Setting Up/Controlling Audio Around Pool and Patio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 06-12-2011, 09:31 AM - Thread Starter
WinstonSmith's Avatar
Hello,
I apologize if I am posting this in the wrong sub-forum as I am not sure exactly where this topic would best be discussed.
We are putting an inground pool in our backyard and we are going to extend our current patio around the pool and enlarge it.
What I would like is to have 2 (or maybe 4) of the rock speakers around the pool in the landscaping and then have 2 indoor/outdoor speakers on the deck facing the patio area.
I'd also like to be able to hook the speakers up to a receiver inside my house, and connect that speaker (somehow) to my Windows Home Server so that I can stream mp3s, Internet radio, etc. to the speakers surrounding the pool and patio. I'd like to be able to control the entire thing (or at least the mp3/streaming part of it through my Android phone or an iPod touch. However, I'm not sure if any or all of this is possible.
I am not looking for audiophile quality here, getting the music out there is the main goal. Essentially looking for entry-level stuff to accomplish the goal. After the costs of the pool and landscaping, retaining wall, etc. there isn't a lot of budget for music.
I guess I have a few questions I was hoping for some help with:
-- Any experience with the rock style speakers? Are some inexpensive ones good enough for what I'm wanting to do?
-- What type of receiver would I need?
-- Is it even possible to stream mp3s from a server to a receiver and control it with a smartphone?
-- What kind of speakerwire would be necessary to run underground?
Truly, any advice would be helpful. Thanks for your time.
My Specs:
Sony KDF55WF655 HDTV | Pioneer VSX1015TX Receiver | JBL SCS180SC 6.1 Surround Speakers | DirecTV HR20 | HTPC | PlayStation3
WinstonSmith is offline
post #2 of 11 Old 06-13-2011, 07:02 AM
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
If budget is an issue....
You can run low voltage wire used for outdoor lighting as speaker wire. I would recommend the heavier gauge. IT is rated to be buried. However,if you are going to bury it, I would recommend conduit in case you ever have to pull another run.
In general, I bought a cheap RCA 5.1 home theater in a box and a small plastic cabinet designed to store garden tools that had two shelves and swing open doors. I drilled a few holes and created an outdor entertainment cabinet. I can leave it out there all the time. I even hooked up a DVD player and bring out my small projector for movies. ANd I jsut added a ROku for al lof the streaming stuff.
Good luck!
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #3 of 11 Old 06-18-2011, 09:21 PM - Thread Starter
Good luck!
Thanks for the advice. Low voltage wire is an interesting idea. I like it.
I have thought about having a cabinet to put outdoors and just leave everything in there and I'm glad to know someone else has been able to do that.
My Specs:
post #4 of 11 Old 06-22-2011, 09:07 PM
TreyS's Avatar
You can control it with iTunes, the iPod and AirPlay. Download apple remote from the app store. You'll need wifi access too.
TreyS is offline
post #5 of 11 Old 06-30-2011, 02:11 PM - Thread Starter
I'll have to do some research on this as I'm not nearly as familiar with Apple products.
Thanks for the idea!
My Specs:
post #6 of 11 Old 06-30-2011, 11:01 PM - Thread Starter
Trey, have you done this?
Is the 3.5-mm audio minijack on the AirPort Express easily connected to an AV Receiver?
My Specs:
post #7 of 11 Old 11-28-2011, 08:36 PM
cdepaola's Avatar
One word... Sonos!
This is the best gadget ever.
Chris
cdepaola is online now
post #8 of 11 Old 12-10-2011, 05:17 AM
Icon Master's Avatar
Sonos will cost you a bundle. Get a Marantz receiver with AirPlay then use an iPhone to send music from itself or any of up to 5 networked Macs' music collections with music sharing enabled to your receiver. You can select your music from the music app on the iPhone. If you need more zones like around a pool area then connect a multi zone amplifier to the receiver.
You can also use Pandora to send music via AirPlay into your home system. Apple's Airplay implemented with an AirPlay capable receiver pretty much makes Sonos obsolete.
Icon Master is offline
post #9 of 11 Old 07-11-2012, 04:05 PM
akyramoto's Avatar
Originally Posted by cdepaola View Post
One word... Sonos!
