Paint for polyvinyl tarp screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 09-23-2010, 08:11 AM - Thread Starter
Tolwyn's Avatar
Hi, hope someone has a suggestion.
I put together a polyvinyl tarp screen for camping trips (14' x 10' white , double backed, clothesline wire hooked through the grommets and racheted into place between 2 trees). The setup is ok, but I am getting quite a bit of glare from the tarp, which is too 'shiny'. Is there a paint or product that I can use to matte it down to get a better picture?
Tolwyn is offline
post #2 of 10 Old 09-23-2010, 12:05 PM
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
OOoooo...that one's pretty tough. I would think that paint would not stick the vinyl. Most of the painted outdoor screens I've seen have been plain painter canvas tarps.
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #3 of 10 Old 09-24-2010, 02:37 AM
kiss_alive's Avatar
there is screen paint out there that is applied in a few steps.
http://www.gooscreen.com/
kiss_alive is offline
post #4 of 10 Old 09-24-2010, 06:21 AM - Thread Starter
Tolwyn's Avatar
I guess another choice would be to alter the polyvinyl by applying some kind of product to remove the gloss. Any ideas on what would do the trick? It doesn't need to be perfect or even close, I'm just looking to improve what I have. People watching the movie don't complain about the glare, but it drives ME crazy!
Tolwyn is offline
post #5 of 10 Old 01-30-2011, 10:45 PM
Telemachus77's Avatar
Nice, they estimated $2500 to cover the size tarp I want to put up outside.
What a joke!
Maybe matte banner material would be a better choice?
Telemachus77 is offline
post #6 of 10 Old 03-11-2011, 06:11 PM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
Have you looked at carls outdoor screens? Mine is 16' x 9' BOC, no issues, no need to paint.
mtbdudex is offline
post #7 of 10 Old 03-14-2011, 07:27 AM
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
You might check out Dazian fabric as well. Can be had in HUGE dimensions.
Tom Logan
post #8 of 10 Old 05-09-2012, 09:31 AM
Joel.DeLaCruz's Avatar
Hmm, That is a tough one because like the other guy said, paint doesn't really stick well to Tarps . Maybe you can get a custom made tarp?
Joel.DeLaCruz is offline
post #9 of 10 Old 07-11-2012, 04:01 PM
akyramoto's Avatar
maybe making one out of a canvas drop cloth might be better? way easier to paint than a plastic tarp, easy to install grommets into.
akyramoto is offline
post #10 of 10 Old 07-11-2012, 04:02 PM
akyramoto's Avatar
Maybe make one from a canvas drop cloth? easier to paint!
Reply Outdoor Theaters
