Humidity and heat effect on receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 05-20-2012, 02:30 PM - Thread Starter
cnikirk's Avatar
For the last several years I have been showing movies outside. I have went through a couple of receivers during that time. When the equipment isn't being used I store it in my garage. The humidity and heat are pretty bad in the garage.
I was wondering how hard those conditions are on a receiver even when it is not in use? I am considering storing the equipment inside even though it would be an immense pain.
cnikirk is offline
post #2 of 11 Old 05-20-2012, 03:35 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 911
I'd think that the Electrolytic Capacitors in a receiver would be the most vulnerable to heat damage but a quick look at DigiKey shows the lowest heat rating as 65C and most are rated at 85C and above.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #3 of 11 Old 05-20-2012, 03:59 PM - Thread Starter
cnikirk's Avatar
Perhaps I've just had bad luck then. In Indiana we do get both very cold winters and very hot summers, so I was wondering whether the fluctuating temperatures were the problem. Thanks.
cnikirk is offline
post #4 of 11 Old 05-20-2012, 04:04 PM
gregzoll's Avatar
Liked: 33
You are better to store the equipment inside in a controlled environment when not in use. Storing it in a garage, unless it is in air & weather tight containers, with descant bags in those containers, you will see the lifespan limited. Even then, still find a place inside to store the equipment.
gregzoll is offline
post #5 of 11 Old 05-20-2012, 04:23 PM
Selden Ball's Avatar
Quoted: 3050 Post(s)
Liked: 1494
As gregzoll mentioned, you need to keep electronic equipment in a climate-controlled environment unless it is intentionally designed for outdoor use.
Temperature fluctuations cause the parts in the receiver to expand and contract. Different materials change size at different rates. This causes connections to physically break apart.
High temperature and humidity cause the parts in the receiver to corrode more rapidly. Oxides in the connections can cause them to become electrically disconnected.
Edited to add:
Getting water into dusty equipment is a disaster, too. That'll happen when humidity condenses onto cold surfaces after a long winter night.
Selden
Selden Ball is offline
post #6 of 11 Old 05-20-2012, 04:45 PM
KJSmitty's Avatar
Liked: 34
Maybe Ive just been lucky yet I have a cheap JVC receiver that has been in my garage since 1999. Dallas, TX area where temps in the garage can reach 110 with humidity in the 90% range. Winters aren't overly cold yet damp. Darn thing has never skipped a beat. Nor has the CD player under it... Gets dusty is an understatement.
Then again, I had a Samsung plasma within my enclosed patio and it stopped producing a picture within 18 months.... Everything else works on the TV yet it's like the bulbs burnt out (not suggesting plasma has a bulb by the way).
I'm 50/50 on what may have caused your / my TVs issues, but I do feel "stuff" just ain't made like it use to be and is entirely too flaky, OK "sensitive" to anything much more harsh than the vacuum of space... Less the temps that is.... :-). Partially kidding of course.
I too would probably protect your next device by storing it out of the elements to see if that achieves longer life. Maybe that and ensure you are providing it with a good, stable power supply while outside.
Cheers
Love DIY
KJSmitty is offline
post #7 of 11 Old 05-20-2012, 05:32 PM - Thread Starter
cnikirk's Avatar
Okay, it sounds like I need to find someway to store it inside. It is inside a nice cart I built which is why it is hard to put it inside. I may have to move the whole cart in.
cnikirk is offline
post #8 of 11 Old 05-20-2012, 05:59 PM
gregzoll's Avatar
Liked: 33
Edited to add:
Yep, just ask any soldier that has returned from Afghanistan or Iraq and ask them how quick electronics become non-workable.
gregzoll is offline
post #9 of 11 Old 05-20-2012, 06:01 PM
gregzoll's Avatar
Liked: 33
Just change it out to the same type of case that is used for rock concerts, to hold the equipment in. Easy to close up, rolls around on big casters, and has a port that you can connect the cables up to on the side, or you can install those yourself.
gregzoll is offline
post #10 of 11 Old 05-20-2012, 09:50 PM
MrBobb's Avatar
Quoted: 164 Post(s)
Liked: 63
It is very simple cnikirk. Just buy a picnic cooler big enough to store the items (you may need an industrial size). That will protect it in the garage against extremes. That's how people transport films (remember those?) during summer.
When storing, u may want to stuff some dry paper things in there and that will help absorb excess moisture.
MrBobb is offline
post #11 of 11 Old 05-21-2012, 05:41 PM - Thread Starter
cnikirk's Avatar
Interesting idea. Thank you.
cnikirk is offline
Reply Outdoor Theaters
