Music and Movies Shine in This Home Theater - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 04-14-2008, 05:43 AM - Thread Starter
Chuck McKenney's Avatar
No matter what's playing, whether it's 2-channel music or 7.1-channel soundtracks, this home theater sounds great!
This homeowner wanted a balance of state-of-the-art sound and video within a designer-inspired environmentall without breaking the bank.
To make the magic happen, Media Design Associates calculated modal frequencies based on the initial room dimensions. The builder also accommodated slight changes to the envelope to insure that modal frequency overlap was minimized and seating placement was optimized. Because of the build-out and equipment chosen, it is optimal for 2-channel sound and for theater, says Michael Wohl, founder and CEO of Media Design Associates.
As with many installs, the projector also posed a problem. A quick solution was a floating soffit, which creates a visual break on the walls, allowing both proper projector offset and placement for four surround speakers.
Click here to read more.
Click here to view slideshow.
Chuck McKenney is offline
Reply CE Pro & Electronic House Articles
