Need A Projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 09-08-2008, 10:51 AM - Thread Starter
firemankjr's Avatar
Can you guys recommed a good pj for indoor / outdoor use? I am lloking to spend less that a grand but would like to get a quality projector.
firemankjr is offline
post #2 of 10 Old 09-08-2008, 11:06 AM
victor-eyd's Avatar
Whatever projector you buy with the features you like will work for indoors and outdoors. However, I would recommend a 16:9 based projector.
Victor
Free cake! Free cake!
- Mordecai and Rigby
Big Screen/Small Space! My 13x12 Bedroom HT
Think small, project big!
Small theaters gallery
victor-eyd is offline
post #3 of 10 Old 09-08-2008, 11:16 AM - Thread Starter
firemankjr's Avatar
is there a lumen rating I should look for? any other special features i should consider?
post #4 of 10 Old 09-08-2008, 11:17 AM - Thread Starter
firemankjr's Avatar
Viewsonic PJ551D DLP® Projector is at Sams for less than $ 600. I am looking for a low level entry system to try. I already have a screen that is 10' diag.
post #5 of 10 Old 09-08-2008, 11:52 AM
victor-eyd's Avatar
I would also lamp life and replacement costs. Here's something to read
http://backyardtheater.com/forums/in...p?topic=2735.0
As to lumens, the brighter the pj, the typically earlier to watch- maybe 20-30 minutes depending on the weather/time of dusk. I would also consider as good a resolution as you can get- a 1024x768 XGA pj = 576p only for 16:9/movie material so this would be the bare minimum for projection.
Victor
post #6 of 10 Old 09-08-2008, 12:01 PM - Thread Starter
firemankjr's Avatar
thanks
post #7 of 10 Old 11-03-2008, 06:13 PM
joerod's Avatar
Quoted: 610 Post(s)
Liked: 492
Sanyo z5 gets the job done on my 20 foot screen...
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is online now
post #8 of 10 Old 11-07-2008, 02:31 PM
elmalloc's Avatar
Quoted: 53 Post(s)
Liked: 52
elmalloc is online now
post #9 of 10 Old 11-20-2008, 01:42 AM
hihich's Avatar
Maybe you can try 25 ft.
__________________
bagssky
http://www.bagssky.com text(anchor text): I love hangbag
hihich is offline
post #10 of 10 Old 11-23-2008, 09:54 AM
timtimes's Avatar
I was able to purchase a Benq PE7700 DLP HD 16:9 with full factory warranty directly from the factory (REFURB) last year for $800. It's a notable improvement over my 4:3 XGA Benq PB6200. Either of my PJ's will project fine to any screen size I have seen here. I'm running 8 x 16 feet in the backyard with no problems. Could go bigger.
Enjoy.
This ain't no upwardly mobile freeway, this is the road to hell.
timtimes is offline
Reply Outdoor Theaters
