Outdoor Screen made with Gemmy - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-18-2012, 06:48 PM - Thread Starter
PMR
PMR's Avatar
Here are some pictures of my outdoor screen made from the screen of a Gemmy blow up.Attachment 243917
Attachment 243918
PMR is offline
post #2 of 3 Old 05-03-2012, 01:50 PM
Cool Face's Avatar
very nice! the 2 sides in the buckets... are they going into a set concrete form? is this a permanent setup? how long is the setup time?
Cool Face is offline
post #3 of 3 Old 05-06-2012, 12:49 PM - Thread Starter
PMR
PMR's Avatar
Yes the pvc posts are set in concrete and the right and left supports just slide on them with a coupler. I take it down which only takes about 10 minutes and it takes about 15 to 20 minutes to put up. The ends screw into the left and right supports and the other ends slide into the center support and I use stainless steel bolts and wingnuts that slide through holes I drilled that hold them together.
PMR is offline
Reply Outdoor Theaters
