Panasonic Ar100U - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-03-2012, 06:41 AM - Thread Starter
Gpugh's Avatar
As anyone projected out as far as a 16 foot by 9 foot screen using the AR 100U projector outdoors?
Gpugh is offline
post #2 of 2 Old 05-03-2012, 12:45 PM
Cool Face's Avatar
not i. however the panasonic pt-ar100u is a fairly new projector. and it has 2800 lumens! a 9'x16' screen is not a problem for this projector! i used projectorcentral.com's projector calculator:
http://www.projectorcentral.com/Pana...ulator-pro.htm
and for a 9'x16' projected image, you'd need to have the projector about 28.5' away from your projection material. it is recommended you increase the brightness, but thats what it said for my projectors' distance. im getting a great image on defaults! i am using a BOC (black out cloth) projection material though. its one of the cheaper materials that reflects the most image back.
Cool Face is offline
Reply Outdoor Theaters
