Building my first outdoor theatre...need projector advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-15-2008, 12:59 PM - Thread Starter
rebel_scum's Avatar
Hey all
I have a rooftop apartment in the city with a fairly huge private terrace. I'm planning on buying a DLP or LCD projector so that I can play movies (and more importantly, Rock Band :P) on my patio. But I'm nearly completely ignorant when it comes to projectors.
All I know is, because there are very few tall buildings in the neighbourhood, light pollution is not a huge factor, but the area will be far from pitch-black.
The patio is about 18 feet deep, and I would like to position it as far away from the wall as possible. (i.e. the full 18 feet.)
720p is preferable, but not not a huge concern.
Ideally, I'd like the projector to sit about 9 feet off the ground, to avoid people walking in front of it, but still operate right-side up as I will have no cieling onto which I'll be able to attach it But it's also not a huge concern.
In the end, I would like the image do be ~200" diagonal. (it's a big wall :P)
I'll be plugging in a DIVX DVD player and/or an xbox 360, so it needs to have at least component inputs. (VGA will do; I can just purchase the adapter
I found this one: http://www.canadacomputers.com/index...32&cid=333.249
Can anyone offer any advice?
Additionally, if anyone has a suitable projector to sell, I'd be interested in hearing about it. (I'm in Toronto.)
Many thanks to all
EDIT: I should prolly mention that money is indeed a concern I'm definitely looking for something used
Cheers
rebel_scum is offline
post #2 of 4 Old 09-16-2008, 11:24 PM
rholdenphoto's Avatar
You may want to check this out. http://store.infocus.com/Stores/Cons...-26E7C8401A79}
It's a business projector but you can't beat it for the price.
rholdenphoto is offline
post #3 of 4 Old 09-26-2008, 04:22 PM
tscoff's Avatar
I have the InFocus X2 and it does a pretty good job outside. Keep in mind that the larger you make the image the less bright it will be. I replaced the InFocus with a Dell 2400MP because the Dell is almost twice as bright. It's also $1,000 US so if price is an object it isn't what you're looking for.
tscoff is offline
post #4 of 4 Old 10-19-2008, 04:55 PM
av noob's Avatar
I use the Panasonic ax200, a 720p PJ that puts out a serious amount of light and is under $1k now. I use it on a 16' x 9' foot outdoor screen and it looks great.
av noob is offline
Reply Outdoor Theaters
