Outdoor sub system - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-23-2010, 11:28 AM - Thread Starter
jbwilliams's Avatar
I am looking for an awesome outdoor sub system. I need a 3 speaker system that will handle all the different frequencies for rock, rap, and country. I need it to plug into a recievers composite plugs and a 110 wall plug-in and rock the f out. It would also be nice if it was on wheels. Anyone have any suggestions where I can find this?
Thanks for any and all help
jbwilliams is offline
post #2 of 5 Old 04-23-2010, 12:09 PM
AVRoberts's Avatar
You could check out the outdoor systems made by PolkAudio. They have an outdoor subwoofer that looks like a ceramic plant stand.
AVRoberts is offline
post #3 of 5 Old 04-25-2010, 01:36 PM
Mr.Poindexter's Avatar
Quoted: 20 Post(s)
Liked: 29
I don't think those rock subs would "rouck the f out" and you might want to look into a professional DJ subwoofer. You won't want it on casters as that absorbs a lot of the energy and cuts into your output but you could probably get it with casters on the side and lay it down to roll it around when not in place.
I don't know where you are, but you could probably find a pro audio shop like Guitar Center or something.
Country has less bass than rock which has less than Rap if you include Hip Hop in the mix. Either way, none of them have the deep bass of films, so a DJ system would probably work just fine for you.
Mr.Poindexter is offline
post #4 of 5 Old 04-28-2010, 09:27 PM
Hydrazine's Avatar
Quoted: 83 Post(s)
Liked: 118
Do what I did. Build your own subs.
8 15" subwoofers with ~4.8K Watts bridged in a series parallel combination.
2 12" midbass/midrange drivers with EV compression drivers powered with ~2.4KW
For me, I prefer sealed subwoofer boxes with a Q of about 0.9. Vented boxes are more efficient and handle more power but if you want realllly deep base. 15Hz... You want a sealed box. 99% of vented boxes unload the driver at high power below 30Hz. They do nothing but destroy themselves from over excursion if you try to turn them up.
This is why I like the simple sealed box. The driver never unloads and this means you can still produce very deep, infrasonic sounds. Yes, you can equalize it flat for response as low as you want to go and the cone always remains in control of itself with proper supervision.
With a vented box, it doesn't matter how much supervision you give them. They just won't reproduce much large signal sound below their resonance frequency.
I like sealed boxes because there are occasional movies or music clips with really deep bass in the 15Hz - 30Hz range. When you have high power amplifiers to back up the sealed boxes, you can crank the "F" out of it at high levels.... And that is when things gets fun.
Its not necessarily (audibly) loud at 15Hz, but when you dump 4.8KW of infrasonic energy into the outdoor theater air, its absolute bliss. Even when you crank the "F" out of infrasonics, its not audibly loud, but you absolutely feel its warming glow.
Have fun. Do it.
PS - High power levels @ 15-20 HZ won't bring the cops to your house like 100Hz will.
Hydrazine is offline
post #5 of 5 Old 04-30-2010, 12:18 PM
Administrator
Administrator
Mike Lang's Avatar
Quoted: 883 Post(s)
Liked: 697
Posts removed due to bickering
Mike Lang, Administrator
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Join the AVS Forum Club and help support the site. Help Support AVS Forum Sponsors.
AVS Forum is not sponsored by or in any way affiliated with AV Science Inc.
Mike Lang is offline
Reply Outdoor Theaters
