Old 02-17-2008, 09:53 AM
Kevin,
Nov 2008. The wheels are in motion.
I've been given a shipping date for the Maelstrom-X & DPL-15 of April 15th.
Kevin Haskins
Exodus Audio
post #202 of 711 Old 02-17-2008, 10:20 AM
Willd's Avatar
Dpl-15?
Willd is offline
post #203 of 711 Old 02-17-2008, 02:31 PM
Liked: 25
Going to have to mark the calender. Sounds like a good reason to throw a party
Dpl-15?
l l Yeah, what he said.
YID DIY
post #204 of 711 Old 02-17-2008, 02:39 PM
The DPL-15 is our IB/Dipole specific design.
Most of these will probably sell as IBs. I'm going to run a special when they arrive, $240 for two, $450/ for four, $850 for eight and all prices include shipping.
Not only will it represent a great value for IBs, with an excellent Cost/L of displacement, the XBL^2 motor and low inductance AlCu shorting rings promise very linear output. We maximized pole vent & basket spacing for low noise operation also.
Don't be fooled by the efficiency, they only need about 200W per driver to get up and moving in IB use. Model them, in an IB install they have great extension.
Singles are $125 each plus shipping.
Pre-Production Parameters:
Re: 6.1 Ohm
Le: 1.7 mH
Fs: 19.5 Hz
Qms: 3.27
Qes: 0.84
Qts: 0.67
Mms: 271g
Cms: 0.23 mm/N
Vas: 232L
Sd: 830 cm^2
Vd: 3.65L
BL: 15.67
SPL: 85.2 1W/1M
X-max: 22mm
X-mech 29mm
Motor Design:
Kevin Haskins
Exodus Audio
post #205 of 711 Old 02-17-2008, 08:31 PM
TheEAR's Avatar
Outstanding news !
In this case April and November are subwoofer order days.
TheEAR is offline
post #206 of 711 Old 02-17-2008, 10:00 PM
[quote=Kevin Haskins;13139119]The DPL-15 is our IB/Dipole specific design.
Re: 6.1 Ohm
Le: 1.7 mH
Fs: 19.5 Hz
Qms: 3.27
Qes: 0.84
Qts: 0.67
Mms: 271g
Cms: 0.23 mm/N
Vas: 232L
Sd: 830 cm^2
Vd: 3.65L
BL: 15.67
SPL: 85.2 1W/1M
X-max: 22mm
X-mech 29mm
This looks pretty much the same as the the Fi car 15 Sub specs except that this one has 5mm more xmech and quite possibly a lower distortion motor. Price is the same too, wow, very nice. Now, you just need to make an 18" that costs $200 with 30mm xmax and maybe 36mm xmech with a large vas for a another good, larger IB/dipole driver.
post #207 of 711 Old 02-17-2008, 11:51 PM
aduljr's Avatar
wish I had the space and the permission to do the DPL-15...
aduljr is offline
post #208 of 711 Old 02-18-2008, 11:19 AM
I'm probably not going to do another 18". I prefer the 15"s for IB use because the manifold gets too large for four driver configurations. They also don't fit between standard stud spacing so there are some mechanical reasons to prefer a 15" vs. an 18". For IBs, just keep adding drivers until you get the output you need.
Both are IB drivers to its not surprising to see spec's close to the same. I can assure you though, the BL curve is flat, and the inductance is extremely well controlled.
XBL^2 has lost some converts since Wiggins was promoting it hard. I found most people don't give the split/gap short coil motor a second thought. When Adire went down the tubes and they put out all that crappy product and their reputation went in the toilet. Also, there has been some testing of product where people didn't see distortion improvements. Somehow people came to the conclusion that XBL^2 motors, are not necessarily delivering what they say. Somehow the driver really isn't any better. Nothing could be further from the truth. Flat BL certainly isn't the entire story but its a big part of getting low distortion. The ENTIRE driver design is important though, XBL^2 or other motor topology. If your suspension non-linearities dominate the THD spectrum, it won't matter that you have flat BL because there are other factors that are limiting you. That doesn't mean that XBL^2 is a poor design choice. It means that you need to work on your suspension design!
Anyway.... I'm rambling. Just venting to start the day.
Kevin Haskins
Exodus Audio
post #209 of 711 Old 02-18-2008, 11:11 PM
aduljr's Avatar
your ramblings are pretty damn interesting if you ask me
aduljr is offline
post #210 of 711 Old 02-18-2008, 11:51 PM
noah katz's Avatar
Quoted: 881 Post(s)
Liked: 304
"your ramblings are pretty damn interesting if you ask me"
+1 v
Noah