I second that!
akyramoto is offline
post #10 of 11 Old 07-12-2012, 02:00 PM
William Luzzi's Avatar
And I too have a custom outdoor cabinet. Here's my 5.1 outdoor setup which not only works fantastically and can blow the whole neighborhood away, but which is relatively high end but cheap enough to tackle (probably). And, if you can manage to buy all used equipment off of Audiogon.com, you'd be all the better smile.gif
1 - Suncast 6' double-door cabinet (paid about $80 - caulked all connection points and added a shower curtain liner hanging from the top of the inside to the bottom of the inside to protect from water entering the double-doors when closed and poked 4 drainage holes in the floor, raised the sub and power strip using a 2" thick piece if styrofoam packing material, and one 1x1" cut out with the flap still connected from the top (made 3 cuts, not 4) for the power cable, and all wiring - wiring protected by sump-pump hosing)
1 - NAD all in one L73 5.1 DVD Receiver (paid $500 new - 5x45W or 2x60W - sits in the cabinet - wpc rated MILES below what they can do - these things ROCK)
4 - Klipsch AW-650s 85wpc 6.5" 2-way outdoor water resistant speakers (paid about $1100 new for all 4 but I've seen them around new for as low as $382/pair - come in black or white and rarely in brown - these are AMAZING outdoors due to the horn tweeters/treble capability which is particularly important outdoors - 2 in the corners of the property with about 150 foot speaker wire runs each, and 2 behind the viewers as surrounds with about a 20 foot speaker wire run each - you ought to hear what it's like for movies, outside, under the stars, in the dark, when a group of horses comes running up in surround mode, with audio approaching from one side of the yard seemingly from acres away, crossing the entire yard, and exiting the other side - unreal...)
1 - Klipsch RC-52 II indoor center channel (paid about $175 on Audiogon - sits in the cabinet)
1 - Velodyne DLS3750RB 180W 10" sub with remote (paid $180 used off craigslist - MASSIVE in-home sounding bass - sits in the cabinet - I have 3 other Velodynes in my in-house setup!)
1 - PS3 (used from craigslist - for Blu-ray, Netflix streaming - sits in the cabinet - I have a 10'x20' screen I custom built used with an Optoma projector that sits across the 18x36 in-ground pool about 40 feet away - also amazing to go gaming on a 10'x20' screen!!!)
1 - Optoma HD71 720p DLP Home Theater Projector (used $500 on Amazon - brightest lumens I can find for early starts to movie night or full moons - excellent picture with Blu-ray even in 720p)
1 - iPod dock (sits in the cabinet)
1 - iPod (sits in cabinet)
1 - Cable box (sits in the cabinet - have cable wired to projector or 32" flatscreen hanging off the wall of the house over the Jacuzzi)
1 - 32" Insignia LCD (new from Best Buy for $175 with 4 years of protection from Geek Squad for $29.95 that covers everything but dropping; even water and moisture damage - whew! - cover it with a velcro grill cover for rain/snow)
This posting might beg many more questions such as wire gauge, above or below ground, how I made the projector screen etc. etc. So, ask away if you're interested. Obviously, one can swap out for cheaper products but this sounds nearly high-end to me even though I have a somewhat high-end in-houses system (although I AM looking to replace the 3 indoor subs with 1-2 JL Audio Fathoms). In-home system consists of
- PS Audio P5 Power Plant Power Regenerator
- PS Audio xStream Statement Power Cables throughout
- Parasound HCA2205at 230wpc 5-channel amp
- Anthem AVM20 processor (need to upgrade)
- 5 Joseph Audio speakers (2x RM25 SI Signature Mark II, 2x RM7 SI Signature and 1 Cinergy center)
- 3 Velodyne subs (2x DLS5000RB 15" 600W with 3000W peak, and 1x 15" SPL series)
- Paul Speltz Anti-cable speaker wiring (except subs) and Anti-IC Interconnects throughout
- Oppo Digital BDP-83 Blu-ray/SACD/DVD-A player
- Wadia dock for iPod
- Hi-fi Tuning Supreme Fuses in Parasound, P5, and Anthem (Oppo was hard-wired and would require sending in)
William Luzzi is offline
post #11 of 11 Old 03-25-2013, 02:23 PM
wishiwasfishing's Avatar
Hey Winston...check this website out...www.outdooraudio.com
I've used the amp and remote (while in a pool)..works great!
Good Luck!
wishiwasfishing is offline
Reply Outdoor Theaters
