newbie informatio about outdoor projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-19-2008, 01:25 PM - Thread Starter
ingerulandrei's Avatar
My aim is to have a projector to project 24 hours per day, 7 days per week outdoors on a maximum screen of 3-4 square meters (a 4:3 image prefferably).
Are there any sort of projectors recommandation you can make? Thank you very much for upcomming advice, I would really appreciate it.
Best regards.
ingerulandrei is offline
post #2 of 8 Old 07-19-2008, 06:55 PM
victor-eyd's Avatar
Why would you need to be playing during the daytime? You won't see an image.
Free cake! Free cake!
- Mordecai and Rigby
Big Screen/Small Space! My 13x12 Bedroom HT
Think small, project big!
Small theaters gallery
victor-eyd is offline
post #3 of 8 Old 07-20-2008, 09:39 AM - Thread Starter
isn't it possible to have a clear image during daytime? And even maybe with some sun on it?
post #4 of 8 Old 07-20-2008, 10:48 AM
victor-eyd's Avatar
No you will not have a clear (if any image) during daytime.
The light of a projector is no match for the light of the sun.
post #5 of 8 Old 07-23-2008, 05:55 AM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 486
No way... Night time only....
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is online now
post #6 of 8 Old 07-23-2008, 08:01 AM
jsloyer's Avatar
at 24x7, you'll run out of all the movies at Blockbuster to watch in about 4 weeks..!
jsloyer is offline
post #7 of 8 Old 07-24-2008, 03:48 AM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 486
Good point.
post #8 of 8 Old 08-15-2008, 07:59 AM
imjay's Avatar
Not sure if the original question serious thread of not.
No - you cannot project in sunlight - not morning, noon or even evening shade sunlight. You might be able to have some visible image in sunlight if you constructed a square frame all around your screen area that extends out far enough from the image - maybe four or five or six feet - that would block any direct sunlight hitting your image. I have seen stores attempt to demonstrate projection in the brightly lit showrooms this way - still doesn't work - viewers standing directly in front of this mess can see something but it ain't a good image - back to the answer - No.
TV displays don't work much in direct sunlight either - alternative answer is, yes, you will need a very, very expensive professional solution - like the jumbo-tron displays that work in daylight at football stadiums or the giant displays that run 24/7 in Times Square in New York City - can we say millions of $$$$$?
24/7 projection equals 168 hrs/week equals 672 hrs/month equals exhausted and probably dead lamp in 3 to 4 months equals bad idea.
No - 2.5 meter throw distance won't produce a 4 meter square image (with any projector I know of) - you will need an extremely bright professional display.
You don't share what your application is (that means, what in the world are you trying to accomplish?). It must be either some advertising gimmick or you want to drive a neighbor out of his or her mind.
goodluck
imjay is offline
Reply Outdoor Theaters
