Show off your outdoor screen! - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #61 of 68 Old 08-19-2017, 02:01 PM
soundofrockets's Avatar
I too ordered screen from Carl's place - 16:9 sizi in flexiwhite material. Haven't made the screen or got the EMT tubes/pipes yet. Should I be adding total of 8 inches to the length and 8 inches to the width for the frame or the dimensions provided by Carl's place are accurate?
soundofrockets is offline
post #62 of 68 Old 08-19-2017, 02:29 PM
b curry's Avatar
Quoted: 477 Post(s)
Liked: 278
What size is your screen? It's not clear if you're saying 9' x 16' size screen or 16:9 aspect.
The short answer is yes, you add 4" to each side or 8" total to the length and height.
If you mean 9" x 16' in size, here are the instructions direct from Carl's web site. BTW, are you wanting a hanging screen or free standing? I'll post links for both in the 9" x 16" size.
Free standing:
http://www.carlofet.com/files/9x16-f...structions.pdf
Hanging:
http://www.carlofet.com/files/9x16-w...structions.pdf
b curry is offline
post #63 of 68 Old 08-19-2017, 02:57 PM
Free standing:
Hanging:
Size is 16' by 9' in 16:9 format. So the dimensions given on the web site are accurate ? Or do I have to make some adjustments to them. Is there a way to make the edges smooth?
I have still not finalized the projector.
post #64 of 68 Old 08-19-2017, 02:59 PM
The screen will be free standing.
post #65 of 68 Old 08-19-2017, 03:17 PM
b curry's Avatar
Quoted: 477 Post(s)
Liked: 278
Yes, they are, with some small ± variation. You would have to ask Carl's what that tolerance is. I just use their dimensions and follow the 4" rule and it works out just fine.
If you use the links I gave you, Carl's gives you the cut lengths for the EMT for that size.
Click on the link for free standing and follow the instructions.
I don't understand what you're asking here.
b curry is offline
post #66 of 68 Old 08-19-2017, 03:26 PM
Thanks. With regards to the edges my question was related to the cut ends of the EMT pipe - which I am presuming will be sharp once they are cut.
post #67 of 68 Old 08-19-2017, 03:34 PM
b curry's Avatar
Quoted: 477 Post(s)
Liked: 278
Depends on how you cut it. If you use a hack saw or a power saw, sawzall etc. you will get some very sharp edges. A pipe cutter/conduit cutter will give you the best cut but, if you're too aggressive you will crush the conduit and have a bad edge too.
Either way, you can use a tube deburring tool or a pair of pliers to ream and a file to clean up the edge.
b curry is offline
post #68 of 68 Old 09-27-2017, 12:05 PM
JeffK1234's Avatar
This is my outdoor screen. I use rear projection. It is nice because I can keep all m equipment in garage. The screen is trapeze fabric I ordered online. The frame folds down in half so I can push it into the garage when in use.
ID:	2288950   Click image for larger version
ID:	2288952   Click image for larger version
JeffK1234 is offline
Reply Outdoor Theaters
